Offline Spring
#1 Posted : 20 February 2025 02:33:51(UTC)
Spring
I just signed up for Märklin-users today with one question in mind. I have a starter M track set from the 1970s with an oval, loco and two gondolas. I'd like to add an extension set 5191 (with electric turnouts). One I'm looking at on eBay has no instructions but otherwise likes O.K. I've scoured the Internet for a PDF or anything of the sort and now I'm here. Can someone point me to such a PDF or a link to what I'm looking for?
I don't know if I'm doing this correctly but you folks look friendly and will surely set me straight if I'm doing it wrong.
Thank you
Steve
Offline mvd71
#2 Posted : 20 February 2025 04:05:34(UTC)
Hi Steve,
What do you need a pdf for? The set will work nicely with your starter set, and they are easy to set up.
Cheers….
#3 Posted : 20 February 2025 04:47:50(UTC)
You can find pdf manuals for turnouts and some signals in this thread - 5117/5202 (Post #2):
https://www.marklin-user...ns---requested-documents
I would also recommend you download and read the Eckert Engineering book (Post #3). There may be others that will help such as the 0340 signal manual, feel free to download whatever you need.
Offline TrainIride
#4 Posted : 20 February 2025 08:20:31(UTC)
TrainIride
my two cents :
Best Regards
Joël
Edited by user 20 February 2025 12:11:48(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by TrainIride
Offline TrainIride
#5 Posted : 27 February 2025 08:51:58(UTC)
TrainIride
Thank you
Steve
Hi Steve,
Any feedback ?
Did we help you well ?
Did you purchase your set ?
Best Regards
Joël
Offline Spring
#6 Posted : 03 March 2025 21:43:41(UTC)
Spring
Joël et al,
My 5191E arrived this afternoon. It didn't have instructions so I printed your images and went to see what I could do. I plugged things in the best I could. The locomotive runs. A little light on the turnout lights up. Pushing the buttons on the 7072 does nothing. But I'm missing a connection somehow. My transformer only has three terminals, brown, red and yellow labeled O, B and L, respectively (hard to read). I'm running wires from the brown and red to the feeder track and the yellow to the 7072, as in your picture. It looks like I also need to run a brown wire to the end of the 7072. Do I need another 7209 and some more wire to conned the transformer's brown terminal to both the track and the blue box? (I see them for under USD 10.00 on eBay.)
Thanks to all for your advice! In the meantime
Steve
PS Here's a link to the other instructions I found--
thanks 1 user liked this useful post by Spring
Offline DB Fan
#7 Posted : 04 March 2025 02:17:05(UTC)
DB Fan
Yes you can use the 7209 or any other distribution block to connect the brown wire to it and then run the brown wire from there to the track and to 7072.
Robert
thanks 1 user liked this useful post by DB Fan
Offline Spring
#8 Posted : 04 March 2025 17:39:18(UTC)
Spring
Thanks, Robert! I'm heading to eBay now.
#9 Posted : 05 March 2025 16:37:41(UTC)
My 5191E arrived this afternoon. It didn't have instructions so I printed your images and went to see what I could do. I plugged things in the best I could. The locomotive runs. A little light on the turnout lights up. Pushing the buttons on the 7072 does nothing. But I'm missing a connection somehow. My transformer only has three terminals, brown, red and yellow labeled O, B and L, respectively (hard to read). I'm running wires from the brown and red to the feeder track and the yellow to the 7072, as in your picture. It looks like I also need to run a brown wire to the end of the 7072. Do I need another 7209 and some more wire to conned the transformer's brown terminal to both the track and the blue box? (I see them for under USD 10.00 on eBay.)-
NO! You need to run only a BROWN to the 7072. No yellows to that box...
You probably dont need any more 7209´s, if your plugs have a hole in the side, where you can insert an additional plug.
The only 7209 that you have, should probably be used for the yellow wires.
Roco digital crane magnet instructions wanted (Digital)
by patnaik 22/01/2025 21:16:55(UTC)
410 Turntable Instructions, please (H0-scale)
by PL21 02/05/2024 12:57:05(UTC)
cannot find Instructions br45 (H0-scale)
by heinrichhess 07/08/2023 13:59:37(UTC)
Z scale 8589 wiring instructions (Model railroad wiring)
by hennabm 18/09/2022 14:54:35(UTC)
MS2 29000 - Instructions?! (Digital)
Belarus Michanglais 22/04/2022 09:56:37(UTC)
ESU sound decoder instructions (H0-scale)
by river6109 07/12/2021 11:36:41(UTC)
ROCO 46093 Cement silo Wagon Instructions (H0-scale)
by Timnomads 29/08/2021 11:16:26(UTC)
F800/3026 loco instructions (H0-scale)
by alebozzo 12/06/2020 02:23:17(UTC)
German translator needed - Weinert instructions (General MRR)
by applor 12/02/2020 06:27:12(UTC)
3023.2/3923 Instructions manual and Marklin versus Hamo (Collector's Corner general)
by mbarreto 03/12/2019 13:17:15(UTC)
Lux Track Clean Set - Instructions & default address? (H0-scale)
by cookee_nz 19/07/2019 04:41:12(UTC)
Noch Cortina Layout Wiring Instructions (Small scale)
by Bob24 09/03/2019 07:53:36(UTC)
instructions for installing the couplings marklin 2681 (H0-scale)
by Hank1027 05/03/2019 19:11:27(UTC)
3338 Instructions manual (H0-scale)
by mbarreto 02/02/2019 16:51:04(UTC)
MFX+ locomotives "World of Operation" Instructions (Digital)
by steventrain 16/12/2018 15:31:21(UTC)
Need Older Marlin Instructions/Manuals (H0-scale)
by rg1911 27/11/2018 23:05:27(UTC)
Need english instructions for Trix/Marklin Entertainment car (Trix 23490) (Digital)
by Fredashay 02/03/2018 01:16:12(UTC)
Instructions For installing 56101 couplers? (Big scale)
by SteamBob 14/06/2017 00:27:50(UTC)
Question - looking for ESU 31255 instructions (H0-scale)
by Mike M 25/01/2017 01:56:43(UTC)
Marklin 6032 programmer instructions (Digital)
by gcanton 09/01/2017 14:44:46(UTC)
grandmother found set without instructions (Digital)
by bembo 24/06/2016 15:41:56(UTC)
Faller Instructions (Faller collectibles and other vintage accessories)
by nzr1 23/03/2016 01:38:23(UTC)
Märklin Start up 36243 H0 wiring instructions (Model kits & layout details, kitbashing and such)
by arjanvandriel 18/03/2016 19:43:25(UTC)
LGB Catalogue + various other instructions (Collector's Corner general)
by NewMB 10/03/2015 15:03:18(UTC)
Instructions for 4370/4371 (Digital)
by klafleur3 05/12/2014 16:59:46(UTC)
6 pin cable for Marklin 7686 Digital turntable needed and instructions (Digital)
by klafleur3 29/08/2014 14:31:56(UTC)
MS1 Instructions (Digital)
by nevw 04/08/2013 05:47:39(UTC)
Marklin Instructions for Locomotive 3050 and 3016 (H0-scale)
by kumarvartak 25/05/2013 10:54:04(UTC)
Instructions for Marklin Locomotive 3048 (Collector's Corner general)
by kumarvartak 25/04/2013 12:38:33(UTC)
Database for Manuals and Instructions (General MRR)
by PMPeter 16/04/2013 05:03:28(UTC)
Need instructions for 78100 Test Stand, AND what IS this ?? (H0-scale)
by MarklTedII 07/04/2013 21:29:56(UTC)
MARKLIN and INSTRUCTIONS failing Grade (General MRR)
by Hoffmann 08/03/2013 19:35:13(UTC)
Central Station 60215 instructions book (Digital)
by mattj70 25/02/2013 23:53:40(UTC)
Marklin Locomotive 3048 Instructions Manual (General MRR)
by kumarvartak 20/02/2013 09:56:49(UTC)
Instructions for faller kit #901 -stadt (Model kits & layout details, kitbashing and such)
by Robyn Boyd 25/12/2012 23:21:44(UTC)
7192 Electric Level Crossing Instructions please (Collector's Corner general)
by cookee_nz 09/12/2012 22:44:34(UTC)
Delta 6604 control installation instructions (H0-scale)
by Tim West 12/10/2012 06:49:50(UTC)
Marklin Instructions and service sheets (Collector's Corner general)
by kumarvartak 20/09/2012 10:40:19(UTC)
Instructions for marklin 3001 locomotive (H0-scale)
by joyofmarklin 19/08/2012 20:28:57(UTC)
english instructions for ESU CS1 update (Digital)
by marklinologos 12/07/2011 12:13:57(UTC)
Marklin 5516 instructions (Big scale)
by gcanton 15/06/2010 02:16:05(UTC)
Instructions for 74460 + 6040 (Digital)
by phyan 14/05/2010 12:47:54(UTC)
instructions for vintage marklin whistle (Collector's Corner general)
by drstapes 21/03/2010 04:58:59(UTC)
6021 instructions (Digital)
by dsphoto 06/02/2010 19:35:10(UTC)
C81 decoder instructions (Digital)
by scraigen 23/07/2009 02:38:51(UTC)
Programing instructions (Digital)
by sudibarba 23/01/2008 04:54:31(UTC)
ESU Decoder Instructions (Digital)
by Frostie 20/04/2007 04:50:07(UTC)
Searching for instructions (Digital)
by dntower85 06/11/2006 02:05:55(UTC)
Lokpilot instructions in English (Small scale)
by elsleuth 19/03/2005 17:59:37(UTC)
Marklin 5214 instructions (H0-scale)
by harrisonc 22/02/2005 03:55:10(UTC)
This page was generated in 0.443 seconds.
