Offline 3gleise
#1 Posted : 30 October 2017 20:34:31(UTC)
3gleise
Hello to all
I always digitized marklin locomotives by welding resistors (file example) to the poles of the motor and then connecting them to the decoder
I ask if I should even cut it on rococo motors and what value in ohms.
thank you
#2 Posted : 30 October 2017 20:51:25(UTC)
Welcome to the forum.
If you are referring to those green "resistors" that come in Märklin conversion sets: those are chokes, not resistors. Resistors are usually neither needed nor used for conversions.
Check if the loco already has chokes.
Addresses for Mfx decoders (Digital)
by biswasg Yesterday at 11:02:17(UTC)
Can't find decoder info to set up run on analog n layout. (H0-scale)
by icf1vvn 15/04/2024 22:24:51(UTC)
CS3 Failure to Read and thus Write to DCC Decoder. (Digital)
by nikdog 06/04/2024 00:45:33(UTC)
Powerpack older 8-pin mLD decoder (Digital)
by jonas_sthlm 05/04/2024 12:31:11(UTC)
CS3 2.5.2. update older decoder FW (Digital)
by jonas_sthlm 25/03/2024 10:55:37(UTC)
Automatic telex uncoupling cycle msd3 decoder (Digital)
by jonas_sthlm 25/03/2024 08:30:04(UTC)
Roco 69618 AC digital (MFX decoder) br118 won't work on digital (H0-scale)
by Lev.Sever 18/03/2024 23:39:27(UTC)
Mobile station 2 not recognizing MFX decoder (Digital)
by Ivanmbrown 24/02/2024 01:55:36(UTC)
Decoder Read Message CS3Plus (Digital)
by mzecchi70 12/02/2024 03:21:12(UTC)
Which decoder in BR89 (MA30000)? (Digital)
by patnaik 01/02/2024 00:30:11(UTC)
6080 decoders (Digital)
by cintrans 25/01/2024 17:26:11(UTC)
BR798/998 (Marklin 39980) replacement decoder (H0-scale)
by Alex H 20/01/2024 20:51:28(UTC)
Tip: Bying a mSD3, decoder only. (Digital)
by bph 20/01/2024 14:26:38(UTC)
Decoder question (Digital)
by Timnomads 28/12/2023 10:36:07(UTC)
Startup decoders (H0-scale)
by revmox 28/12/2023 01:25:37(UTC)
6090 decoder working in analogue (H0-scale)
by Paul59 26/12/2023 21:12:49(UTC)
Programmed Decoder (Big scale)
by Roger W. Hooper 20/12/2023 17:32:20(UTC)
Decoder burn out! NEED new decoder (H0-scale)
by AndrePinto 19/12/2023 20:21:22(UTC)
24997 uncoupler problem with M83 decoder (H0-scale)
by fabstar68 19/12/2023 16:42:14(UTC)
Programming Uhlenbrock decoder 770 (Digital)
by kollemt 03/12/2023 23:45:27(UTC)
Märklin 39549 Robel 54.22 Decoder (Digital)
by Refvik 28/11/2023 23:45:54(UTC)
Block power and signal decoder (Digital)
by rytter 26/11/2023 23:12:12(UTC)
76200 decoder issue (Digital)
by Giovanni Carboni 24/11/2023 11:16:33(UTC)
Looking for a Decoder for Marklin 37780 ICE3 (General MRR)
by waterslip 23/11/2023 20:46:41(UTC)
Marklin decoder replacement (H0-scale)
by StanN 11/11/2023 18:01:22(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
Locked stock decoders or how to change the Function Keys (Digital)
by Sashmeister 13/10/2023 08:44:34(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
Marklin Decoder mSD3 Sound Fade (Digital)
by Kiko 11/10/2023 02:12:38(UTC)
need to upgrade decoders what will work (Digital)
by heinrichhess 21/09/2023 13:23:11(UTC)
How easy to fit decoders? (H0-scale)
by dave55uk 19/09/2023 10:04:25(UTC)
Change adress on decoder (Digital)
by henna 10/09/2023 20:38:35(UTC)
Marklin Decoders and JMRI (Model railroad software)
by Santa Fe Rly 05/09/2023 06:07:33(UTC)
ECosDecoder and new Marklin engines (Digital)
by DrCodeWizzard 27/08/2023 00:29:24(UTC)
digital loco with 6080 decoder in analog mode (H0-scale)
by 3104V200 25/08/2023 08:04:09(UTC)
what decoder needed to convert rail bus (Digital)
by heinrichhess 12/08/2023 22:10:30(UTC)
Help with Fleischmann 1166 - does it have a decoder, or not? (H0-scale)
by Lev.Sever 08/08/2023 21:41:49(UTC)
Marklin sound decoder bootloader/firmware update (60977) (Digital)
by dlwestphalen 08/08/2023 03:02:32(UTC)
AnDi decoder vs 60760 decoder (Digital)
by cintrans 01/08/2023 01:11:01(UTC)
CS2 and programmer programming decoder question (H0-scale)
by billyamy 18/07/2023 21:37:04(UTC)
Complete list of CVs for mSD3 decoders / Brake Squealing (Digital)
by Nalle 14/07/2023 10:35:31(UTC)
Help identify this decoder (Digital)
by Rosscoe 05/06/2023 10:02:08(UTC)
Turnout decoder, mobile station (Digital)
by pBonavoglia 31/05/2023 17:04:10(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Selection of sound data projects for all Märklin msD3 decoders (Digital)
by jonas_sthlm 17/05/2023 16:43:56(UTC)
Decoder MSD3 (60975) (Digital)
by Tie 15/05/2023 19:28:07(UTC)
Märklin S3/6 decoder upgrade (Big scale)
by QQQ1970 30/04/2023 15:52:11(UTC)
Decoder mSD vs mSD3 (bit and kHz) (Digital)
by jonas_sthlm 25/04/2023 10:44:52(UTC)
Changing function mapping in factory installed decoders via DCC (Digital)
by Gregor 19/04/2023 11:40:27(UTC)
Decoder gremlin (H0-scale)
by QQQ1970 19/04/2023 03:59:13(UTC)
