Offline Macfire
#1 Posted : 21 January 2007 10:09:29(UTC)
Macfire
Hi all.
Just thought I would pass on a small trap that I experienced when wiring up the turntable.
I am setting up a C (with some K) Track layout and have been flat out wiring up the points and uncouplers with signals to come. Cheaper and more fun than digital in my mind.
Anyway came time to wire up the turntable and I followed the instructions religiously
The turntable worked fine but the track feed failed once the turntable was turned away from the main line.
I rechecked all the wiring which was fine so before giving up and sending an SOS, I had a coffee break and went back under to retrace all the wiring.
Found the fault - ME!
I had connected the track feed to the accessories transformer!
Why? Because all the other wiring I had done up to that stage had been connected to that transformer as well!
[:I][:I][:I]
Lord Macca
Offline Philip
#2 Posted : 21 January 2007 12:21:15(UTC)
Philip
Is it just wonderful,when the problem just kinde of solved it selv after a good cup of coffee.
It gives, at least me, a burst of self confidens.
Best of luck with the rest of the wiring.
Philip Smile
Philip.
Let's keep it simple.
MFDWPL
Offline HueyCE
#3 Posted : 21 January 2007 21:58:23(UTC)
HueyCE
I think we have all been there, you just get into a routine and sometimes it's difficult to break out of it right away. Doing a self QA is always a good idea.
Ira
7286 Turntable (Digital)
by BenP Yesterday at 15:31:36(UTC)
How the 7286 turntable actually works... (H0-scale)
by DaleSchultz 14/08/2025 04:57:05(UTC)
Upgrading the 7286 turntable (H0-scale)
by DaleSchultz 14/08/2025 04:48:05(UTC)
Marklin 7286 turntable voltage problem (H0-scale)
by Dirtboy 26/01/2025 00:23:25(UTC)
Marklin 7286 Turntable (H0-scale)
by guardman1 15/07/2024 01:27:14(UTC)
Alterative controller for Marklin 7286 turntable (General MRR)
by rustya 02/05/2023 02:19:02(UTC)
Advice needed for Marklin 7286 Turntable (H0-scale)
by marklin61 20/07/2022 00:48:22(UTC)
7286 Turntable activates empty shed contact tracks. (H0-scale)
by luckas 15/06/2022 11:02:54(UTC)
7286 Turntable motor straining and power question (Digital)
by luckas 15/04/2021 13:47:40(UTC)
7286 turntable with LDT TT-DEC - CS2 step turn doesn't work properly (Digital)
by applor 29/12/2020 22:56:15(UTC)
Marklin 7286 Turntable Woes (H0-scale)
by compatty 22/12/2020 13:06:13(UTC)
Intellibox, 7286 Turntable & 7687 decoder (General MRR)
by jbblunck 25/11/2019 19:11:26(UTC)
by springboard 15/11/2019 23:30:10(UTC)
Marklin 7286 turntable track height issue and no stepping (H0-scale)
by applor 17/04/2018 01:55:15(UTC)
by Twisterdodger 11/10/2017 18:57:18(UTC)
Marklin 7286 Turntable & C Track (General MRR)
by chrisisrang 04/10/2017 01:51:24(UTC)
Märklin 7286 Turntable (Digital)
by Cargodog 31/05/2017 13:22:31(UTC)
Connecting 7286 turntable to 7687 decoder and CS2 (Digital)
by sgbrail 09/08/2016 22:34:10(UTC)
7286 turntable coil question (Digital)
by Hackcell 04/04/2016 21:31:20(UTC)
Problem with a Märklin 7286 Turntable (H0-scale)
by Brakeman 24/01/2016 01:45:23(UTC)
7286 turntable (Digital)
by Alexwaning 17/10/2015 14:51:02(UTC)
Parts for 7286 Turntable (General MRR)
by Shamu 02/09/2015 03:42:46(UTC)
7286 turntable do I need 7687 (Digital)
by jlopez 22/06/2015 00:14:25(UTC)
7286 Turntable. (Digital)
by charles Sharpe 03/03/2014 14:27:08(UTC)
7286 turntable with sound? (Digital)
by Hackcell 14/02/2014 21:37:03(UTC)
Trouble configuring 7286 Turntable with ECoS 50200 using 7687 Decoder (Digital)
by Richard_Pymble 01/09/2013 08:35:34(UTC)
Marklin 7186 & 7286 Turntables (H0-scale)
by trainsman2001 27/02/2013 19:01:18(UTC)
Anyone Played Around with the 7286 Turntable? troubleshooted one? (H0-scale)
by 5HorizonsRR 20/04/2010 00:37:20(UTC)
7286 Turntable pit depth? (H0-scale)
by Writhdar 12/04/2009 17:59:39(UTC)
Reposting: 7286 Turntable with 7.5 deg spacing (General MRR)
by jvuye 17/01/2009 12:44:55(UTC)
Marklin 7286 turntable. (H0-scale)
by steventrain 23/03/2008 11:34:44(UTC)
Manual for 7286 turntable (H0-scale)
by huttel 09/09/2006 18:47:02(UTC)
7286 Turntable problems (Digital)
by obb_taurus 15/08/2006 18:31:39(UTC)
7286 Turntable and decoder problems (Digital)
by obb_taurus 22/06/2006 18:00:59(UTC)
Programming 7286 Turntable + Intellibox (Digital)
by obb_taurus 04/06/2006 19:17:56(UTC)
What's up with the 7286 turntable? (H0-scale)
by Martin T 24/01/2006 15:19:28(UTC)
7286 turntable internal wiring (H0-scale)
by Mikael 23/09/2005 17:48:59(UTC)
Digital Decoder for 7286 turntable (Digital)
by robertrt 17/07/2005 01:19:24(UTC)
How to - 7286 Turntable (H0-scale)
by Eisenhower 10/02/2005 19:57:46(UTC)
Broken 7286 turntable (H0-scale)
by RDRBerry 31/03/2004 02:48:06(UTC)
This page was generated in 0.233 seconds.
