#1 Posted : 06 October 2016 14:32:53(UTC)
Having just come back I appear to be overdoing the questions lol.
Just installed my fourth shuttle on the layout (several years since the others were installed) Loco works fine but when coaches are added it stops where the coach reaches the contact area and the loco then just goes back and forwarded a few inches.
Having forgotten what I did with the other shuttle routes where am I going wrong now ?
Maybe at my age changing the layout was not a great idea. Any help much appreciated.
#2 Posted : 06 October 2016 16:28:51(UTC)
are we talking about Märklin or ESU decoders ?
#3 Posted : 06 October 2016 18:22:10(UTC)
Marklin S88 John.
#4 Posted : 06 October 2016 22:35:44(UTC)
This is indicative of a shuttle setup using contact track - e.g. 24995 (isolated rail that is bridged by an axle) when, on a CS2, you have ....
- contact bounces - due to dirty track or physically not in contact
- the detection section is shorter than the span of the wagons axle spacing
- you use 2 rail wagons (DC wheel-set, with isolated wheels), in the middle of a consist.
Unlike the CS1, the CS2 implementation of the shuttle is not tolerant to these bounces.
The best suggestion is to extend your detection track.
If you are using circuit tracks (shoe triggered e.g. 24994) , then you must ensure that the 2 directional indicators are NOT wired together. You must only get a pulse when going in one directions.
Poorly adjusted contact track mechanisms (the level that the shoe hits) may spring back and cause a false pulse in the other direction.
Reed switches on a CS2 shuttle will not work without additional logic
#5 Posted : 06 October 2016 23:41:19(UTC)
Thanks Peter. I am using 24995 which is easy to connect to a S88. Will go through the above suggestions.
Shuttletrain help (Digital)
by Mille 12/06/2023 08:58:41(UTC)
Wiring for shuttle trains. (Model railroad wiring)
by IBtrain 22/11/2021 20:46:29(UTC)
Automated digital shuttle (Digital)
by BenP 21/09/2021 18:19:06(UTC)
Bingo: shuttle train operation (Digital)
by river6109 08/08/2021 12:56:02(UTC)
Adding sounds to a Shuttle route using a CS2 (Digital)
by Elsleuth1 29/06/2021 21:56:13(UTC)
Digital shuttle operation (General MRR)
by Brian McWhirter 03/02/2021 04:09:33(UTC)
Cheapest solution for shuttle layout (General MRR)
by Komm 27/01/2021 20:07:30(UTC)
Shuttle Route (Digital)
by Elsleuth1 14/02/2019 01:58:16(UTC)
Programming a shuttle route (Digital)
by Harvey 12/02/2019 17:38:42(UTC)
Shuttle Route issue (H0-scale)
by JoeB 14/01/2019 04:10:14(UTC)
Day 2 , Garratt Shuttles , different track . (Prototype)
by Tom Jessop 30/09/2018 23:25:26(UTC)
Garratt tourist shuttle . (Prototype)
by Tom Jessop 29/09/2018 22:59:39(UTC)
MA 3423 shuttle (Digital)
by Crocodile 11/11/2014 11:40:31(UTC)
Analogue shuttle. (H0-scale)
by mikemasey 10/06/2014 03:23:59(UTC)
Creating a shuttle train route with a S88 module (Digital)
by Rocca 06/05/2013 09:47:05(UTC)
Simple Shuttle Route (Digital)
by gharris198 28/04/2013 22:16:09(UTC)
Marklin MS 2 & a Simple Shuttle:Advice appreciated (Digital)
by 1spur 09/01/2013 20:06:05(UTC)
Ecos shuttle train (Digital)
by Iamnotthecrazyone 07/12/2012 22:55:14(UTC)
Sylt Shuttle - May 28 (Prototype)
by Alsterstreek 02/04/2012 22:38:59(UTC)
Shuttle routes with the new 60214 (H0-scale)
by loegerk 25/07/2011 02:54:52(UTC)
shuttle trains (Digital)
by nevw 19/05/2011 07:25:05(UTC)
Shuttle routes in CS2 (Digital)
by kgsjoqvist 20/10/2010 18:49:37(UTC)
Shuttle train ETC (Digital)
by charles Sharpe 17/10/2010 00:09:09(UTC)
Shuttle Train Version 1 2009 (Digital)
by nevw 21/10/2009 01:12:10(UTC)
Some questions on how to shuttle (Digital)
by Pavle 16/08/2009 23:36:37(UTC)
6051 shuttle? (Digital)
by WelshMatt 03/11/2008 16:14:27(UTC)
Shuttle/S88 (Digital)
by charles Sharpe 17/07/2008 00:27:35(UTC)
shuttle trains. (Digital)
by charles Sharpe 03/07/2008 23:10:36(UTC)
Help with shuttle trains- solved (Digital)
by ria 04/04/2008 14:13:09(UTC)
Cannot configure Shuttle Train with s88 /CS-SOLVED (Digital)
by Caplin 20/01/2008 17:56:14(UTC)
This page was generated in 0.327 seconds.
