Offline eurotrain
#1 Posted : 28 July 2021 15:45:07(UTC)
eurotrain
I have successfully added 6 S88s on my layout. The 7th and final S88 will not work. I can not get my reed switch to signal the CS3.
I have the correct " length" on my CS3 for the GPF-3
I have switched RJ45 cables to see if there was a bad cable. I bought an extra S88 thinking the last one was bad but I get the same result.
I have seen glitches in the CS3 before, but this one is making me crazy,
I have seen people try a reboot and change the length back to one etc.
I could really use some ideas to fix this issue. I only have 15 more reed switches to connect.
Thank you in advance.
#2 Posted : 28 July 2021 17:59:18(UTC)
Hi Eurotrain (funny kinda first name I think)
My guess your problem is you have to specify the length of each bus (1, 2 and 3) on your CS3 or the Bus 1 on CS3+
On my CS3 is shows like this with one S88 on Bus 1 and 7 on Bus 2.
If you have a CS3+ there must be a similar screen with only one bus
Failure to indicate the proper length means the extra modules won't be scanned (will not report information back)
#3 Posted : 29 July 2021 01:56:47(UTC)
I just ordered my first 60881 S88 for my CS3+ and one contact track. I watched the webinbar and the factory setting is for (5) S88's, so you need to change that setting to 6 or more.
I presume I can use this contact track for one event. Can it make the trains start and stop at the contact track with or without triggering a couple of turnouts, and a signal?????
#4 Posted : 29 July 2021 11:25:11(UTC)
Yes, it can. No restriction on the type (switch, signal, relay) and on the number. The action is triggered by a signal FLANK (becoming busy= loco arriving symbol) or free= loco leaving symbol) normally without delay but there may be one.
#5 Posted : 29 July 2021 13:07:49(UTC)
Meric Jean! Once again, I appreciate your knowledge!
#6 Posted : 30 July 2021 22:14:01(UTC)
Does one ground wire or two connect to the S88? The diagrams with the Contact track and S88 seem conflictiing to me. One from the ouside of the contact area to the ground port on the S88 for sure, and also one from the insideside of the contact area to the left screw terminal of track 1 port?
Thank's in advance!
#7 Posted : 30 July 2021 22:58:36(UTC)
The way it works is simple:
- all your Märklin layout has the same 0 (external rails) no matter how many boosters you have
- you must connect this 0 also to the S88 system because it is a floating voltage BUT much preferably only at one point (only one S88 at the upside-down "T"). Why? to avoid having high currents in your S88 system in case of short-circuits.
- each detection section is one of the rails, insulated from the other rail (by cutting the little 2 bridges per C track rail) and insulated from the next section by the little red insulation sock on rail connector.
- the detection section may be as long as you want but usually does not include switches / Double - slips. The wire connecting it to the S88 input should be short (1 meter maximum if possible) and possibly away from high current wires (feeder wires)
- it is your responsibility to make sure that after the detection section, the rails are connected to the 0
Diode Trick
With Märklin S88, some people (also me on some difficult places) add a diode to improve the rail contact (loco stopping in detection sections). Each cathode (side with ring marking) on the detection section side and the anode on the other rail. It is not mandatory but may improve circulation on track with dust.
The easiest way is to install the diode inside the track bed of on C track section per detection section
Problem to register s88 (Digital)
by geir 26/09/2025 20:19:04(UTC)
Problems adding new contacts to S88Link (Digital)
by Dirtboy 03/04/2025 17:09:56(UTC)
Problems with S88AC and CS3 Plus (Digital)
by sanjiv 10/03/2025 12:02:30(UTC)
L88 to S88 cable type. (Digital)
by Luna 14/02/2025 15:50:27(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
Can one connect 2 S88 LINK (L88) units together, if so how (Digital)
by Condios 01/02/2025 14:11:48(UTC)
S88 error message (Digital)
by brauer.jim 27/12/2024 21:11:58(UTC)
60882 S88 DC for three Rail AC Operations (Digital)
by KennethH 23/12/2024 04:55:04(UTC)
S88 DC not powering train (Digital)
by morsing 15/12/2024 08:22:29(UTC)
Feedback modules S88 interfere? (Digital)
by Tjeerd 27/11/2024 16:53:14(UTC)
Problem with S88dc (Digital)
by As30157 22/10/2024 02:16:15(UTC)
Link s88 / Diode Trick / C & K Track (General MRR)
by Marklin Nut 12/10/2024 22:44:17(UTC)
Add a Digikeijs S88 DR4088xx after LINK88 on a CS3 (60226) (Digital)
by JeanClaudeMCH 16/05/2024 03:13:29(UTC)
S88 connection (Digital)
by mcs51 27/04/2024 12:59:18(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
S88 contact and Track Diagram CS3 (Digital)
by fvelazdem 13/11/2023 13:50:14(UTC)
CS2 : s88Link and Booster use same port : how do I connect them both ? (Digital)
by Johnvr 06/07/2023 13:04:58(UTC)
Train Controller Gold sees Blocks only on the Direct S88 (Model railroad software)
by punksie1 28/04/2023 21:49:51(UTC)
s88 link and cs3 (Digital)
by Thewolf 10/12/2022 23:17:22(UTC)
S88 Grounding (Digital)
by Bones 30/11/2022 11:09:53(UTC)
S88 60880 not working (Digital)
by craigericks 02/11/2022 01:09:06(UTC)
Cable extension from S88Link (60883) to cs2 (60215) (Digital)
by Thewolf 06/12/2021 23:19:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
S88 (Digital)
by eurotrain 04/06/2021 18:58:52(UTC)
CS3 adding S88 AC to Link S88 (Digital)
by luckas 12/05/2021 10:09:04(UTC)
Intellibox I 65000 S88 damaged. How to open it? (Digital)
by fje 01/05/2021 18:12:54(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
S88 bus-length CS3 changes automatically (Digital)
by Gustav 14/02/2021 09:03:52(UTC)
Digital software users: Is an LDT HSI-88 a must have for s88 feedback? (Digital)
by Roland 18/01/2021 04:03:46(UTC)
Checking the S88 60880 (Digital)
by biswasg 17/01/2021 18:08:46(UTC)
Contact Track, M-Track and S88 (Digital)
by Harvey 15/12/2020 01:19:00(UTC)
s88 sensor track placement (Digital)
by IBtrain 06/12/2020 06:29:16(UTC)
Faulty S88 module? (Digital)
by morsing 12/08/2020 19:52:50(UTC)
S88 (old) and CS2 - how do I get started? (Digital)
by hvc 16/06/2020 05:55:42(UTC)
CS3+ with Link S88 60883 (Digital)
by Demch 21/04/2020 20:23:53(UTC)
How I have solved the unstable s88 feedback (Digital)
by French_Fabrice 25/03/2020 23:08:18(UTC)
S88 DC Questions with LGB (Digital)
by ReelfootJim 24/02/2020 01:54:11(UTC)
Cs3 S88link (Model railroad software)
by Heinz 19/12/2019 21:23:22(UTC)
Adding 2- S88 to L88 (Digital)
by eurotrain 16/12/2019 14:32:17(UTC)
All s88's Yellow (Digital)
by Elsleuth1 12/12/2019 02:02:15(UTC)
Link S88 (Digital)
by Drjoe11 10/11/2019 15:53:33(UTC)
Connecting a 3rd S88, L88 involved - help! (Digital)
by johnpatrickwack 05/11/2019 22:29:54(UTC)
Problem with S88 ac (Digital)
by geir 27/10/2019 19:11:04(UTC)
S88AC and S88DC (Digital)
by mgbeck_98 05/09/2019 21:50:01(UTC)
L88/S88 - Events no longer work? NOW SOLVED (Digital)
by petestra 24/07/2019 13:20:15(UTC)
S88 sensor flickers with power applied (Digital)
by applor 24/03/2019 02:09:25(UTC)
Advise on S88 feedback modules (Digital)
by IBtrain 14/03/2019 16:23:11(UTC)
CS2 S88 problem (Digital)
by Peter Claesson 05/02/2019 22:00:21(UTC)
L88 and S88 (Digital)
by Harvey 05/02/2019 21:32:53(UTC)
CS3 Plus and S88 (Digital)
by David Dewar 03/01/2019 20:24:11(UTC)
This page was generated in 0.371 seconds.
