Offline bobhunt2
#1 Posted : 09 August 2007 05:35:15(UTC)
bobhunt2
I have recently put together a factory building which has provision for some lights - but does not supply them.
What is required is a length of cable from which 2-3 LEDs branch out for distribution within the model. I know that such things exist because I received some as part of my Marklin roundhouse kit.
I have had a look at Viessmann and Brawa lights but they seem to be confined to structured lights.
Can anyone suggest where I might be able to source some?
Bob
Offline tekin65
#2 Posted : 09 August 2007 09:18:14(UTC)
tekin65
Turkey
bob hi,
here we have smd leds that come with smd resistors, ready to be used with 12V. leds are placed on a strip that you can clip, and at the back there is scotch tape for easy installation.
you might want to check electronics shops.
regards,
cem.
Now all eras but no ICE
#3 Posted : 10 August 2007 06:12:09(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by bobhunt2
<br />I have recently put together a factory building which has provision for some lights - but does not supply them.
Bob
Bob Try JAY CAR. I have got some 3mm Leds from them. Easy to connect etc.
Also they will give you the correct resistor to incluse in hte Circuit .
N
Leichtstahlwagen interior lights (General MRR)
by mvd71 16/04/2025 21:29:34(UTC)
Marklin 43335 Control cab coach - headlights will not reverse red/white (H0-scale)
by Donb 19/03/2025 04:03:34(UTC)
ICE 2 Train headlights (General MRR)
by rickjames84 27/10/2024 02:10:13(UTC)
60760 Decoder no lights w/Delta (H0-scale)
by Brian_BR96 26/06/2024 02:12:05(UTC)
Sudexpress – Special Highlights 2024 (News from Märklin and others)
by bph 18/04/2024 10:54:01(UTC)
39710 flickering LED lights (Digital)
by Kaspar 12/02/2024 13:26:43(UTC)
Marklin 37784 (ICE 3) interior lights only working in one direction (H0-scale)
by BillMNYC 27/01/2024 21:05:32(UTC)
Locomotive Lights........ (Small scale)
by spinnerguy 16/01/2024 11:32:41(UTC)
mSD3 / mDT - Output - Dual flashing lights (Digital)
by einotuominen 29/07/2023 17:16:30(UTC)
Cab lights with mSD3 (21pin board) (Digital)
by einotuominen 05/07/2023 21:37:02(UTC)
Signal lights (Digital)
by Tie 28/04/2023 16:36:00(UTC)
Having passengers lights control when loco is starting (Digital)
by Puttputtmaru 15/03/2023 15:05:41(UTC)
Incandescent lights for Marklin layouts instead of LED (General MRR)
by dwptravel 08/02/2023 21:02:54(UTC)
Coaches 4095 and 4097 - Interior lights (General MRR)
by ocram63_uk 16/12/2022 16:04:43(UTC)
Riding the État 231-592 in 1938: La Bête Humaine / The Human Beast Highlights Cab Ride (Prototype)
by I_love_Marklin_37538 28/09/2022 12:17:20(UTC)
M track points lights (Model railroad wiring)
by mitchnz 12/08/2022 02:56:16(UTC)
Lights NMBS series 55 (Digital)
by cintrans 11/07/2022 18:39:30(UTC)
Trix Marklin Alco Pa Union Pacific 600/601 DCC -how to connect the LED lights in AC system (H0-scale)
by Bill L 25/05/2022 01:33:28(UTC)
Self making End lights for passenger cars (H0-scale)
by JohnjeanB 12/05/2022 18:28:13(UTC)
Lights that light up in the opposite direction of travel (Digital)
by maruju 18/04/2022 09:18:01(UTC)
M84 AC flickering led lights (Digital)
by Mbjerre 28/03/2022 13:06:41(UTC)
How I activate the Red lights on passenger car 4027 (H0-scale)
by 2shy2fly 17/02/2022 03:12:43(UTC)
SBB lights changeover with mSD3 (Digital)
by anthpao 02/12/2021 22:02:14(UTC)
Front white lights and rear red tails lights based on direction (Digital)
by waterslip 29/11/2021 12:48:36(UTC)
Rear end red lights on German Locomotives (Prototype)
by PJMärklin 07/10/2021 11:19:08(UTC)
Interior lights for Märklin SJ wagons 4020 and 4021 (H0-scale)
by pederbc 29/06/2021 21:48:18(UTC)
Viessmann lights for Z scale (Small scale)
by veloboldie 27/04/2021 22:51:18(UTC)
Marklin 7187 signal - broken lights (General MRR)
by ocram63_uk 27/04/2021 15:48:36(UTC)
Swiss lights changeover (Digital)
by anthpao 26/04/2021 01:52:19(UTC)
3060 lights and switches (H0-scale)
by BenP 06/04/2021 02:44:35(UTC)
Locomotive lights will not turn off (H0-scale)
by Keyser 27/02/2021 06:37:07(UTC)
No Blinking Lights (H0-scale)
by dominator 07/02/2021 22:56:59(UTC)
Directional lights on Passenger Cars (General MRR)
by xpsensation 04/02/2021 21:30:00(UTC)
Easy Fix for Analog Car Lights Flickering On Digital Layout? (H0-scale)
by frickwg 22/01/2021 21:21:04(UTC)
Lights in bi-level cars (Märklin 43574/43575) (H0-scale)
by PeFu 19/01/2021 11:23:50(UTC)
Headlights not working (Digital)
by Keyser 03/01/2021 20:16:28(UTC)
Marklin wiring for lights on analog small track (Model railroad wiring)
by kakemann 29/11/2020 10:40:19(UTC)
LED lights (General MRR)
by rogergags 25/09/2020 03:56:11(UTC)
Problems with lights on marklin34635 delta dec. (Digital)
by geir 03/09/2020 18:15:55(UTC)
26495 - Montreal Limited Observation Car-no lights (Digital)
by HerrDoktorBD 28/08/2020 02:48:03(UTC)
EBAY LED lights (Digital)
by oranda 25/08/2020 21:16:03(UTC)
Tail lights on Era III steam locomotives (Prototype)
by Gregor 30/06/2020 13:27:56(UTC)
Cabin Car lights based on Loco direction of travel (Digital)
by STE-BM 04/05/2020 17:37:30(UTC)
3696 with flickering lights (Digital)
by dominator 10/04/2020 02:00:57(UTC)
3739 lights issue. (General MRR)
by Hics 15/03/2020 11:41:44(UTC)
HUGE smoke, sounds, lights... how does this all work? (Big scale)
by doublereefed 18/02/2020 22:47:43(UTC)
Add Headlights Cab End to the starter set locomotive 29479 (Digital)
by Pasquiles 25/12/2019 14:52:46(UTC)
White LED headlights for DB 101 (H0-scale)
by fossie 19/11/2019 23:57:13(UTC)
Wiring a 3900 / 3800 M track w/ switches & semaphore lights (Model railroad wiring)
by edmund36 24/10/2019 23:00:15(UTC)
Marklin Vectron Long distance lights and cab lights (Digital)
by anthpao 23/10/2019 11:40:09(UTC)
This page was generated in 0.293 seconds.
