Offline marcelltrain
#1 Posted : 04 December 2021 07:48:47(UTC)
marcelltrain
CS3+ crash when I click Mapping or after open Configuration click any icon of function on left screen
#2 Posted : 04 December 2021 10:01:59(UTC)
I don't know what is wrong with it. Take it to Micro macro mundo in Miami.
Did you buy it from them? Is it crashing when you don't try mapping, but just operating?
#3 Posted : 05 December 2021 08:31:21(UTC)
How can a CS3+ crash when you start open mapping or configuration?
When you start click any button on the mapping or configuration the system shuts down?
A question...do you have older mfx locomotive on the track?
It could be this problem which disturb system.
You have to leave the CS3+ to Märklin service.
Do you have still warranty?
Offline Copenhagen
#4 Posted : 05 December 2021 12:15:29(UTC)
Copenhagen
I have a CS3 but I'm no expert. It's possible to make backups to a USB stick and then you can try to reset it or update it via an ethernet cable to your router (or switch) or a combination of these things. The backup can then be reloaded (unless the fault lies within the backup data).
Offline reink
#5 Posted : 07 December 2021 02:15:38(UTC)
reink
My new CS3 has been crashing. I can not see any pattern to it. Sometimes it crashes, other times it freezes and I can only recover by cutting power. I have sent it in to Marklin repair, but I fear they will not see the problem because it is so erratic.
JPH
thanks 1 user liked this useful post by reink
Offline PeFu
#6 Posted : 07 December 2021 05:40:29(UTC)
PeFu
I had some similar issues with my CS2 which is feeded by a Märklin 60061. The problems started after adding a Märklin 60175 booster having a different power feeder. On some forums, I found recommendations to use the same kind of power feeder for the CS2 and all boosters. When exchanging the power feeder for a 60061, everything was great again.
#7 Posted : 07 December 2021 05:46:21(UTC)
And i am disapointed at Märklin who has bad service.
They have service at link by writing to them but the answers takes so long time.
Not many who use CS3 knows about the problems appears and how to fix the problem.
I too did have some issues with the CS3.
#8 Posted : 07 December 2021 09:58:34(UTC)
Peter, if Marklin has it, trust they will fix or replace it under the warranty!
A neighbor has a new vehicle, and the dash screen has gone dead twice.
The dealer has it now again, and I suspect these are chip related issues in your case too. The i.c. chip shortages or defective ones. A resin supply shortage is also affecting the medical device supply chain.
Offline Joakim_B
#9 Posted : 07 December 2021 15:19:13(UTC)
Joakim_B
Hi all.I had some issues as well with my CS3+ (Black screen and so) and just like "Copenhagen" I successfully could reset and reinstall all via the WEB access service (remote control)
#10 Posted : 07 December 2021 16:45:36(UTC)
What size power supply do you have and what size power supply is the cs3 configured to expect. If you have it configured to use the high power supply but you use a lower power supply then this can be a symptom.
60VA v 100VA for CS3+ (Digital)
by BenP 28/06/2025 22:50:45(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
DIY Boosters for CS3?? (Digital)
by BenPerr 03/05/2025 04:37:38(UTC)
Setting Up Märklin 76393 Signals with CS3 and C-Track (Digital)
by tgj 27/04/2025 16:29:13(UTC)
Marklin cs3 plus error overload (Digital)
by Adrian666 05/04/2025 14:38:20(UTC)
IP address of two CS3+ (Digital)
by Capitole 03/04/2025 09:43:46(UTC)
CS3+ with a CS3 slave (Digital)
by rhfil 21/03/2025 22:53:17(UTC)
Loco Images on CS3 (Digital)
by garben 14/03/2025 16:40:31(UTC)
Cs3 connection to 12AWG main bus (General MRR)
by Puttputtmaru 11/03/2025 22:27:01(UTC)
issue with locos that doesn't stop on cs3+ (Digital)
by Adrian666 11/03/2025 13:31:25(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
Problems with S88AC and CS3 Plus (Digital)
by sanjiv 10/03/2025 12:02:30(UTC)
Problemer med digital dekoder på CS3 (Digital)
by tgj 03/03/2025 19:03:18(UTC)
Cs3 router (General MRR)
by Fred14305 24/02/2025 08:22:50(UTC)
Manual enter linked signals into the CS3? (Digital)
by Nick_40034 13/02/2025 10:22:05(UTC)
Any rumor about possible CS3 update? (Digital)
by jonas_sthlm 12/02/2025 11:05:25(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
Brand new engine from marklin but no icon on CS3 (Digital)
by Zeeboo04 31/01/2025 22:02:20(UTC)
How to register viessmann 5211 on cs3 (Digital)
by geir 25/01/2025 18:28:43(UTC)
Question regarding cs3 plus (Digital)
by Adrian666 23/01/2025 07:00:17(UTC)
Gleisbox-only operation (without MS2/CS2/CS3) - Testers wanted (Digital)
by osoraku 22/01/2025 11:46:45(UTC)
question regarding cs3 marklin 60216 (Digital)
by Adrian666 22/01/2025 09:35:13(UTC)
CS3 Plus Programming Track - Read DCC won't update in browser (Digital)
by WC Model Railroad 16/01/2025 02:00:23(UTC)
CS3 ,Windigipet 2018 (Digital)
by geir 13/01/2025 16:38:38(UTC)
CS3 track setting (Digital)
by rhfil 06/01/2025 17:15:16(UTC)
Printing Out CS3 Events (Digital)
by Al Thompson 01/01/2025 19:02:01(UTC)
CS3+ (Digital)
by greatrocks 15/12/2024 00:00:09(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
CS3 memory card slot (Digital)
by rhfil 20/11/2024 00:09:33(UTC)
Märklin has released downgrade today CS3/MS2 (Digital)
by jonas_sthlm 19/11/2024 16:45:24(UTC)
CS3 memory capabilities (Digital)
by rhfil 18/11/2024 18:53:45(UTC)
CS3 update 2.5.2 (Digital)
by rhfil 16/11/2024 12:42:28(UTC)
Ecos and CS3 via sniffer? (Digital)
by Goofy 15/11/2024 08:21:08(UTC)
Keeping track of locomotive run time on a CS3 (Digital)
by Keyser 03/11/2024 22:39:04(UTC)
Problem whit CS3 and M84 (H0-scale)
by Siluc94 03/11/2024 19:44:53(UTC)
CS3 MU setup (Digital)
by Kaspar 20/10/2024 17:43:42(UTC)
Manual Setting of Article Address on CS3 (Digital)
by JerryC 30/09/2024 05:58:57(UTC)
Can Marklin CS3+ connect with servo? (Digital)
by Solar007 27/09/2024 11:22:36(UTC)
Marklin CS3 remote control of CS3(not on home network) (Digital)
by EBro 22/09/2024 05:36:08(UTC)
Ecos and CS3 compatibility (Digital)
by JayMac 29/08/2024 02:55:26(UTC)
esu lokpilot 5 and CS3 (Digital)
by andrea_spv 02/08/2024 10:40:02(UTC)
CS3+ (Digital)
by Carlos 28/07/2024 17:16:04(UTC)
CS3+ (Digital)
by Mailme 11/07/2024 03:53:39(UTC)
How to configure Viessmann 5235 decoder with CS3 (Digital)
by obb_taurus 04/07/2024 17:41:01(UTC)
CS3/cs3+ update 2.5.2 (Digital)
by Flupke 22/06/2024 20:05:21(UTC)
MS2 vs CS3 (Digital)
by sfophx 16/06/2024 06:45:54(UTC)
dcc brake signals & marklin cs3 (Digital)
by fabstar68 12/06/2024 19:27:49(UTC)
Access icons on marklin cs3 v 2.5.2 (Model railroad software)
by Drese Alain 05/06/2024 09:18:07(UTC)
Stylus pen use with CS3 (Digital)
by Jasbir Singh 24/05/2024 04:33:59(UTC)
Automatic signals and braking without CS3 (Digital)
by intveltr 21/05/2024 02:48:31(UTC)
This page was generated in 1.027 seconds.
