Offline joyofmarklin
#1 Posted : 16 November 2018 22:50:01(UTC)
joyofmarklin
I am going to assemble my M track and have in the past had it on 2 folding tables approx 6' by 5' I have done a mainly oval shape with a second smaller oval crossing over the main one. I always end up with it not quite meeting. Thinking of getting some smaller track to fit better?
Any suggestions on a better method?
Also suggestions of what sort of fabric I should cover these tables with?
Any advice greatly appreciated? have youngster visiting for Christmas!!
Chris
thanks 1 user liked this useful post by joyofmarklin
Offline Chris6382chris
#2 Posted : 17 November 2018 03:10:55(UTC)
Chris6382chris
Chris
If you are using any of the Marklin Sectional track, like M Track you should be able to find the needed sections to make a larger outside circle M 5200 and then a smaller circle M 5100. You can achieve the cross over via one of the crossing or by using the curved or straight switches. If you having a problem with the tracks meeting up you could always try a free track planning software just to get a better understanding of the actual track sections you need.
If you are just doing a temporary Christmas display you could use one of the Woodland Scenic landscaping mats. They come in various sizes and could be made to cover a 6'x5' table.
thanks 1 user liked this useful post by Chris6382chris
#3 Posted : 17 November 2018 15:57:04(UTC)
joyofmarklin
Originally Posted by: Chris6382chris Go to Quoted Post
Chris
Many thanks for this advice, appreciated!!
#4 Posted : 17 November 2018 19:32:51(UTC)
joyofmarklin
Chris
Using a landscape mat got me thinking of building a lightweight frame, say of plywood that would sit on the tables. Then I could hide/ run the signal wires under it, to look neater. Any advice on best method to run these wires please? I read that Eckert engineering (Invaluable advise) advise a loom , but think that is for general lighting and not specific signals?
Any advice re construction of "tray" and wiring would be much appreciated?
Thank you
Offline SteamNut
#5 Posted : 17 November 2018 20:15:22(UTC)
SteamNut
Chris
Thank you
This is just a thought and I have not done it myself but perhaps glue the wires to the plywood. You can pencil were the wire should go first as a guide. It sounds like you are making a simple layout and it should not be hard to do - Fred
MrB32
#6 Posted : 18 November 2018 03:35:13(UTC)
Chris
Thank you
Careful!
A couple of thoughts more and you will be re purposing your living room into a permanent train room :) It is very easy to get carried away...
How many points and signals are you planning on using on your Xmas layout? Do you have lots of houses with lights and other decorative electrical knick-knacks? How much time do you have to build all this between now and xmas? How fast do you work? Are you planning on re using anything in the future?
Judging by your posts, I am assuming you are just looking at a one off setup, in this case a frame and loom may be over engineering in my honest opinion. On the other hand, if you a secretly thinking of making things more permanent/re usable in the same configuration, then this is the way to go... I am also assuming you are running everything in analogue mode.
I spend my time building and dismantling analogue m-track temporary layouts (I simply would get bored with a permanent layout... but I am digressing...). I start with an overall sketch with pen and paper, think about automation then move to track planning software. At that stage, I plan space for wiring on the surface of my folding tables. The fun starts after this stage, building!.
During the building stage, if there is one certainty, it is that anything you thought would take 1 day, will automatically take 3 to 4 times longer: there is always something missing you need to buy, a quick delivery promised by a vendor always turns to be very slow, some items that you thought would be readily available just happen to become unavailable at the time you most need them...
Regarding wiring loom, they is more of a permanent solution. Putting all wires together in a loom assumes that you will re use this loom in the same of a very similar configuration. Any drastic change will require you to add more wires to the loom, or worse run additional wires alongside it, defeating the purpose of the exercise... My last temporary "layout" was 8x15ft (22 points, 15 signals, 20ft ramp and bridge section, 300ft of track, 1 turntable, 1 transfer table and 1 crane... and catenary....). Even with that size, bearing in mind I use a feeder track every 5 to 6 ft of track, and the use of 300ft of cable, I got away with using a few (20'ish) stick-on cable holders (similar to these ones: Cable holders) on my folding tables. I just ran the majority of the wiring in 2 straight lines between parallel tracks along each side of the layout, and kept all wires together with these clips. I guess this arrangement could be covered with a mat to make it look neater, one "just" has to leave enough space between wires and tracks to keep things as level and stable as possible to avoid derailments...
I guess I am trying to say with this long blurb, that sometimes less is better:
The little ones visiting you will be happy racing trains as fast as possible on 2 parallel ovals or pressing buttons/turning dials, and see they can move objects by doing so. They'll also want to see derailments:)
What they won't notice are a few wires on show...
But if you are in the mood for a lot of work, there is an example of a permanent/re usable Christmas layout on m-track on YouTube (in german and in 5 episodes so far...), plenty of sawing, wiring, glueing etc etc....
#7 Posted : 19 November 2018 19:26:06(UTC)
joyofmarklin
Chris
Thank you
Careful!
Thank you so much for this much food for thought!!
#8 Posted : 19 November 2018 19:30:08(UTC)
joyofmarklin
May I see you layout perhaps?
Also are you suggesting I run the wires to the signals using these clips?
many thanks for your input.
Offline Michael4
#9 Posted : 19 November 2018 19:51:33(UTC)
Michael4
Just a thought, Railmodeller Express is a free software that works with Marklin M track on imac etc, I assume PCs as well. It is quite limited but will give you ideas as to how to do things. (RailModeller Pro costs money) Might save you hours of trying things out while lying on the floor!
If you need more 'M' track Ebay is the place to go though careful, some of it is rusty junk that has been trodden on by young feet.
MrB32
#10 Posted : 19 November 2018 21:17:05(UTC)
Yes, exactly that.
If you look at the picture (this is the large layout I mentioned in my post), the black lines represent where I ran the wires and attached them with clips. Signals, points and power cables mostly end up running along these black lines on the way to whatever item controls them. You could see that as a loom I guess, with the difference that cables are not permanently tied together, so you can add or remove stuff as the need arises. I think of it more like a collector.
If a signal is controlled by a switching track for example, and the switching track is not far away, then the cable goes directly there, unless there is a practical reason to go via the collector. Pretty simple :)
MrB32
#11 Posted : 19 November 2018 21:18:43(UTC)
The picture I just posted was made with RailModeller Pro on iMac :)
Michael, we need to meet :)
They don't offer a version on PC, but their customer service is very good (it is basically a one man shop, so you speak to the developer directly...)
#12 Posted : 20 November 2018 21:51:11(UTC)
joyofmarklin
Yes, exactly that.
Would
Many Thxs will let you know how I do!
#13 Posted : 20 November 2018 21:53:30(UTC)
joyofmarklin
Many thanks for this will pursue
#14 Posted : 29 November 2018 18:07:10(UTC)
joyofmarklin
Chris
Further advice sought please
If I convert my analogue loco to digital, info suggests that I can run it as an analogue loco provided I am using a new transformer ie white?
If that is correct can I also add analogue locos to the same m track and run them using switches etc? All controlled by the same transformer?
Also what do I need if I convert all my locos to digital. Believe I need a mobile station? Can I use the white transformer as its power source as I would also use it to control signals and switches.
Hope you can help?
MrB32
#15 Posted : 30 November 2018 03:18:12(UTC)
You can run digital locomotives on an analogue layout using a white transformer. Your locomotive will simply behave like another analogue locomotive on the layout. Functions might not be available depending on the decoder you decide to use.
Analogue and digital cannot run at the same time on the same track. In analogue mode, power to the track is increased or decreased as required to control the locomotive. In digital mode, the power to the track is at a constant voltage, and digital locomotives are listening to digital signals transferred from the controller over the track, so your analogue locomotives would simply run full speed in one direction with no way to control them.
You can isolate track sections of the layout to run analogue material on one side and digital on the other, with the evident risk of wrongly sending an engine on the wrong track, but in your case, it is unlikely to be possible based on your description of ovals crossing each other.
I would recommend the Traxeditor website for you to experiment with shapes and plan your layout on your computer. The address of the site is: https://www.traxeditor.com/. It is free and offers the entire M-track library. It is a good way to find out what shape could work.
To convert your locomotives you will need:
- a motor upgrade kit and decoder (there are several kits available for the majority of motor types on the Märklin website)
- a soldering iron and ancillaries.
- a set of small screwdrivers (like the Märklin 70900)
For digital control:
- a mobile station will not work with a white transformer out of the box.
- You'd have to buy a mobile station, a connection box, and a power supply.
- An option could also to buy a starter set and a couple of adapter tracks to connect the newer C-track to your M-track. The reference of the adapter track is 24951. This would be a relatively cheap way to familiarise yourself with the digital world before engaging in the conversion of your older locos.
- Your switches can be operated manually, and wired the old fashioned way, you can use your white transformer to power them (you need to ensure the only shared wire with your digital kit is the brown one, you might destroy the electronics in the digital locomotives otherwise).
Also:
A good track rubber, to ensure your M-track is clean. Digital operations rely on good connectivity, your old m-track might suffer from oxidisation at the moment.
Finally:
Spend a lot of time reading documentation, if you speak German, there is a good book called "(Wieder-) Einsteigen in die Märklin Modellbahn", as far as I know only available in German. There are also plenty of resources available online. ACJKIDS in the US has a good website, with plenty of "How do I?" or "How does this work?" type of articles in English, of course there is also this forum and good old Google...
#16 Posted : 30 November 2018 17:09:44(UTC)
joyofmarklin
Also:
Finally:
Thankyou so much for this extensive reply! Can you suggest a make of rubber (do i use it on the middle power pickup to?)and perhaps clips for the wires, as it has been suggested I run the wires under the track in case I change the layout? I will start using the track plan and will keep you posted.
MrB32
#17 Posted : 30 November 2018 18:04:54(UTC)
Track rubber (or rail cleaners in US English) all work more or less the same, Peco, Piko, Walthers, Woodland Scenics for example all offer these products.
I'd start with the rails, very lightly, just to get rid of the oxidisation. I only touch the middle contacts in when I find issues on a particular piece of track. Where you find rust, you'll have to go a bit harder.
You'll find the clips on ebay or amazon for example, just type cable clips in the search box. I would simply experiment with various arrangements once the layout is in place and go for the one that suits your circumstances (no clips, clips, cable ties, under track etc...). Nothing beats passing wires through drill holes and fixing the wires under the baseboard if you are doing something permanent.
#18 Posted : 30 November 2018 20:19:00(UTC)
joyofmarklin
Many thxs will do (and will have a cuppa, I'm a Brit too!)
MrB32
#19 Posted : 30 November 2018 20:23:53(UTC)
I am French, but like a cuppa :)
#20 Posted : 01 December 2018 00:36:45(UTC)
joyofmarklin
Merci mon fils habite en France!
#21 Posted : 04 December 2018 00:20:18(UTC)
joyofmarklin
I have seen somewhere turnouts numbered on small blocks. Where can I get these, so I can easily identify which turnouts correspond with my switches?
Suggestions please?
Thank you
MrB32
#22 Posted : 04 December 2018 13:27:19(UTC)
This is not longer produced by Märklin, but you can still find used sets on auction sites. The article number is 7195.
Offline waorb
#23 Posted : 04 December 2018 14:24:28(UTC)
waorb
Brazil
Hello!
I labelled my ones (turnouts and signals) with small tapes.
Label Printer
Walter
#24 Posted : 04 December 2018 15:07:20(UTC)
joyofmarklin
Once again thankyou ideal but where to find them MMM
MrB32
#25 Posted : 04 December 2018 17:09:18(UTC)
They turn up on eBay from time to time, sometimes as part of a lot with something M-track related.
The German name for it is "Nummernschild Garnitur"
Offline twmarklinfan
#26 Posted : 04 December 2018 18:14:53(UTC)
twmarklinfan
There are some on eBay. I found this item 273591635757 which is in the USA but the picture is of the right item but the description appears to be K track. Pricing for the item seems to be all over the place. I have a spare brand new in box set.
#27 Posted : 04 December 2018 20:03:07(UTC)
joyofmarklin
Many thxs will look at the ebay item you kindly found for me and report back
Chris
#28 Posted : 17 December 2018 00:32:41(UTC)
joyofmarklin
Help my white transformer has stopped working! The lights and turnouts work but no power to the track! My old blue transformer works though? The white transformer says it has a thermal cut out to protect it and resets itself. Any advice to get the transformer working. Stopped when some carriages derailed, they have lights in them.
Help plse?
Also:
Finally:
#29 Posted : 26 September 2020 21:18:06(UTC)
joyofmarklin
https://1drv.ms/v/s!AieVZl0I2-3dlneT6R2ZwLNV70Ba
Have finally made progress with my layout. Have added two outer C track, but will remain with M track!
Work in progress, as need to redo the ramp section and get my 6600 running smoothly.
Am indebted to the advice here and to Nicolas Boutinon for his patience and assistance.
thanks 3 users liked this useful post by joyofmarklin
Offline ocram63_uk
#30 Posted : 26 September 2020 23:24:30(UTC)
ocram63_uk
Cool layout, multiple trains running around!!! Like it very much :-)
#31 Posted : 27 September 2020 01:45:34(UTC)
joyofmarklin
Appreciated 😁
Guest (4)
Marklin 74043 signal wiring on digital layout (Model railroad wiring)
by kaybee6 18/01/2026 07:15:51(UTC)
Small Christmas Layout for 2025 (Collector's Corner general)
by mb300e4m 16/01/2026 17:04:40(UTC)
Huge Märklin layout in SC (Great layouts I have seen...)
by Dirtboy 15/01/2026 00:02:22(UTC)
Large layout in Ukraine (Great layouts I have seen...)
by 1borna 13/01/2026 20:59:04(UTC)
Small layout of a big man (Great layouts I have seen...)
by 1borna 19/12/2025 20:48:16(UTC)
Layout on wheels? (H0-scale)
by revmox 19/12/2025 04:04:08(UTC)
3 Rails DCC/Digital layout - AC/DC wheels (H0-scale)
by Rhode 18/12/2025 09:30:53(UTC)
Layout background (General MRR)
by mbarreto 09/12/2025 13:46:25(UTC)
Marklin catenary K track posts for C track layout (General MRR)
by egonzinc 13/10/2025 18:22:11(UTC)
LGB Train Set for Christmas Tree Layout (Big scale)
by AmalfiCoast 17/09/2025 03:20:49(UTC)
2025 Holiday M track Winter Layout Project (Great layouts I have seen...)
by 5HorizonsRR 12/09/2025 20:27:12(UTC)
US Aspect and Collections/Layouts/Display (General MRR)
by Jimmy Thompson 13/08/2025 17:20:06(UTC)
using both 67013 and 6701 on same layout (Small scale)
by wildstix 06/08/2025 10:41:11(UTC)
CS 1 for non Marklin layouts (Digital)
by Tuby 29/07/2025 00:27:50(UTC)
Display Layout on Perspex - 1968 - thoughts? (Collector's Corner general)
by cookee_nz 14/05/2025 12:04:04(UTC)
Märklin 36700 on analog layout? (Digital)
by Montignac 13/05/2025 11:03:16(UTC)
Can Märklin 6005 be used for analog layout? (Digital)
by rdn0609 03/05/2025 20:56:53(UTC)
Old passenger cars with interior lighting on digital layouts (Digital)
by Evergreen 21/04/2025 15:47:07(UTC)
First Layout Attempt – Seeking Tips & Suggestions! (H0-scale)
by omera60 03/04/2025 22:03:45(UTC)
Building my a digital Layout - Finally (Digital)
by White Buffalo 05/01/2025 22:03:21(UTC)
New Layout Using Marklin C Track (Track plans)
by Hewlett87 23/12/2024 17:28:53(UTC)
Curved Stations on a layout (Model kits & layout details, kitbashing and such)
by Jimmy Thompson 13/11/2024 13:10:56(UTC)
Gauge 1, does anyone in the UK have a gauge 1 layout. (Big scale)
by twmarklinfan 30/07/2024 16:54:25(UTC)
Looking for Pros in moving a Train layout in Montreal, Canada (General MRR)
by waterslip 26/06/2024 23:45:01(UTC)
My Z-scale layout (Small scale)
by einotuominen 15/06/2024 08:16:03(UTC)
Can't find decoder info to set up run on analog n layout. (H0-scale)
by icf1vvn 15/04/2024 22:24:51(UTC)
Freight train on my WIP z-layout (Small scale)
by einotuominen 16/03/2024 10:23:29(UTC)
Reading Maerklin layout plans. (H0-scale)
by biswasg 11/03/2024 22:19:46(UTC)
Controlling a second layout. (Digital)
by Model Railway shed D 23/02/2024 15:08:20(UTC)
Mobile station vs. Central Station - and new C track layout application (Digital)
by bpitchkites 19/02/2024 17:42:29(UTC)
Design of a layout in a tiny area (Track plans)
by Manga 16/02/2024 11:41:18(UTC)
4998 Dance Car on Analog Layout? (Collector's Corner general)
by ccranium 13/02/2024 04:09:20(UTC)
Marklin 0232 mini club track game or layout guide? (Small scale)
by ProductionMgr 10/02/2024 04:03:24(UTC)
MiWuLa in Hamburg quit Märklin layout after 25 year! (General MRR)
by Goofy 09/02/2024 19:45:51(UTC)
Whats the best way to start to prepairing for landscaping in new layout construction (H0-scale)
by tandrschaefer 22/01/2024 21:39:47(UTC)
trying to find the perfect track layout (H0-scale)
by river6109 10/01/2024 13:55:31(UTC)
c-track geometry advice needed for my layout (H0-scale)
by fabstar68 08/01/2024 23:41:10(UTC)
Expandable power consumption Layout Plan (Model railroad wiring)
by Hubertvanmierlo 04/01/2024 01:26:41(UTC)
sw layout control (Model railroad software)
by fvelazdem 03/01/2024 13:51:05(UTC)
Marklin layout on Craigslist (Collector's Corner general)
by Hematite 20/12/2023 16:40:28(UTC)
All in M-track layout plan (Track plans)
by tandrschaefer 15/12/2023 00:50:36(UTC)
Marklin Hauptbahnhof coin operated display layouts (Great layouts I have seen...)
by Paul59 01/12/2023 01:42:46(UTC)
Märklin Factory Built Layouts for Dealers and Shows (Collector's Corner general)
by Jimmy Thompson 30/11/2023 01:55:07(UTC)
New layout with C & K track. Will older M signals work? (Digital)
by matiSon 23/11/2023 02:53:09(UTC)
Starting HO Marklin Layout: Questions (General MRR)
by matiSon 25/10/2023 20:56:38(UTC)
Digital Engines on Analog Layout (H0-scale)
by FastEddie 19/10/2023 00:08:49(UTC)
My New Marklin Toporama Z Gauge Layout (Small scale)
by tsenthia 12/10/2023 07:52:48(UTC)
Not Marklin but you have to see this layout (General MRR)
by heinrichhess 03/10/2023 16:16:26(UTC)
CS3 layout editing (Digital)
by rytter 30/09/2023 23:50:31(UTC)
six months in and pulling down layout (General MRR)
by heinrichhess 29/09/2023 16:23:13(UTC)
This page was generated in 0.841 seconds.
