Offline eurotrain
#1 Posted : 21 January 2019 17:37:48(UTC)
eurotrain
I finally went to replace my CS2 and install my new CS3 plus to my layout and when I plugged it in, nothing happened. No power to my boosters etc. CS2 works fine and now I think I have the wrong power to the new CS3. So when I look at the available switched mode power, lots of different numbers but nothing to point to the one that should be with the CS3 in the good old USA.
Anyone have the definitive number to use?
Offline kgsjoqvist
#2 Posted : 21 January 2019 17:59:52(UTC)
kgsjoqvist
60065 is the item number you are looking for, it’s 60 VA and for 120 V. CS3 don’t work with AC transformer, but needs a switched DC supply.
#3 Posted : 21 January 2019 18:41:49(UTC)
There is a new power supply ( 60045 ) for the American market in the new items 2019. Alas no delivery date is available yet.
It is accepting any voltage from 110V till 240V 60W and suitable for the US market
It seems that the 60065 was delivering only 50W and for some users it was causing the CS3 to reboot.
Definitely a Marklin transfo even with the same connector is not usable because of pin assignements & capacity to convert AC to DC.
#4 Posted : 21 January 2019 19:29:04(UTC)
Right at the front of the manual for the CS3 it clearly tells you:
A quick check on the Märklin website shows the 60061 is for 240v and the 60065 is for 120v, (all assuming your running H0) - sot he 60065 is the north american 120v solution.
There are new power supplies that came out in the new items 2019 catalog, which isn't out yet, if the color matters to you (60045), but the 60065 is still just fine.
Offline Drjoe11
#5 Posted : 03 February 2019 18:14:10(UTC)
Drjoe11
Hi All:
I need help!. I just received the new starter set 29051, and a new CS3+. It registered the MFX engines AOK. When I register an old digital engine, for example a 33182, I get the correct digital address, it how the engine, but I cannot get it torun. What did i do wrong? Or, did I not complete all of the steps to register the engine. I have the CS3 book, but I think there is some information missing on how to do this. I have 6 more older Marklin digital engines I need to register. Any help would be greatly appreciated. Joe
#6 Posted : 03 February 2019 18:19:34(UTC)
Originally Posted by: Drjoe11 Go to Quoted Post
Hi All:
Has the 33182 been converted to digital, or is it delta?
If it is Delta then you should be able to find it in the loco database by searching for 33182.
The same would go for the other locos if they were originally digital or delta items.
Offline Drjoe11
#7 Posted : 03 February 2019 22:37:02(UTC)
Drjoe11
I finally figured it out. It seems one of the power wires to the C track came loose. SO nothing worked. Thanks for the help it is greatly appreciated
Offline TEEWolf
#8 Posted : 04 February 2019 01:39:58(UTC)
For registering locos the manual form Märklin's homepage will help better than the book. Anyway, are all your locos running now?
Offline Drjoe11
#9 Posted : 04 February 2019 13:42:41(UTC)
Drjoe11
Everything is now running and the old Marklin Locos and the MFX locos are running great. I have trouble with one turnout decoder and I have 1 more loco to register. I think the turnout decoder is defective. Thanks for all the help and a quick response. Joe
thanks 1 user liked this useful post by Drjoe11
CS3 plus (General MRR)
by trevp104 01/11/2025 12:37:01(UTC)
Marklin cs3 plus error overload (Digital)
by Adrian666 05/04/2025 14:38:20(UTC)
Problems with S88AC and CS3 Plus (Digital)
by sanjiv 10/03/2025 12:02:30(UTC)
Question regarding cs3 plus (Digital)
by Adrian666 23/01/2025 07:00:17(UTC)
CS3 Plus Programming Track - Read DCC won't update in browser (Digital)
by WC Model Railroad 16/01/2025 02:00:23(UTC)
Screen protector for CS3 plus. (Digital)
by Bryan 17/10/2021 12:29:43(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
Item List on CS3 plus (Digital)
by MDMX2057 06/03/2021 13:40:08(UTC)
Copy data from CS2 to CS3 plus (Digital)
by gachar001 24/02/2021 07:15:23(UTC)
Marklin CS3 Plus sending 24V to the track (H0-scale)
by MooMooHolyCow 23/02/2020 02:30:23(UTC)
Recording with the CS3 Plus (Digital)
by David Dewar 23/11/2019 16:44:56(UTC)
CS3 PLus and CS2 (Digital)
by David Dewar 29/06/2019 14:44:31(UTC)
Technical Support for the CS3 plus (Digital)
by John Ferguson 05/03/2019 16:57:58(UTC)
CS3 Plus and S88 (Digital)
by David Dewar 03/01/2019 20:24:11(UTC)
CS3 Plus event (Digital)
by David Dewar 01/01/2019 14:35:42(UTC)
CS3 Plus S88 (Digital)
by David Dewar 15/11/2018 15:35:54(UTC)
CS3 plus - Problems (Digital)
by jeanmomo 06/11/2018 11:17:02(UTC)
Elements within an event for the CS3 plus (Digital)
by John Ferguson 05/10/2018 18:29:16(UTC)
Backup files for the CS3 plus (Digital)
by John Ferguson 26/09/2018 20:10:08(UTC)
Network access for the Central Station CS3 plus (Digital)
by John Ferguson 08/09/2018 16:51:41(UTC)
RocRail softCentral Station CS3 plus (Digital)
by John Ferguson 29/08/2018 15:15:29(UTC)
CS3 Plus, Decoder m83 60832 and Control 60821 (Digital)
by Vipe 31/03/2018 20:57:19(UTC)
CS3 Plus Control with Win 10 on Desktop PC (Digital)
by leistef 05/03/2018 20:46:16(UTC)
CS3 plus and S88 (Digital)
by David Dewar 27/01/2018 15:19:54(UTC)
CS3/CS3 plus and Märklin Digital 6021? (Digital)
by Ultimo 28/10/2017 21:25:46(UTC)
PC-connection for CS3 and CS3 Plus (Digital)
by siroljuk 16/12/2016 10:48:01(UTC)
CS3 Plus Review (Digital components and Software reviews)
by bugsmasher 20/11/2016 03:05:11(UTC)
CS3 plus and booster 60174 (Digital)
by MSanches 10/11/2016 20:26:54(UTC)
CS3 Plus 60216 (Digital)
by Steamer01 25/10/2016 08:46:16(UTC)
CS3/CS3 Plus Delivery Dates (News from Märklin and others)
by bugsmasher 08/09/2016 05:33:07(UTC)
Difference between CS3 and CS3 plus (Digital)
by shannon 30/04/2016 12:30:25(UTC)
Which is worth to get one...CS3 or CS3 plus? (Digital)
by Goofy 21/01/2016 09:26:11(UTC)
This page was generated in 0.406 seconds.
