Offline gbrendem
#1 Posted : 05 February 2021 14:26:03(UTC)
gbrendem
Hi, I'm trying to insert a sound decoder into a BR110 locomotive Märklin, old type.
The engine on this has been changed.
The manual has been followed, but it only lights up at both ends of the locomotive when I try it?
It is Märklin Sound-Decoder mSD (Not NEM) Pictures can be sendt.
Thanks.
#2 Posted : 05 February 2021 15:07:59(UTC)
Some locos with C Sine motor require a NEM decoder to work. Non-NEM decoders cannot provide the power the C Sine motor driver board needs.
Which loco is it? Which decoder is it?
#3 Posted : 05 February 2021 18:11:05(UTC)
Please post the model number or if not readily available, photos of the model.
can you also post a photo of the chassis of the locomotive, showing the decoder and the wiring?
Offline gbrendem
#4 Posted : 06 February 2021 11:15:08(UTC)
gbrendem
Thanks for your answer.
It's a BR 110 234 - 2. Decoder Märklin Digital "60967 Conversion Decoder Set for a Electric Locomotive"
Offline bph
#5 Posted : 06 February 2021 14:19:48(UTC)
No
your locomotive originally has a "regular" motor, so the decoder has no problem running it, as long as you have installed a permanent magnet motor.
A common thing to forget with the 60967 decoder is that it does not use the Märklin colour codes on the wires. Double check that you have wired it up according to the NEM colour codes as described in the 60967 manual.
please post pictures of how motor, decoder and light are wired up.
the decoder could also be faulty or have been programmed wrongly?
Offline gbrendem
#6 Posted : 06 February 2021 19:32:44(UTC)
gbrendem
Offline gbrendem
#7 Posted : 06 February 2021 19:34:45(UTC)
gbrendem
Offline gbrendem
#8 Posted : 06 February 2021 19:36:47(UTC)
gbrendem
Offline gbrendem
#9 Posted : 06 February 2021 19:39:40(UTC)
gbrendem
Thanks for help.
I hope you will figure it out and help me?
I hope you can see my pictures there?
Offline Crazy Harry
#10 Posted : 06 February 2021 21:40:41(UTC)
Crazy Harry
As noted above, the 60967 decoder follows the NEM colour codes, refer to page 27 of your manual (not page 28). Grey and orange go to the motor not the light as your pictures show.
Harold.
Offline nhumps
#11 Posted : 06 February 2021 22:11:29(UTC)
nhumps
I would recommend heat shrink on (all joins for that matter) both the chokes where joining to the motor output wires (blue and green) - articulation of the bogie can make those touch the chassis and or permanent magnet and ground out which will make a short.
Potentially grounding any outputs from the decoder can blow it, such as the sound ones (Sadly I have done this with an msd3 before)
thanks 1 user liked this useful post by nhumps
Offline bph
#12 Posted : 06 February 2021 22:42:14(UTC)
No
Thanks for help.
It seems like you have mixed up the wire colours and wired acording marklin standard. If you take a look at the german version in the manual on page 5, it says "Die Kabelfarben am Decoder sind nach Norm NEM 652". But it seems that Marklin forgot to translate that important notice and put it on page 27 (The wire colours on the decoder are according to the NEM 652 standard.)
So wire up the decoder according to the NEM table on page 27 in the 60967 manual.
Offline bph
#13 Posted : 06 February 2021 23:02:48(UTC)
No
And make sure the light bulb ground is not concected to the chassis before you wire up with the blue wire. (Common Wire for Lights)
Offline gbrendem
#14 Posted : 06 February 2021 23:57:40(UTC)
gbrendem
Thanks for help.
Thanks a lot for your help.
Should the two speakers be connected. There is red and black wire on them. How to connect them to work properly?
thanks 1 user liked this useful post by gbrendem
Offline bph
#15 Posted : 07 February 2021 11:25:39(UTC)
No
Hi, connect only one speaker to the brown wires. polarity is not marked on the decoder wires.
Offline gbrendem
#16 Posted : 07 February 2021 11:36:07(UTC)
gbrendem
The red wire to the brown and the black wire to the ground?
What about the second speaker?
Thanks.
Offline bph
#17 Posted : 07 February 2021 13:28:21(UTC)
No
Thanks.
Hi, don't know if I understand you correctly, but never connect the speaker wires to the chassis ground. (if the brown speaker wires accidentally touch the chassis ground, you might destroy the decoder sound module.)
In short, the red and black speaker wires go to the two brown speaker wires on the decoder.
the reason for two speakers is to provide an option to several different locomotive models, just pick the biggest one if it fits.
Offline gbrendem
#18 Posted : 08 February 2021 21:08:27(UTC)
gbrendem
Thanks.
I understand you, thanks for your help.
Märklins new sound decoder 256 MB? (Digital)
by Goofy 08/11/2025 17:37:24(UTC)
Marklin 60976 Diesel sound decoder install (Digital)
by Gerald Lynch 14/10/2025 22:19:01(UTC)
Sound Decoder (H0-scale)
by Harvey 26/06/2025 15:13:31(UTC)
msd sound decoder (Digital)
by vupti 17/11/2024 14:19:09(UTC)
Problem with Piko sound decoder 5.1 (Digital)
by Goofy 24/08/2024 07:36:38(UTC)
Marklin sound decoder bootloader/firmware update (60977) (Digital)
by dlwestphalen 08/08/2023 03:02:32(UTC)
Installing MSD3 Sound Decoder in SBB Ae 8/14 (Märklin 37593) (Digital)
by Johnvr 24/02/2023 07:46:31(UTC)
Sound decoder problems (Digital)
by Charles Farrugia 26/11/2022 16:58:44(UTC)
Conversion of the snow plow with recent loksound decoder (Digital)
by French_Fabrice 20/11/2022 18:16:17(UTC)
Which High efficiency motor retrift kit and sound decoder for Marklin ho br 218 diesel? (Digital)
by marklinist5999 21/02/2022 14:31:47(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
ESU sound decoder instructions (H0-scale)
by river6109 07/12/2021 11:36:41(UTC)
Sound decoder (General MRR)
by Vadim 01/04/2021 11:57:22(UTC)
Märklin 55741 Köf II Sound decoder (Big scale)
by pa-pauls 10/03/2021 21:53:42(UTC)
A slight night mare programming a Zimo sound decoder (Digital)
by river6109 21/10/2020 04:09:12(UTC)
Problem with sound decoders 60975, 60976, 60977 (Digital)
by Best Ripper 17/09/2020 21:11:02(UTC)
Marklin Br24 sound decoder dead (H0-scale)
by fossie 08/06/2020 14:53:12(UTC)
Mfx Sound decoders having random ANNOYING issues (Digital)
by Martin T 02/04/2020 22:27:32(UTC)
CS3 sound decoder update.. Missing files (Digital)
by Nick_40034 25/02/2019 00:34:12(UTC)
60987 sound decoder problems. (Digital)
by Nonno FULVIO 11/01/2019 17:41:57(UTC)
Smoke Unit with ESU Loksound Decoder (H0-scale)
by skeeterbuck 20/12/2018 03:26:34(UTC)
4 AUX sound decoder (Digital)
by Nick2017 07/08/2018 20:20:46(UTC)
Sound Decoder (Digital)
by skeeterbuck 02/06/2018 00:01:46(UTC)
Has anyone had a problem with a Marklin sound decoder (Digital)
by dominator 30/04/2018 06:41:13(UTC)
Sound Decoder for Marklin 5579 (Big scale)
by Jaime 13/04/2018 02:23:40(UTC)
OBB 1116 - Sound Decoder (H0-scale)
by kganotop 09/04/2018 21:40:57(UTC)
sound decoders (Digital)
by river6109 20/07/2017 04:01:09(UTC)
Märklin sound decoder (Digital)
by river6109 07/03/2017 09:35:44(UTC)
Programming / Uploading sound scenes / files into ESU LokSound decoders (Digital)
by Minok 01/03/2017 00:06:32(UTC)
English Tutorial re Sound Project for mSD/3 Sound Decoder/Programming (Digital)
by Malcolm Smith 12/01/2017 02:26:31(UTC)
37184 Sound Decoder Issue (Digital)
by mb300e4m 12/12/2016 01:50:46(UTC)
Piko 96225 AC and Marklin MFX sound decoder help (H0-scale)
by danmarklinman 18/10/2016 20:22:16(UTC)
Reset Sound decoder on 39016 BR 01 (Digital)
by trainsman2001 18/05/2016 21:06:18(UTC)
Sound decoder problem (Digital)
by Inox 20/07/2015 23:33:29(UTC)
Märklin V80 (36080) Sound Decoder conversion (with Video) (H0-scale)
by Moritz-BR365 09/07/2015 08:26:52(UTC)
VT11.5 with dual sound decoders (H0-scale)
by biedmatt 27/06/2015 14:13:54(UTC)
ESU LokSound Decoder - English Instruction Booklet?? (Digital)
by Joseph Meiring 23/06/2015 21:29:22(UTC)
Märklin Ludmilla BR 232 now with Doehler&Haass Sound Decoder - Matthias Henning sound (with video!) (H0-scale)
by Moritz-BR365 03/06/2015 08:41:49(UTC)
ESU Loksound decoders for "old" V200 diesel 3021? (Digital)
by Joseph Meiring 31/05/2015 19:38:57(UTC)
Zimo sound decoder and Marklin Mobile Station 2 (Digital)
by Unholz 29/05/2015 14:45:38(UTC)
What Loksound Decoder Is This? (Digital)
by trainstamp 30/04/2015 16:04:14(UTC)
ESU Loksound Decoder (Digital)
by ice 1 21/01/2015 13:35:54(UTC)
Sound decoders in 3309 BR85? (Digital)
by Joseph Meiring 22/10/2014 23:19:56(UTC)
suitable sound decoder for Roco BLS Ae 6/8 (Digital)
by river6109 07/06/2014 10:50:39(UTC)
With or without sound decoder (Digital)
by Goofy 05/06/2014 18:28:24(UTC)
Sound decoders for loco's (Digital)
by Shamu 01/04/2014 07:36:32(UTC)
Sound decoder for Märklin Ludmilla (Digital)
by Hackcell 07/02/2014 17:40:46(UTC)
Roco ESU M4 sound decoder? (Digital)
by Goofy 06/01/2014 12:12:32(UTC)
ESU M4 sound decoder and 3 pole motor (Digital)
by Goofy 06/01/2014 11:36:47(UTC)
Have you ever been frustrated from a loco with sound decoder and noisy motor? (H0-scale)
by H0 12/12/2013 09:35:34(UTC)
This page was generated in 0.632 seconds.
