Offline drnodk
#1 Posted : 01 December 2017 04:38:26(UTC)
drnodk
I have had the following problem twice. When my lok derails and caused a shutdown I loose any forward or reverse motion.
Initially I have some functions like sounds but eventually they stop and all I have is a paper weight.
Do decoders blow from a simple derailment?
Bill
#2 Posted : 01 December 2017 05:08:34(UTC)
Bill
Bill, where does the paper weight come into it ? a decoder shouldn't fail completely because of a derailment, I think there is another reason for it and it could be coincidental.
some help would be if you can let us know what type of decoder and loco you're referring to
I have had sounds failing
thanks
#3 Posted : 01 December 2017 08:31:41(UTC)
Bill,
which locomotive are you referring to? Was the problem with the same locomotive twice?
A decoder can blow from a short circuit. Many times, a decoder will fry because live power is fed into the outputs.
Was this an OEM factory digital lok or is it a lok that you converted or had converted?
The more details you provide, the more detailed answer that we can provide.
What locomotive?
Factory Digital or Aftermarket Converted?
Type of Controller? (6021/MS1/2/3, CS1/2/3?)
If you have a derailment and after the derailment (I presume you mean after you replace the locomotive on the tracks) you still have sound, but that eventually stops working too and the lok is dead, this sounds like there may be some kind of short somewhere.
Once we have more information, I will be able to make a better assessment, and I think that this would help John or Jacques Vuyes provide help too.
Offline Kapalua
#4 Posted : 01 December 2017 11:47:10(UTC)
Kapalua
I had two Locomotives with Delta Decoders fry because of a faulty Mobile Station recently.
My questions is, do new decoders have some sort of fuse or overload protection?
Offline dickinsonj
#5 Posted : 02 December 2017 15:17:53(UTC)
Last year I blew up the decoder in my Württemberg C loco with just a brief short, so it is definitely possible for this to happen. The plus side was that I replaced the very old, original decoder with an ESU V4 decoder and it now runs better than it ever did before.
#6 Posted : 02 December 2017 20:04:36(UTC)
Usually it won't be the short circuit that damages the decoder, but the spark that comes with it. Sparks generate high voltage spikes at high frequencies and these travel through the tracks as well as radiating in the air.
The controller should shut down the instant a short circuit is detected, but if the problem occurs far from the power feed the resistance in the tracks and the feeder cables might delay the cut-off, allowing sparking to go on for longer.
#7 Posted : 02 December 2017 22:37:00(UTC)
Bill
thanks
It sounds stupid I know, but the ESU Loksound yahoo mail group periodically has people complaining about this happening. My personal opinion is that it is an effect due to things that would take too long to explain here, but involves generation of power spikes due to characteristics of non-obvious electronic components and the resulting high voltage spikes they generate when things get shorted. The immediate reaction is that 'it shouldn't happen' , but unfortunately it does. In the case of ESU decoders some people have success by doing multiple resets of the decoder, and/or reloading the software using a Lokprogrammer, but this is not guaranteed.
#8 Posted : 03 December 2017 01:54:15(UTC)
Bill
thanks
I've had many sound decoders (sound) failing and lately sent 5 back to ESU for repair but never had a decoder fail due to a derailment and yes I had decoders fail and than reset them and they worked fine afterwards which to me is a bit of a mystery., and one of these occurrences happened when ESU informed me the decoder I've sent back to them there was nothing wrong with it.
I also had a few Märklin decoders from clients who bought the loco in for conversions and failed do to a faulty motor., my latest repair (which I can't fulfill) is a overhead maintenance car with various functions, e.g. raising pantograph, movable working bridge, raising and lowering of working bridge and the rail car itself doesn't move at all, all I get out of it is the auxiliary sound functions. I'll get in contact with Märklin and see if they can repair the rail car (39970)., my friend said don't worry about it but I think it's worth the repair depending how much if anything Märklin will charge.
I've had my share of derailments but mainly with carriages and not with locos, when cleaning the pukos with a fine diamond plate (own design) and I forget to turn of my ECoS there are coming substantial sparks from it and most the time it shuts itself down.
So far I'm aware ESU decoders are protected from shorts but how far this protection goes I've got no idea nor am I qualified to make any technical or electronic assumptions.
Trix Turnouts using Marklin 74462 Decoders (Digital)
by xxup 29/08/2025 06:34:34(UTC)
How many digital decoders for C Track can you use? (Digital)
by michelvr 25/05/2025 23:29:05(UTC)
74462 and 74460 decoders with 6040 key board (H0-scale)
by George Felipes 11/04/2025 23:09:52(UTC)
Two decoders started acting funky this week (H0-scale)
by johnhendry 21/01/2025 16:39:11(UTC)
Help with Z decoders (Small scale)
by rbw993 18/01/2025 00:08:44(UTC)
Pre -programmed decoders (Big scale)
by Roger W. Hooper 08/08/2024 22:31:28(UTC)
Addresses for Mfx decoders (Digital)
by biswasg 19/04/2024 11:02:17(UTC)
6080 decoders (Digital)
by cintrans 25/01/2024 17:26:11(UTC)
Startup decoders (H0-scale)
by revmox 28/12/2023 01:25:37(UTC)
Locked stock decoders or how to change the Function Keys (Digital)
by Sashmeister 13/10/2023 08:44:34(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
need to upgrade decoders what will work (Digital)
by heinrichhess 21/09/2023 13:23:11(UTC)
How easy to fit decoders? (H0-scale)
by dave55uk 19/09/2023 10:04:25(UTC)
Marklin Decoders and JMRI (Model railroad software)
by Santa Fe Rly 05/09/2023 06:07:33(UTC)
Complete list of CVs for mSD3 decoders / Brake Squealing (Digital)
by Nalle 14/07/2023 10:35:31(UTC)
Selection of sound data projects for all Märklin msD3 decoders (Digital)
by jonas_sthlm 17/05/2023 16:43:56(UTC)
Changing function mapping in factory installed decoders via DCC (Digital)
by Gregor 19/04/2023 11:40:27(UTC)
Mapping 32 bit MFX decoders to production specs (Digital)
by Bryan 08/02/2023 03:39:49(UTC)
A Silly question about mSD3 decoders (Digital)
by einotuominen 24/01/2023 13:07:17(UTC)
Conversion of 3093 and alternative decoders? (Digital)
by einotuominen 13/01/2023 13:20:51(UTC)
CS3 for updating non Märklin decoders (Digital)
by diavolino 07/01/2023 12:33:12(UTC)
Capacitor installation for Loco Decoders/Dirty track? (Digital)
by 5HorizonsRR 25/11/2022 19:06:39(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
Coding button on old K64, K74 decoders (Digital)
by marklinist5999 10/03/2022 15:02:50(UTC)
M83 decoders (Digital)
by Don Morris 09/03/2022 03:53:15(UTC)
Piko Light Strips/Decoders (Digital)
by obb1016 28/02/2022 16:33:43(UTC)
Using 6080 or 6090 chips as pure function decoders- possible? And ground? (Digital)
Belarus 5HorizonsRR 25/02/2022 02:22:11(UTC)
Programming/Reprogramming MSD3 decoders (Digital)
by JDennis 25/01/2022 02:48:23(UTC)
Programming Decoders -- Several (or more) questions (Digital)
by JDennis 20/01/2022 21:17:53(UTC)
Digital decoders from Decoderwerk (H0-scale)
by Gunnar 17/12/2021 13:49:38(UTC)
by Gunnar 22/11/2021 13:18:31(UTC)
Turnout decoders (General MRR)
by Christo Swanepoel 17/11/2021 06:25:18(UTC)
Reprogramming Factory fitted decoders (Digital)
by Bigdaddynz 25/08/2021 10:45:47(UTC)
Loading two M83 decoders into a CS3 connected together (Digital)
by marklinist5999 04/07/2021 17:20:17(UTC)
Upgrade decoders via CS3? (Digital)
by Goofy 03/02/2021 18:38:48(UTC)
CS3 with Massoth 8156101 switch decoders (Digital)
by Railman 28/12/2020 15:01:32(UTC)
What is the difference between Marklin 60949 and 60979 decoders (General MRR)
by rustya 22/10/2020 17:20:03(UTC)
Problem with sound decoders 60975, 60976, 60977 (Digital)
by Best Ripper 17/09/2020 21:11:02(UTC)
List for decoders (Digital)
by DB Fan 03/08/2020 05:31:30(UTC)
Digital locomotive decoders (Digital)
by Nibelungen 23/06/2020 13:22:37(UTC)
How to program CV decoders with Arduino ? (Digital)
by Gerald_Litzistorf 14/05/2020 09:54:14(UTC)
Decoders available for the 6021 (Digital)
by Rocca 10/05/2020 12:23:30(UTC)
DCC decoders full speed reverse after short circuit of programming track (Digital)
by Martin T 02/04/2020 22:55:07(UTC)
Mfx Sound decoders having random ANNOYING issues (Digital)
by Martin T 02/04/2020 22:27:32(UTC)
Programing Decoders (Digital)
by lvfocus 12/03/2020 19:02:43(UTC)
Cost-effective decoders (General MRR)
by Thewolf 28/02/2020 13:54:50(UTC)
Marklin new DCC 74461 decoders (Digital)
by rhfil 10/02/2020 19:35:28(UTC)
ESU will soon release new lokpilot decoders V 5.0 (News from Märklin and others)
Belarus river6109 09/01/2020 14:24:40(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
14/28/126 Driving Steps for Decoders (Digital)
by cajaeger 23/10/2019 11:55:28(UTC)
This page was generated in 0.498 seconds.
