Offline trevp104
#1 Posted : 01 November 2025 12:37:01(UTC)
trevp104
Hi guys.
I am using a CS3 plus and while running trains last night I had my Croc stop on a dirty track and another loco ran into it and caused a derailment. I had the usual overload icon on the screen, I hit the stop and got everything sorted out. When I went out of the stop mode I still got the overload warning. As it was quite late I shut down the CS3. When I switched on this morning I still get the overload warning. I checked that all loco's and rolling stock where sitting on the track properly and still the problem persisted. I have now disconnected everything from the rear of the CS3 and have only the power supply plugged in, so no connection to the layout at all but as soon as I go out off the stop mode the overload warning returns. I think the CS3 itself has done a dirty on me.
thanks 1 user liked this useful post by trevp104
#2 Posted : 01 November 2025 14:30:36(UTC)
Hi Trev
So your CS3 is stuck in Stop mode while all is disconnected except the power supply
You may have jammed the STOP button which presses on a microswitch directly soldered on the mother board.
What can you do?
- make sure the STOP taste is not jammed down (does it have its regular play between the UP and the down position. On a CS2 I had a STOP taste jammed and I had to unjam it.
- connect to "Tante M" using internet to fetch for the last s/w version. In some cases it may clean files and solve the issue (get a new GFP (GleisFormatProcessor)
- as a last resort, if the CS3 is not under warranty anymore (2 years after purchase) you may try to open it to check if a plastic part is broken. You need a long Torx wrench and go pasdt the warranty seal
I never opened my CS3 but intervened on my CS2 (almost the same casing and probably a similar shape for the mother board).
On the mother board there is another plastic part to interface with the surface-mounted device switch Here it is (part view of a 60215 motherborad rear side)
NOTE: Märklin will NOT sell any inside spare part so either you repare it (glue broken plastic part, replace the SMD switch if falty with proper SMD soldering station (hot regulated temperature air) or you send it to repair in Germany.
All the above is IF the STOP button does not work.
If the short detection is faulty reload the S/ and make sure the programmed power supply in you CS3 MATCHES the reality (It changes sometimes mostly after an update)
Offline trevp104
#3 Posted : 01 November 2025 14:44:41(UTC)
trevp104
Hi Johnjean, thank you for your reply. there is movement on the stop tab, it does not seem to stuck. I never use the tab to activate the stop but use s mouse and click on the stop icon. I have in the meantime checked for updates and found that there where updates available. I did the updates and now when I switch on and go out of the stop nothing happens and no longer get the overload warning but nothing works on the layout.
#4 Posted : 01 November 2025 14:46:06(UTC)
Not quite true. I managed to break the clear plastic part in the above photo, on one of my cs2 units. I took a photo of the broken part and sent an email with the photo attached to marklin service, saying I found my stop bar didn't work and this is the reason. They wanted me to send the whole cs2 back for repair, but i protested that the fault was obvious and I didn't see a need to go to that expense. They eventually sent me the plastic piece gratis.
Offline BenP
#5 Posted : 01 November 2025 15:23:18(UTC)
BenP
Test cs3 stop button functionality by holding it down for ten seconds, which activates shutdown procedure (and bootup when powered). Make sure red alert window is gone (click X).
B
Ben van der Pluijm--
#6 Posted : 01 November 2025 15:36:31(UTC)
Double check if the type of power supply entered on the CS3 has not changed. If incorrect it may trigger an overload situation
Online David Dewar
#7 Posted : 01 November 2025 21:08:38(UTC)
Have you removed the trains that caused the problem and checked all other trains and coaches on the layout. Also try just using the programme track. I am not sure the CS3 is the problem.
Marklin cs3 plus error overload (Digital)
by Adrian666 05/04/2025 14:38:20(UTC)
Problems with S88AC and CS3 Plus (Digital)
by sanjiv 10/03/2025 12:02:30(UTC)
Question regarding cs3 plus (Digital)
by Adrian666 23/01/2025 07:00:17(UTC)
CS3 Plus Programming Track - Read DCC won't update in browser (Digital)
by WC Model Railroad 16/01/2025 02:00:23(UTC)
Screen protector for CS3 plus. (Digital)
by Bryan 17/10/2021 12:29:43(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
Item List on CS3 plus (Digital)
by MDMX2057 06/03/2021 13:40:08(UTC)
Copy data from CS2 to CS3 plus (Digital)
by gachar001 24/02/2021 07:15:23(UTC)
Marklin CS3 Plus sending 24V to the track (H0-scale)
by MooMooHolyCow 23/02/2020 02:30:23(UTC)
Recording with the CS3 Plus (Digital)
by David Dewar 23/11/2019 16:44:56(UTC)
CS3 PLus and CS2 (Digital)
by David Dewar 29/06/2019 14:44:31(UTC)
Technical Support for the CS3 plus (Digital)
by John Ferguson 05/03/2019 16:57:58(UTC)
CS3 plus (Digital)
by eurotrain 21/01/2019 17:37:48(UTC)
CS3 Plus and S88 (Digital)
by David Dewar 03/01/2019 20:24:11(UTC)
CS3 Plus event (Digital)
by David Dewar 01/01/2019 14:35:42(UTC)
CS3 Plus S88 (Digital)
by David Dewar 15/11/2018 15:35:54(UTC)
CS3 plus - Problems (Digital)
by jeanmomo 06/11/2018 11:17:02(UTC)
Elements within an event for the CS3 plus (Digital)
by John Ferguson 05/10/2018 18:29:16(UTC)
Backup files for the CS3 plus (Digital)
by John Ferguson 26/09/2018 20:10:08(UTC)
Network access for the Central Station CS3 plus (Digital)
by John Ferguson 08/09/2018 16:51:41(UTC)
RocRail softCentral Station CS3 plus (Digital)
by John Ferguson 29/08/2018 15:15:29(UTC)
CS3 Plus, Decoder m83 60832 and Control 60821 (Digital)
by Vipe 31/03/2018 20:57:19(UTC)
CS3 Plus Control with Win 10 on Desktop PC (Digital)
by leistef 05/03/2018 20:46:16(UTC)
CS3 plus and S88 (Digital)
by David Dewar 27/01/2018 15:19:54(UTC)
CS3/CS3 plus and Märklin Digital 6021? (Digital)
by Ultimo 28/10/2017 21:25:46(UTC)
PC-connection for CS3 and CS3 Plus (Digital)
by siroljuk 16/12/2016 10:48:01(UTC)
CS3 Plus Review (Digital components and Software reviews)
by bugsmasher 20/11/2016 03:05:11(UTC)
CS3 plus and booster 60174 (Digital)
by MSanches 10/11/2016 20:26:54(UTC)
CS3 Plus 60216 (Digital)
by Steamer01 25/10/2016 08:46:16(UTC)
CS3/CS3 Plus Delivery Dates (News from Märklin and others)
by bugsmasher 08/09/2016 05:33:07(UTC)
Difference between CS3 and CS3 plus (Digital)
by shannon 30/04/2016 12:30:25(UTC)
Which is worth to get one...CS3 or CS3 plus? (Digital)
by Goofy 21/01/2016 09:26:11(UTC)
This page was generated in 0.364 seconds.
