Offline eurotrain
#1 Posted : 04 June 2021 18:58:52(UTC)
eurotrain
Help needed
I have 7 S88s placed around my layout. Last night I i jumped from the 3rd s88 that would be 3 and 16 to my 7th s88 7 and 1. I am using the CS3plus and traincontroller.
So my reed switch icon turns to yellow and my corresponding block turns to pink on trancontroller screen as it should My problem is that my actual reed switch will not activate the CS3 when it put my magnet to the reed switch.
What are my possible issues. Confused
#2 Posted : 04 June 2021 23:35:25(UTC)
I have no idea what this is trying to say:
Problem to register s88 (Digital)
by geir 26/09/2025 20:19:04(UTC)
Problems adding new contacts to S88Link (Digital)
by Dirtboy 03/04/2025 17:09:56(UTC)
Problems with S88AC and CS3 Plus (Digital)
by sanjiv 10/03/2025 12:02:30(UTC)
L88 to S88 cable type. (Digital)
by Luna 14/02/2025 15:50:27(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
Can one connect 2 S88 LINK (L88) units together, if so how (Digital)
by Condios 01/02/2025 14:11:48(UTC)
S88 error message (Digital)
by brauer.jim 27/12/2024 21:11:58(UTC)
60882 S88 DC for three Rail AC Operations (Digital)
by KennethH 23/12/2024 04:55:04(UTC)
S88 DC not powering train (Digital)
by morsing 15/12/2024 08:22:29(UTC)
Feedback modules S88 interfere? (Digital)
by Tjeerd 27/11/2024 16:53:14(UTC)
Problem with S88dc (Digital)
by As30157 22/10/2024 02:16:15(UTC)
Link s88 / Diode Trick / C & K Track (General MRR)
by Marklin Nut 12/10/2024 22:44:17(UTC)
Add a Digikeijs S88 DR4088xx after LINK88 on a CS3 (60226) (Digital)
by JeanClaudeMCH 16/05/2024 03:13:29(UTC)
S88 connection (Digital)
by mcs51 27/04/2024 12:59:18(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
S88 contact and Track Diagram CS3 (Digital)
by fvelazdem 13/11/2023 13:50:14(UTC)
CS2 : s88Link and Booster use same port : how do I connect them both ? (Digital)
by Johnvr 06/07/2023 13:04:58(UTC)
Train Controller Gold sees Blocks only on the Direct S88 (Model railroad software)
by punksie1 28/04/2023 21:49:51(UTC)
s88 link and cs3 (Digital)
by Thewolf 10/12/2022 23:17:22(UTC)
S88 Grounding (Digital)
by Bones 30/11/2022 11:09:53(UTC)
S88 60880 not working (Digital)
by craigericks 02/11/2022 01:09:06(UTC)
Cable extension from S88Link (60883) to cs2 (60215) (Digital)
by Thewolf 06/12/2021 23:19:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
S88 (Digital)
by eurotrain 28/07/2021 15:45:07(UTC)
CS3 adding S88 AC to Link S88 (Digital)
by luckas 12/05/2021 10:09:04(UTC)
Intellibox I 65000 S88 damaged. How to open it? (Digital)
by fje 01/05/2021 18:12:54(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
S88 bus-length CS3 changes automatically (Digital)
by Gustav 14/02/2021 09:03:52(UTC)
Digital software users: Is an LDT HSI-88 a must have for s88 feedback? (Digital)
by Roland 18/01/2021 04:03:46(UTC)
Checking the S88 60880 (Digital)
by biswasg 17/01/2021 18:08:46(UTC)
Contact Track, M-Track and S88 (Digital)
by Harvey 15/12/2020 01:19:00(UTC)
s88 sensor track placement (Digital)
by IBtrain 06/12/2020 06:29:16(UTC)
Faulty S88 module? (Digital)
by morsing 12/08/2020 19:52:50(UTC)
S88 (old) and CS2 - how do I get started? (Digital)
by hvc 16/06/2020 05:55:42(UTC)
CS3+ with Link S88 60883 (Digital)
by Demch 21/04/2020 20:23:53(UTC)
How I have solved the unstable s88 feedback (Digital)
by French_Fabrice 25/03/2020 23:08:18(UTC)
S88 DC Questions with LGB (Digital)
by ReelfootJim 24/02/2020 01:54:11(UTC)
Cs3 S88link (Model railroad software)
by Heinz 19/12/2019 21:23:22(UTC)
Adding 2- S88 to L88 (Digital)
by eurotrain 16/12/2019 14:32:17(UTC)
All s88's Yellow (Digital)
by Elsleuth1 12/12/2019 02:02:15(UTC)
Link S88 (Digital)
by Drjoe11 10/11/2019 15:53:33(UTC)
Connecting a 3rd S88, L88 involved - help! (Digital)
by johnpatrickwack 05/11/2019 22:29:54(UTC)
Problem with S88 ac (Digital)
by geir 27/10/2019 19:11:04(UTC)
S88AC and S88DC (Digital)
by mgbeck_98 05/09/2019 21:50:01(UTC)
L88/S88 - Events no longer work? NOW SOLVED (Digital)
by petestra 24/07/2019 13:20:15(UTC)
S88 sensor flickers with power applied (Digital)
by applor 24/03/2019 02:09:25(UTC)
Advise on S88 feedback modules (Digital)
by IBtrain 14/03/2019 16:23:11(UTC)
CS2 S88 problem (Digital)
by Peter Claesson 05/02/2019 22:00:21(UTC)
L88 and S88 (Digital)
by Harvey 05/02/2019 21:32:53(UTC)
CS3 Plus and S88 (Digital)
by David Dewar 03/01/2019 20:24:11(UTC)
This page was generated in 0.389 seconds.
