Offline tony_bbc
#1 Posted : 24 October 2019 20:30:14(UTC)
tony_bbc
I have 4 very old dc marklin z engines that ran well before being stored for more than 5 years.
They need servicing as they light but dont run
How do i clean the wheels
I just purchased marklin 7149 oil which the manual for my dB engine says to use. It also says not to use oil.
So whats the difference
If i used labelle oil years ago was that a mistake.
While 2 engines came with instructions the gg1 and f7 engines did not.
Are there manuals i can access for them. Please send link
Any help would be appreciated
Tony
#2 Posted : 24 October 2019 21:16:05(UTC)
Is it one of those symbols that shows a can of salad oil?
The message is "Do not use salad oil". Machine oil will be fine.
Some batches of 7149 suffer from "hardened oil syndrome" and may glue up your motor.
Offline Carim
#3 Posted : 24 October 2019 21:49:51(UTC)
Carim
Hello Tony,
Welcome to the forum. Labelle oil will be fine (I use Labelle 108). If you go to https://www.maerklinshop.de/en/SpareParts/index and enter the model number, you should be able to get the user manual for it.
Carim
Offline Zme
#4 Posted : 24 October 2019 22:19:23(UTC)
Zme
Hello, Yours in an interesting post. I hope I might be able to help out.
Tom is correct, don't use any salad oils on your Marklin Z Scale items. Labelle's has been used and recommended by many, a synthetic oil, in a variety of types. It has been the old Markin oils which have caused the HOS, (hardened Oil Syndrome) which you may be experiencing. If the Labelle's was used before, it should not be a problem, but if the light only comes on when power is applied, it may call for an entire cleaning of the loco. I use Labelle's 108 too and it works great.
Wheels can be cleaned in a variety of ways. There are brushes which are available, which clean the surface. I myself use an electric Jewelry cleaner, which are available in a variety of type and costs. I disassemble the loco and then drop the wheels in the tank and turn it on. It vibrates the surfaces clean, and this has worked well. Remember, disassembling is a bit risky because a part can be lost.
If you are not sure you want to invest in one of these, (Even a cheap one would work) you could clean each with a small brush, such as a dental type brush for between the teeth. They are available in a variety of widths, from narrow to wide, but they are very soft and may not completely clean the gears. I use 70% isopropyl alcohol or above. Parts may be soaked in this fluid, but I don't recommend soaking overnight as the surfaces of the gears may lose that polished. gleaming finish they are produced with. These brushes work well with cleaning a variety of parts, and are sold in grocery stores next to the toothpaste. You may be surprised by the amount of old oil, and mixed in dirt they will clean. Just don't use a harsh cleaner of stiff brush, be gentle.
I always go back to the source for missing documents for the Marklin z scale items as Carim has suggested.
In addition to instruction sheets, parts lists and other information can be found here.
With a little careful effort, I am certain you will get your engines working again.
Best wishes
Offline husafreak
#5 Posted : 25 October 2019 06:07:59(UTC)
husafreak
Cleaning and restoring old Marklin's is a great hobby in and of itself. If you are up to the task and want to you can learn by doing with a few small tools and a 9V battery. Get some magnifying lenses and a bright light, work on a white towel so you can keep track of every part, and take lots of pictures with your cellphone so you can get it all back together again. And no worries, if you just want to pass the job to another modeler, or if you get lost and can't finish the job, there are guys here in the states (shameless plug!) like Frank at Zscalehobo (but a real hobo, just a Z scale fanatic) who offers a repair service for your Marklin loco's.
#6 Posted : 25 October 2019 08:42:50(UTC)
They had bad batches in the '90s AFAIK. I experienced no hardening with the 7149 oil I used in the '70s.
Marklin Z 81520.000 (Small scale)
by gary664 Yesterday at 19:29:04(UTC)
Help with ID Marklin Z (Small scale)
by Chas 01/08/2025 13:07:30(UTC)
Marklin z scale (Digital)
by Allen Lee 08/06/2025 01:53:52(UTC)
Marklin Z-Scale Signals Part 2 (Small scale)
by Fluegelmeister 07/04/2025 01:07:03(UTC)
Noisy Marklin Z locomotives (Small scale)
by Papymouzot 05/02/2025 14:30:28(UTC)
Using Snail Controller with Miniclub Marklin z scale engines (Small scale)
by Mary 24/07/2024 20:05:11(UTC)
Marklin Zeppelin Railcar (Small scale)
by spinnerguy 26/12/2023 20:35:31(UTC)
Marklin Z Scale (Older Model) Spare Parts in US (General MRR)
by NewToThis 26/09/2023 02:18:09(UTC)
Marklin Z Br50 And Equal Locos (Small scale)
by Artologic 16/09/2023 21:01:46(UTC)
Marklin Z Gauge Catalogue Numbers (Small scale)
by dannyboyz 14/08/2022 21:46:25(UTC)
Best Marklin Z Steam Loco for Hauling (Small scale)
by Jags 17/07/2022 03:33:59(UTC)
Marklin z fifty year page (Small scale)
by Zme 03/03/2022 05:14:20(UTC)
Attaching Marklin Z track to Noch preformed layout (Small scale)
by xxup 05/02/2022 03:13:20(UTC)
Marklin Z track (Small scale)
by daveoZ 02/01/2022 19:24:27(UTC)
Marklin z 88221 (Small scale)
by pdiam2 05/05/2021 18:14:55(UTC)
Oiling Marklin Z scale locos (Small scale)
by ajayrav 18/05/2020 17:50:26(UTC)
Marklin Z-Scale Restoration Latest Vid. (Small scale)
by Fluegelmeister 19/04/2020 23:36:00(UTC)
Improved Lighting for Marklin Z scale loco's with HTM (Small scale)
by husafreak 03/04/2020 23:25:05(UTC)
Marklin z and digital (Small scale)
by Nrwatson 10/12/2019 14:46:27(UTC)
Marklin Z car (Digital)
by Agrawal 23/07/2019 16:15:34(UTC)
Marklin Z scale future plans (Small scale)
by wbrock 27/05/2019 22:05:09(UTC)
Looking at Marklin Z scale Is there a starter set?????? (Small scale)
by tommysus 28/02/2019 13:33:46(UTC)
Marklin z new tooling rail bus and trailer 88166 88171 (Loco Reviews)
by stevedenver 19/09/2018 19:42:28(UTC)
Stores carrying Marklin Z scale products that are in stock (Small scale)
by veloboldie 05/06/2018 16:39:53(UTC)
Digital Conversion Question: Marklin Z Class 50 Steam Loco (Small scale)
by JD3 01/06/2018 21:46:25(UTC)
Marklin Z and 'Gap Track' (Small scale)
by Bahner 29/12/2017 07:43:01(UTC)
Marklin Z scale uncoupler track uncoupling (Small scale)
by darticus 29/12/2017 02:04:49(UTC)
Marklin Z 8590 Insulator Use (Small scale)
by darticus 10/09/2017 20:24:52(UTC)
What is the smallest diameter curve a Marklin Z can do? (Small scale)
by darticus 08/09/2017 23:20:20(UTC)
Marklin Z Track Insulators??? Do they make them? (Small scale)
by darticus 19/08/2017 15:56:11(UTC)
Still scratching my head on correctly putting marklin z steamer wheels back in??? (Small scale)
by Artologic 12/08/2017 12:46:09(UTC)
Need help getting Marklin Z 8885 , BR 03 to run !?? (Small scale)
by MarklTedII 23/07/2017 15:38:16(UTC)
Marklin Z scale fun (Small scale)
by ixldoc 30/11/2016 07:19:50(UTC)
Marklin Z turnouts...AC or DC power? (Small scale)
by marklin81 25/05/2016 03:25:25(UTC)
Marklin Zeppelin remake 3 (H0-scale)
by ixldoc 13/05/2016 10:03:47(UTC)
Marklin Zeppelin remake 2 (H0-scale)
by ixldoc 03/05/2016 07:33:16(UTC)
Marklin Z Crossing 8559 (Model railroad wiring)
by IanR38 07/04/2016 22:17:08(UTC)
Marklin z Gauge Points (Model railroad wiring)
by IanR38 27/02/2016 12:24:37(UTC)
Marklin Z Gauge Rolling Stock (Small scale)
by IanR38 22/02/2016 22:59:43(UTC)
Marklin Z item 81352 (News from Märklin and others)
by docfinance 07/01/2016 21:30:12(UTC)
Worn in motor 5 pole anker Marklin Z Br24 (Small scale)
by Artologic 07/04/2015 12:29:40(UTC)
Marklin Z Gauge 88731 Max Liebermann (Small scale)
by johnmarklin 01/03/2015 18:14:33(UTC)
Marklin Z Gauge 8864 Diesel Engine (Small scale)
by grahame 06/10/2014 03:22:21(UTC)
Marklin z Parts (Small scale)
by Zme 23/02/2014 21:22:39(UTC)
QUESTION - Marklin Z photos wanted (Small scale)
by billch 25/01/2014 07:26:16(UTC)
Marklin Z photos (Collector's Corner general)
by billch 21/12/2013 23:07:56(UTC)
Marklin z scale DB 89 service sheets, photos etc for routine maintenance (Small scale)
by grahame 21/12/2013 20:16:21(UTC)
Marklin Z Gauge Starter Set - which engine is best ? (Small scale)
by Jay939598 20/11/2013 19:06:42(UTC)
Marklin Z scale 8874 5 pole motor conversion (General MRR)
by sillypilot 13/09/2013 05:27:30(UTC)
Marklin Z Steam Loco Traction (Small scale)
by rjstichler 16/08/2013 15:35:59(UTC)
This page was generated in 0.498 seconds.
