Offline capn_tinkydink
#1 Posted : 26 January 2002 04:01:08(UTC)
capn_tinkydink
I need some tips on cleaning M-Track; regular and switches. I just have the normal slight rust, as well as oily gunk in the switches.
#2 Posted : 27 January 2002 02:37:33(UTC)
Alcohol, or some kind of light oily cleaning fluid might work best. No stuff that will dissolve paint, though.. Also regular cleaning stuff like "Ajax", dishwashing liquid and such will probably work well on the gunk... This means manually scrubbing the tracks with a rag or such.
One unusual tip on the MML some years ago, was to put the tracks into a dishwashing machine and wash them there... But since the M rails are hollow, water might not be totally drained from inside the rails and they may rust from the inside...
I myself once manually dishwashed my old M-rails with a brush, as you normally do dishes, then put some of the tracks to dry "naturally", and put some into my washing dryer cabinet at max temperature... The ones that were "naturally" dried rusted, but the ones in the cabinet seemed ok...
If I was in the situation to clean M-tracks again, I would not go for the methods that involve water en masse, unless you can dry them quickly. The main thing to watch out for is to keep the inside of the hollow rails dry... Once you have got water inside those, only heat can dry it out... And you better do it quckly, since the rusting starts within hours...
C track cleaning (H0-scale)
by Alex H 05/11/2024 16:23:14(UTC)
Help with Marklin Track Cleaning cars (H0-scale)
by jimwallace1652 11/04/2024 23:55:53(UTC)
Marklin HO 46049 Track Cleaning Car 3-Rail (General MRR)
by mjborelli 19/02/2023 23:19:59(UTC)
Track cleaning machine (Big scale)
by nygma 21/05/2019 19:01:28(UTC)
Science of track cleaning (General MRR)
by Danlake 19/05/2019 09:26:10(UTC)
Track cleaning car comparison - Lux vs Dapol (H0-scale)
by Minok 10/03/2019 22:46:06(UTC)
LUX Track Cleaning Car 9130 (Reviews of rolling stock)
by PMPeter 13/12/2018 22:34:32(UTC)
Track cleaning (z scale) (Small scale)
by Trainiac 23/06/2018 15:39:07(UTC)
Track Cleaning (H0-scale)
by Kapalua 29/10/2017 09:15:00(UTC)
Marklin Track Cleaning Car (Small scale)
by BillO 02/11/2016 03:05:17(UTC)
Track Cleaning Car (H0-scale)
by Jabez 12/09/2016 23:23:57(UTC)
Track cleaning (General MRR)
by Varun R 24/05/2015 06:16:24(UTC)
Marklin German Track Cleaning Car of the DB (H0-scale)
by baggio 28/03/2015 18:08:24(UTC)
by db ice3 11/02/2015 11:43:33(UTC)
Märklin 46010 Track Cleaning Wagon (General MRR)
by Shamu 27/08/2014 12:15:50(UTC)
M-Track Cleaning (H0-scale)
by Makistrain 21/01/2014 23:13:12(UTC)
Track Cleaning Idea- is it pratical? (H0-scale)
by Harvey 15/10/2013 03:23:58(UTC)
Advice on Track Cleaning Product (H0-scale)
by Mike M 07/09/2013 23:25:39(UTC)
Track cleaning - Chemicals and metods (General MRR)
by Martin T 09/07/2013 09:39:24(UTC)
Can anyone identify this track cleaning car? (General MRR)
by kc6uvm_George 21/11/2012 20:33:27(UTC)
Cleaning Track Pads on 46042 Track Cleaning Car (General MRR)
by petestra 20/03/2012 16:16:37(UTC)
by swanpondwv 19/12/2011 01:53:43(UTC)
Track cleaning (Small scale)
by Jon11 25/08/2011 00:33:25(UTC)
HO track cleaning pads (H0-scale)
by Tex 11/08/2011 04:32:19(UTC)
ANY GOOD Z SCALE TRACK CLEANING CARS (Small scale)
by darticus 09/12/2010 02:18:44(UTC)
Track Cleaning Cars (H0-scale)
by Ranjit 21/10/2009 22:50:07(UTC)
Home madeTrack Cleaning Car (General MRR)
by FMS 31/05/2009 00:08:21(UTC)
Track cleaning cars (Small scale)
by ozzman 17/12/2008 01:21:51(UTC)
What track cleaning car would you suggest? (H0-scale)
by Eisenhower 10/11/2008 23:18:49(UTC)
Pulling Power for track cleaning (H0-scale)
by Martin T 03/09/2007 18:07:14(UTC)
C-Track Cleaning (including roadbed) (H0-scale)
by pmgsr 29/06/2007 17:09:50(UTC)
Track Cleaning (General MRR)
by bobhunt 07/02/2007 10:53:25(UTC)
Track cleaning... (General MRR)
by shaygetz 22/12/2006 05:38:02(UTC)
46042 Track Cleaning Car (H0-scale)
by MHauge 30/11/2005 08:09:17(UTC)
Track cleaning car (H0-scale)
by Winst0n 27/01/2004 17:17:35(UTC)
Track cleaning cars (H0-scale)
by PeFu 26/09/2003 12:09:42(UTC)
K + M HO Track Cleaning (H0-scale)
by Ranjit 24/06/2003 00:14:26(UTC)
This page was generated in 0.336 seconds.
