Offline Drongo
#1 Posted : 23 March 2017 06:07:19(UTC)
Drongo
I'm confused regarding the wiring of my layout.
I'm using an EcoS and Traincontroller with my layout and I'm asking for opinions as to which wire to use. Firstly, the wire from the EcoS to the layout. I was suggested to use 0.75mm stranded copper wire from the EcoS to a central point where I can distribute the power to different parts of the layout. Again, from the central point to the layout, I'm using the same wire.
Secondly, I'm connecting to the C Track to an s88 unit for occupancy detection, and the wire I'm using here is 0.5mm stranded copper wire.
Is this wire suitable or is there better wire to use?
Another question on wire - is it better to use thicker wire if in doubt as this gives better conductivity than a thinner wire?
Greg
Offline applor
#2 Posted : 23 March 2017 06:37:07(UTC)
applor
Greg
The thicker the wire, the less voltage drop you get over longer distances due to the thinner wire having a higher resistance.
This makes it necessary to have a thick enough cable for your bus and enough feeder tracks so that the trains gets the required voltage to operate (particularly in the case on compact c-sine which were rather voltage sensitive prior to the SDS update)
I am using 0.5mm solid core for my S88 detection, they are short runs and won't be a problem so I wouldn't worry.
I am using 16 gauge for my bus cabling, which is overkill, but its cheap and easy - figure 8 audio cable is perfect and readily available.
#3 Posted : 23 March 2017 08:20:55(UTC)
Yes.
The voltage drop grows proportionally with the current and the length. You reduce the voltage drop by half if you double the diameter of the wires.
So there is no "One size fits all". A small Xmas tree layout with just one loco has a low current and short distances and thin cables will do.
And don't forget the "²". You probably ask about 0.75 mm².
0.75 mm² should be sufficient - even for the 6 A of the new ECoS 2.1.
For very large layouts with very long cables, thicker cables may be required to keep the overload detection operational.
Offline Drongo
#4 Posted : 23 March 2017 10:17:09(UTC)
Drongo
Yes.
Thanks Tom, you've answered my questions. Yes, the "squared" was missing from my message as I didn't know how to do it from the keyboard - perhaps another question (and off topic).
Again, thanks for the help.
Greg
Choice of wire gauge (Small scale)
by ciderglider 11/07/2025 15:49:50(UTC)
Wire gauge Crocodile wiring inside (Small scale)
by Chas 04/07/2025 19:17:37(UTC)
Wires from winding (H0-scale)
by johnhendry 07/04/2025 02:19:24(UTC)
wire (Digital)
by Timnomads 23/03/2025 10:59:06(UTC)
New problem red wire (Digital)
by jesperdog 22/03/2025 15:35:44(UTC)
Ground wire on loc digital conversion upgrade (Digital)
by garben 14/02/2025 04:44:59(UTC)
Marklin wire (H0-scale)
by David Dewar 15/01/2025 17:09:51(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Broken connecting wires to brushes (H0-scale)
by Don Mebius 01/05/2024 22:31:58(UTC)
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Wire gauge for locos (Small scale)
by ciderglider 12/01/2024 18:37:14(UTC)
Finally got the yard wired up! (Small scale)
by einotuominen 17/12/2023 18:29:12(UTC)
Overhead wire system for sale (H0-scale)
by Keith C 20/10/2023 19:06:17(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Colors in new Marklin Start up wires (H0-scale)
by Angelo_Schettini 27/05/2023 03:50:28(UTC)
Invisible track feeder wires (Small scale)
by Manga 08/03/2023 10:30:03(UTC)
Feeder wires (H0-scale)
by Suomi762 01/03/2023 22:48:54(UTC)
Additional Feeder Wires (Digital)
by Mayleneman 05/02/2023 21:27:58(UTC)
Wire and voltage (Digital)
by Thewolf 21/12/2022 20:49:37(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
How to wire the Marklin 60902/60942 decoder to achieve swiss lighting in Re460 (Digital)
by Bill L 05/10/2022 09:01:14(UTC)
Multiwire rolling stock connections (H0-scale)
by revmox 05/07/2022 04:38:29(UTC)
Wrapped wire around axles (General MRR)
by GaryTrooper 17/10/2021 06:15:57(UTC)
78111 (display for rollerbed) - require wire(colors) for Transducer attachment (General MRR)
by clapcott 07/05/2021 10:06:29(UTC)
Wire Stripper (Model railroad wiring)
by MKOpSeattle 24/04/2021 08:32:02(UTC)
Wire gauge? (H0-scale)
by Puttputtmaru 18/03/2021 20:42:14(UTC)
M83 M84 and S88 wire sizes (Model railroad wiring)
by Demch 28/12/2020 21:42:23(UTC)
Electrical wire cross sectional surface for a decoer (Digital)
by sdel95 20/12/2020 16:22:13(UTC)
Locomotive Maintenance - broken wires (H0-scale)
by randallchin 19/12/2020 05:13:45(UTC)
Wireless control of M track accessories (Digital)
by joyofmarklin 22/11/2020 03:43:22(UTC)
Locomotive Wire Suggestion Needed (Model railroad wiring)
by Roman 03/11/2020 21:06:01(UTC)
Connector for wires (Model railroad wiring)
by chiemgau 11/10/2020 20:46:40(UTC)
Electrical wire connections to the Decoder m83 (Digital)
by fosuna 04/10/2020 11:57:41(UTC)
7186 Turntable connection help. Where does this loose wire go? (H0-scale)
by HerrDoktorBD 16/08/2020 03:00:36(UTC)
Need for bus wires using C-Track (Great layouts I have seen...)
by Richard Joint 03/08/2020 20:59:21(UTC)
Is 20AWG solid “bell wire” OK for my layout? (H0-scale)
by husafreak 17/06/2020 03:55:12(UTC)
Legacy Marklin DCC decoder wire color code (Digital)
by faithie999 13/04/2020 17:34:02(UTC)
Märklin gauge 1 catenary wires (Big scale)
by aclassifier 17/01/2020 10:30:22(UTC)
Wireless from laptop to CS3 and most recent CS3 update not working (Digital)
by johnpatrickwack 18/11/2019 13:32:16(UTC)
design of power supply wires (Model railroad wiring)
by Thewolf 28/08/2019 14:36:35(UTC)
3600 EKS 3-Rail Uncoupler devise re-wire (H0-scale)
by HO_Steve_OH 24/08/2019 21:49:21(UTC)
Bus feeder wires? (Model railroad wiring)
by Jabez 10/05/2019 22:24:24(UTC)
Soldering Feeder wires to C track (Model railroad wiring)
by Jabez 19/04/2019 22:36:52(UTC)
How do I wire up a signal protecting a point? (Digital)
by LongHairedDavid 28/02/2019 19:23:25(UTC)
Wire section (Model railroad wiring)
by Thewolf 27/02/2019 16:20:28(UTC)
Attaching wire to sockets?? (General MRR)
by tommysus 26/02/2019 20:16:24(UTC)
Bent catenary masts...and wires (H0-scale)
by Michael4 31/01/2019 10:44:10(UTC)
We all need inspiration and support when it comes down to the wire (General MRR)
by river6109 25/12/2018 00:59:15(UTC)
Digital is more than 2 wires (Model railroad wiring)
by amartinezv 20/12/2018 11:16:35(UTC)
Adding Wires to Seuthe Smoke Units (General MRR)
by skeeterbuck 03/11/2018 17:21:56(UTC)
This page was generated in 0.371 seconds.
