Offline 3gleise
#1 Posted : 30 October 2017 20:34:31(UTC)
3gleise
Hello to all
I always digitized marklin locomotives by welding resistors (file example) to the poles of the motor and then connecting them to the decoder
I ask if I should even cut it on rococo motors and what value in ohms.
thank you
#2 Posted : 30 October 2017 20:51:25(UTC)
Welcome to the forum.
If you are referring to those green "resistors" that come in Märklin conversion sets: those are chokes, not resistors. Resistors are usually neither needed nor used for conversions.
Check if the loco already has chokes.
Addresses for Mfx decoders (Digital)
by biswasg 19/04/2024 11:02:17(UTC)
Can't find decoder info to set up run on analog n layout. (H0-scale)
Belarus icf1vvn 15/04/2024 22:24:51(UTC)
CS3 Failure to Read and thus Write to DCC Decoder. (Digital)
by nikdog 06/04/2024 00:45:33(UTC)
Powerpack older 8-pin mLD decoder (Digital)
by jonas_sthlm 05/04/2024 12:31:11(UTC)
CS3 2.5.2. update older decoder FW (Digital)
by jonas_sthlm 25/03/2024 10:55:37(UTC)
Automatic telex uncoupling cycle msd3 decoder (Digital)
by jonas_sthlm 25/03/2024 08:30:04(UTC)
Roco 69618 AC digital (MFX decoder) br118 won't work on digital (H0-scale)
by Lev.Sever 18/03/2024 23:39:27(UTC)
Mobile station 2 not recognizing MFX decoder (Digital)
by Ivanmbrown 24/02/2024 01:55:36(UTC)
Decoder Read Message CS3Plus (Digital)
by mzecchi70 12/02/2024 03:21:12(UTC)
Which decoder in BR89 (MA30000)? (Digital)
by patnaik 01/02/2024 00:30:11(UTC)
6080 decoders (Digital)
by cintrans 25/01/2024 17:26:11(UTC)
BR798/998 (Marklin 39980) replacement decoder (H0-scale)
by Alex H 20/01/2024 20:51:28(UTC)
Tip: Bying a mSD3, decoder only. (Digital)
by bph 20/01/2024 14:26:38(UTC)
Decoder question (Digital)
by Timnomads 28/12/2023 10:36:07(UTC)
Startup decoders (H0-scale)
by revmox 28/12/2023 01:25:37(UTC)
6090 decoder working in analogue (H0-scale)
by Paul59 26/12/2023 21:12:49(UTC)
Programmed Decoder (Big scale)
by Roger W. Hooper 20/12/2023 17:32:20(UTC)
Decoder burn out! NEED new decoder (H0-scale)
by AndrePinto 19/12/2023 20:21:22(UTC)
24997 uncoupler problem with M83 decoder (H0-scale)
by fabstar68 19/12/2023 16:42:14(UTC)
Programming Uhlenbrock decoder 770 (Digital)
by kollemt 03/12/2023 23:45:27(UTC)
Märklin 39549 Robel 54.22 Decoder (Digital)
by Refvik 28/11/2023 23:45:54(UTC)
Block power and signal decoder (Digital)
by rytter 26/11/2023 23:12:12(UTC)
76200 decoder issue (Digital)
by Giovanni Carboni 24/11/2023 11:16:33(UTC)
Looking for a Decoder for Marklin 37780 ICE3 (General MRR)
by waterslip 23/11/2023 20:46:41(UTC)
Marklin decoder replacement (H0-scale)
by StanN 11/11/2023 18:01:22(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
Locked stock decoders or how to change the Function Keys (Digital)
by Sashmeister 13/10/2023 08:44:34(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
Marklin Decoder mSD3 Sound Fade (Digital)
by Kiko 11/10/2023 02:12:38(UTC)
need to upgrade decoders what will work (Digital)
by heinrichhess 21/09/2023 13:23:11(UTC)
How easy to fit decoders? (H0-scale)
by dave55uk 19/09/2023 10:04:25(UTC)
Change adress on decoder (Digital)
by henna 10/09/2023 20:38:35(UTC)
Marklin Decoders and JMRI (Model railroad software)
by Santa Fe Rly 05/09/2023 06:07:33(UTC)
ECosDecoder and new Marklin engines (Digital)
by DrCodeWizzard 27/08/2023 00:29:24(UTC)
digital loco with 6080 decoder in analog mode (H0-scale)
by 3104V200 25/08/2023 08:04:09(UTC)
what decoder needed to convert rail bus (Digital)
by heinrichhess 12/08/2023 22:10:30(UTC)
Help with Fleischmann 1166 - does it have a decoder, or not? (H0-scale)
by Lev.Sever 08/08/2023 21:41:49(UTC)
Marklin sound decoder bootloader/firmware update (60977) (Digital)
by dlwestphalen 08/08/2023 03:02:32(UTC)
AnDi decoder vs 60760 decoder (Digital)
by cintrans 01/08/2023 01:11:01(UTC)
CS2 and programmer programming decoder question (H0-scale)
by billyamy 18/07/2023 21:37:04(UTC)
Complete list of CVs for mSD3 decoders / Brake Squealing (Digital)
by Nalle 14/07/2023 10:35:31(UTC)
Help identify this decoder (Digital)
by Rosscoe 05/06/2023 10:02:08(UTC)
Turnout decoder, mobile station (Digital)
by pBonavoglia 31/05/2023 17:04:10(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Selection of sound data projects for all Märklin msD3 decoders (Digital)
by jonas_sthlm 17/05/2023 16:43:56(UTC)
Decoder MSD3 (60975) (Digital)
by Tie 15/05/2023 19:28:07(UTC)
Märklin S3/6 decoder upgrade (Big scale)
by QQQ1970 30/04/2023 15:52:11(UTC)
Decoder mSD vs mSD3 (bit and kHz) (Digital)
by jonas_sthlm 25/04/2023 10:44:52(UTC)
Changing function mapping in factory installed decoders via DCC (Digital)
by Gregor 19/04/2023 11:40:27(UTC)
Decoder gremlin (H0-scale)
by QQQ1970 19/04/2023 03:59:13(UTC)
This page was generated in 0.375 seconds.
