Offline Timnomads
#1 Posted : 23 March 2025 10:59:06(UTC)
Timnomads
Hi All
I would like to put a ring main under the track with leaders connecting to the track and other boxes when needed. What type of wire should i use? I am deciding between solid two core or filimant two core. Advice please
Thx
Tim
thanks 1 user liked this useful post by Timnomads
Online rhfil
#2 Posted : 23 March 2025 11:51:16(UTC)
rhfil
It is not really necessary unless you have a huge layout. But the thicker the wire the less drop it will have ad you get further from the power source. 12 or 14 gauge works. See the end of this video:
Offline PMPeter
#3 Posted : 23 March 2025 15:08:30(UTC)
PMPeter
I used standard 3c#14 North American house wire. This provides Black, White and Red conductors where I used the White to run the (Yellow) lighting circuit.
Online rhfil
#4 Posted : 24 March 2025 04:57:50(UTC)
rhfil
House wire is often less expensive than the same gauge separately. But some claim that you get interference if you run a different signal next to a coded signal so you might want to separate the dc power wire from the ac signal wires.
Offline PMPeter
#5 Posted : 24 March 2025 17:23:25(UTC)
PMPeter
I never had a problem with this and had all my control through RocRail and a CS2. However, if that is a concern you can always run 2 times 2c#14AWG house wire. One for the track power and the other for lighting and accessories. However, if you end up joining the brown from both circuits as is normally recommended, then you again could have the same issue.
Offline Willem99
#6 Posted : 24 March 2025 17:52:14(UTC)
Willem99
Hi there,
I bought a supply of wire last month at https://www.wiringdepot....ire-16-AWG-100-Ft-Spool.
It works very well. I am using red, brown and yellow for the standard marklin colors on my analog section.
I am using green for the catenary.
I am going to be using orange and black in place of red and brown for the digital section
I will be using white for the house and street lights once I get to that stage.
It will be very colorful underneath the tables :)
I am really not to worried about the costs of the wire, Model Railroading is an expensive hobby anyway.
If it comes down to saving a couple of pennies per foot on the wire then it is probably not the right hobby.
Besides, this company has all the colors that I need and is not like Amazon where I need to buy packages with colors that I will never use.
But as usual, this is my viewpoint, you do not have to agree with it.
Enjoy
Tim
thanks 3 users liked this useful post by Willem99
#7 Posted : 25 March 2025 11:52:23(UTC)
Wiring depot seems to carry the same selection as Home Depot, etc. 20 awg being the thinnest. I would find that romex house cable is too cumbersome to work with for wiring a layout. Unless you strip all of the outer vynil insulation away. Too much work.
Offline Willem99
#8 Posted : 25 March 2025 15:15:04(UTC)
Willem99
I have looked at Home Depot, Lowes and every other hardware store in this area, including Amazon.
They just did not have the selection of colors and the 16AWG that I wanted.
Besides Wiring Depot ships for free, so that helps.
I agree with your other comments, too much work for not enough value.
Tim
thanks 1 user liked this useful post by Willem99
Manage CS3 wireless on PC – how? (Digital)
by GRL1849 05/01/2026 00:20:53(UTC)
Yellow feed wire for digital decoders (Digital)
by Darren 31/12/2025 04:00:38(UTC)
MS2 and wireless MS update (Digital)
by paulcushing 09/10/2025 00:06:38(UTC)
soldering wires to the Flat sleeve connectors. (General MRR)
by Alex H 06/10/2025 19:48:43(UTC)
Choice of wire gauge (Small scale)
by ciderglider 11/07/2025 15:49:50(UTC)
Wire gauge Crocodile wiring inside (Small scale)
by Chas 04/07/2025 19:17:37(UTC)
Wires from winding (H0-scale)
by johnhendry 07/04/2025 02:19:24(UTC)
New problem red wire (Digital)
by jesperdog 22/03/2025 15:35:44(UTC)
Ground wire on loc digital conversion upgrade (Digital)
by garben 14/02/2025 04:44:59(UTC)
Marklin wire (H0-scale)
by David Dewar 15/01/2025 17:09:51(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Broken connecting wires to brushes (H0-scale)
by Don Mebius 01/05/2024 22:31:58(UTC)
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Wire gauge for locos (Small scale)
by ciderglider 12/01/2024 18:37:14(UTC)
Finally got the yard wired up! (Small scale)
by einotuominen 17/12/2023 18:29:12(UTC)
Overhead wire system for sale (H0-scale)
by Keith C 20/10/2023 19:06:17(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Colors in new Marklin Start up wires (H0-scale)
by Angelo_Schettini 27/05/2023 03:50:28(UTC)
Invisible track feeder wires (Small scale)
by Manga 08/03/2023 10:30:03(UTC)
Feeder wires (H0-scale)
by Suomi762 01/03/2023 22:48:54(UTC)
Additional Feeder Wires (Digital)
by Mayleneman 05/02/2023 21:27:58(UTC)
Wire and voltage (Digital)
by Thewolf 21/12/2022 20:49:37(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
How to wire the Marklin 60902/60942 decoder to achieve swiss lighting in Re460 (Digital)
by Bill L 05/10/2022 09:01:14(UTC)
Multiwire rolling stock connections (H0-scale)
by revmox 05/07/2022 04:38:29(UTC)
Wrapped wire around axles (General MRR)
by GaryTrooper 17/10/2021 06:15:57(UTC)
78111 (display for rollerbed) - require wire(colors) for Transducer attachment (General MRR)
by clapcott 07/05/2021 10:06:29(UTC)
Wire Stripper (Model railroad wiring)
by MKOpSeattle 24/04/2021 08:32:02(UTC)
Wire gauge? (H0-scale)
by Puttputtmaru 18/03/2021 20:42:14(UTC)
M83 M84 and S88 wire sizes (Model railroad wiring)
by Demch 28/12/2020 21:42:23(UTC)
Electrical wire cross sectional surface for a decoer (Digital)
by sdel95 20/12/2020 16:22:13(UTC)
Locomotive Maintenance - broken wires (H0-scale)
by randallchin 19/12/2020 05:13:45(UTC)
Wireless control of M track accessories (Digital)
by joyofmarklin 22/11/2020 03:43:22(UTC)
Locomotive Wire Suggestion Needed (Model railroad wiring)
by Roman 03/11/2020 21:06:01(UTC)
Connector for wires (Model railroad wiring)
by chiemgau 11/10/2020 20:46:40(UTC)
Electrical wire connections to the Decoder m83 (Digital)
by fosuna 04/10/2020 11:57:41(UTC)
7186 Turntable connection help. Where does this loose wire go? (H0-scale)
by HerrDoktorBD 16/08/2020 03:00:36(UTC)
Need for bus wires using C-Track (Great layouts I have seen...)
by Richard Joint 03/08/2020 20:59:21(UTC)
Is 20AWG solid “bell wire” OK for my layout? (H0-scale)
by husafreak 17/06/2020 03:55:12(UTC)
Legacy Marklin DCC decoder wire color code (Digital)
by faithie999 13/04/2020 17:34:02(UTC)
Märklin gauge 1 catenary wires (Big scale)
by aclassifier 17/01/2020 10:30:22(UTC)
Wireless from laptop to CS3 and most recent CS3 update not working (Digital)
by johnpatrickwack 18/11/2019 13:32:16(UTC)
design of power supply wires (Model railroad wiring)
by Thewolf 28/08/2019 14:36:35(UTC)
3600 EKS 3-Rail Uncoupler devise re-wire (H0-scale)
by HO_Steve_OH 24/08/2019 21:49:21(UTC)
Bus feeder wires? (Model railroad wiring)
by Jabez 10/05/2019 22:24:24(UTC)
Soldering Feeder wires to C track (Model railroad wiring)
by Jabez 19/04/2019 22:36:52(UTC)
How do I wire up a signal protecting a point? (Digital)
by LongHairedDavid 28/02/2019 19:23:25(UTC)
Wire section (Model railroad wiring)
by Thewolf 27/02/2019 16:20:28(UTC)
Attaching wire to sockets?? (General MRR)
by tommysus 26/02/2019 20:16:24(UTC)
Bent catenary masts...and wires (H0-scale)
by Michael4 31/01/2019 10:44:10(UTC)
This page was generated in 0.648 seconds.
