Offline pab-windmills
#1 Posted : 19 August 2011 05:00:10(UTC)
pab-windmills
I have a section of track on my layout where the grade is approx 3%. Almost all of the loks I have - Swedish Rc series, NOHABS, etc, can drag a fairly long consist up the grade without any issues. I also have one of the beautiful D-series wooden loks (3170) and the Danish 37037 steam engine. Both of these seem to be spinning their wheels on level sections of the layout. On the grade, both of these slow down and completely stop, wheels spinning like crazy, struggling to gain traction. I have replaced the tires on both loks, but this did not help. Any ideas from anyone out there? Thank you!
#2 Posted : 19 August 2011 06:28:13(UTC)
Pab
there can be several issues about wheels spinning out of control.
I'm surprised after changing traction tyres with new ones it is still happening.
second scenario is, look at the wheels and see if all or particular the axle with rubber tyres is actually firm on the track itself.
Thirdly, earlier locos without load regulated decoders & motors had to go uphill at full speed to be able to reach the top and some of them never achieved this
locos on level sections should not be a problem at all unless you have such a heavy load behind the loco, the motor can't cope with it and the wheels are just spinning.
Your 37037 has had problems if its the same design as the BR 38, where as Märklin has added another set of wheels with Rubbertyres, first and last axle.
So you may write to Märklin and find out what they have to say or what they are going to do about it.
3170 has the same chassis as a 3179 (E 132) and the weight is not particular impressive so without a high efficiency motor and without a load regulated decoder this loco will not perform as well as pointed out with a digital conversion set (60903, 60923), actually this loco in its analog version is a very poor performer.
I also have the EP 2 (Primex , converted) and added another axle with rubber tyres.
Rubbertyres: When fitting new rubber tyres, make sure you understand and know the course why they don't work anymore.
putting to much load onto the loco will automatically result in wheels spinning (mostly analog version)
old rubber tyres get worn a.) because of the extended use over years, b.) dirty tracks, c.) over oiled engines, (rubber tyres hate oil).
With the latter experience you have the clean the groove as well to get rid rid of any sign of oil residue before replacing them with new ones, otherwise you are back to square one.
make sure you get the right size rubber tyres designated for this particular loco and also when fitting them make sure the rubber tyre is evenly distributed on the wheel itself and sits 100 % in the groove.
Good luck with your next mountain excursion.
regards.,
Offline GSRR
#3 Posted : 19 August 2011 07:08:38(UTC)
GSRR
P.
Have you checked the coupler height on the loks, possibly need adjustment. Also swap cars to different types, at least the lead car.
r/Thomas
Offline Brakepad
#4 Posted : 21 August 2011 08:22:54(UTC)
Brakepad
France, Metropolitan
I believe this issue has nothing to do with the decoder or the efficiency of the motor. If the wheels spin,then power is obviously not the problem.
If a loco shows ths problem assuming that wheels and traction tyres are clean,upgrading it with a hyper-ultra efficiency motor and the latest top performance decoder will improve nothing,unless the vertical reaction on the tractive axles -in particular the one/s with traction tyres- is increased,or the number of traction tyres is increased (but this has some disadvantages,regarding costs -the wheels have to be swapped or a slot machined on them- ,current collection and track cleanliness.
That being said,there are some locomotives which are just too light or the weight distribution is so poor that they can not handle a heavy consist on anything but a perfectly leveled surface.
The "easy" solution is trying to add some weight to the loco, if possible at the areas where the axle with traction tyres are located. But this is not always possible due to lack of space.
Offline Chris6382chris
#5 Posted : 21 August 2011 08:31:35(UTC)
Chris6382chris
If you have wheels spinning on level sections, check to see if you have oil or something on your wheels or track. It happened to me (had one engine's wheels spinning and other engines had no problem) but once cleaned up all was ok again.
#6 Posted : 21 August 2011 08:54:51(UTC)
I don't agree with all your assumption and in my opinion has nothing to do with facts.
A motor as described without a high efficiency system or a decoder that doesn't support the torque factor will struggle going up hill, as I've mentioned in my previous post unless at full speed.
To add weight to the loco is one option and as you've mentioned where needed, is not always possible and most the time impossible.
Having had a layout over 20 years and starting off with AC analog- digital and now converted all my locos with a 5 pole armature / perm. magnet, ESU lokpilots/sound decoders I can tell you and this is the fact my locos have very much improved going up hills.
Loco I've converted including the heavy SBB Ae 4/4 and BR E 44 had one set of rubber tyres and I've added another axle with rubber tyres (2 axles powered), It can pull any heavy train.
Another model I have is an american Steam loco weighing over 800g (loco only) but hasn't got rubber tyres and it pulls hardly anything.
To add another axle with rubber tyres does make a lot of difference and it is easier in the long run, if required, as to add weight to the loco.
One example is the BR 38.
Further more, an AC Analog motor may not support the extra weight or traction that is required
My explanation or solution, if this answer was directed to me,it is not one problem but the cause can come from different factors and to resolve it, some factors have to be combined.
regards.,
#7 Posted : 21 August 2011 16:27:32(UTC)
Chris6382chris
The engines that are slipping, are they pulling long trains also?
Chris
Offline eroncelli
#8 Posted : 22 August 2011 11:35:18(UTC)
eroncelli
When wheels are spinning, simply there is not enough "friction" between wheels and rails; power (or torque to be precise) is enough, no matter if you have electronics and high efficiency motors.
The solution to the problem (apart from cleaning any oil and dirt) includes :
1) increase the weight of the loco
2) check the position of the wheels and the boogie to correctly distribute the weight (motorized boogie in rear position is better when going uphill)(we should talk about "isostatic" suspension of the wheels but seems too technical)
3) increase the friction (that what rubber tires are for)
So, if you can't increase the total weight of your loco, there are few possibilities to solve the issue.
Going back to electronics, "load regulation" is useful to start the train (electronics can increase the power/torque increasing the motor current, still keeping the speed) but not to solve the issue of wheels spinning (because more power means more slipping; on the contrary, should the loco stall with the wheels stopped, that would be a problem of "low power")
Have fun with your trains
Eugenio
Owner destroys 39244 with "traction" upgrade! (General MRR)
by LA2019 16/03/2025 17:18:47(UTC)
traction tire for Marklin 89005 engine (H0-scale)
by rabtab 04/02/2025 18:37:21(UTC)
Dual Traction Marklin Ms2 (H0-scale)
by DDAM1ANN 03/12/2024 20:52:47(UTC)
3000 add traction tire (H0-scale)
by Brian_BR96 18/06/2024 01:41:48(UTC)
Sources of traction tyres (H0-scale)
by Ewillis 04/03/2024 06:55:34(UTC)
Traction tires (General MRR)
by rhfil 22/11/2023 15:19:10(UTC)
Changing traction tires on 37780 ICE 3 center power unit (General MRR)
by artvegas 05/10/2023 17:57:02(UTC)
cheapest traction tires ever!! (H0-scale)
by heinrichhess 05/09/2023 20:04:30(UTC)
Märklin 37320 Re 10/10 how to reprogram double-traction (H0-scale)
by PFG45 17/02/2023 20:56:03(UTC)
Uneven traction tires on 39027 and 39491 (Br 02 0314 and DSB E 991) (H0-scale)
by bph 13/05/2022 23:24:15(UTC)
Rokuhan Traction Tires (Small scale)
by zoooctan 30/04/2022 19:39:18(UTC)
traction tires for marklin miniclub (Small scale)
by parakiet 12/11/2021 12:39:08(UTC)
Traction tyre sizes (so I don't need to buy Marklin) (H0-scale)
by Michael4 05/08/2021 17:43:54(UTC)
Traction tires (H0-scale)
by Mr. Ron 28/06/2021 02:56:26(UTC)
3029 with one traction tyre (H0-scale)
by Michael4 22/05/2021 17:48:56(UTC)
Oiled loc with 7149 - lost traction power (H0-scale)
by MarcelV 29/03/2020 03:13:17(UTC)
BRAWA 0571 has no traction tyre (H0-scale)
by aclassifier 04/07/2019 15:00:03(UTC)
Marklin 37861 V60 keeps shedding traction tyres (H0-scale)
by LongHairedDavid 02/07/2019 12:22:01(UTC)
New models, traction etc (Small scale)
by Poor Skeleton 16/03/2019 00:48:56(UTC)
Traction tire part number for 3060? (H0-scale)
by artfull dodger 24/02/2019 03:55:23(UTC)
traction issues (single tire) T3, glaskasten etc. (H0-scale)
by applor 15/01/2019 23:22:36(UTC)
BLS Traxx MU Traction and other BLS runnings (H0-scale)
by mike c 12/01/2019 03:30:55(UTC)
Loco traction force (General MRR)
by costing 14/12/2018 11:05:54(UTC)
Traction tyres 7153 and 7154 (H0-scale)
by Ivan 13/08/2018 14:33:38(UTC)
Lok #3440 threw a traction tire on an oval (H0-scale)
by walters48 15/04/2017 02:33:25(UTC)
Traction tires for 3007/SK 800 (Collector's Corner general)
by Soest 22/03/2017 18:24:42(UTC)
Marklin/Trix BR38/P8 traction issue resolution (H0-scale)
by applor 14/01/2017 03:45:54(UTC)
S2/6 37017 Traction (General MRR)
by PMPeter 21/10/2016 20:21:03(UTC)
traction tire help (H0-scale)
by thomas buckley 08/09/2016 01:22:23(UTC)
New tender for 39030 with traction problems (H0-scale)
by manou 01/04/2016 10:34:35(UTC)
3048 traction tires/all loco tires (H0-scale)
by thomas buckley 27/03/2016 21:11:41(UTC)
NS TRAXX E 186 double traction for Intercity Direct service. (Prototype)
by NS1200 03/10/2015 15:26:22(UTC)
Mitsubishi to update ICE2 traction equipment (Prototype)
by ozzman 27/05/2015 09:49:15(UTC)
Are these the right Traction Tyres to be fitted for 3085 ? (H0-scale)
by Johnvr 09/08/2014 09:24:54(UTC)
Alternative to rubber traction tires on locos (General MRR)
by Danlake 09/10/2013 09:19:32(UTC)
Traction Tires / Brushes (General MRR)
by kimmiemck 07/09/2013 17:19:54(UTC)
Marklin Z Steam Loco Traction (Small scale)
by rjstichler 16/08/2013 15:35:59(UTC)
traction tires for marklin engines (H0-scale)
by reverendpen 10/06/2013 19:36:21(UTC)
Traction Tires for King Ludwig Tristan Loco and #33041 Loco (Digital)
by wsscott 03/12/2012 18:36:30(UTC)
Traction Tire Replacement (H0-scale)
by Answ 25/10/2012 06:24:35(UTC)
BR 44 3047 44690 traction tyres (H0-scale)
by foumaro 17/04/2011 05:57:58(UTC)
How to replace traction tyres (General MRR)
by Drongo 27/10/2010 08:44:53(UTC)
Lack of traction and isolating points - In correct folder this time!! (Small scale)
by mahoose 04/03/2010 12:02:14(UTC)
Lack of traction; Z-gauge and isolating points (Small scale)
by mahoose 04/03/2010 11:55:07(UTC)
Old Plastic Traction Tires Stuck-Help Please (H0-scale)
by walters48 01/02/2010 03:09:46(UTC)
traction tire fitting - Solved (H0-scale)
by Darren W 20/11/2009 21:36:24(UTC)
I think ive just solved the BR01 39010's traction (H0-scale)
by monster134 10/11/2009 23:38:40(UTC)
by Deborail 18/10/2009 14:33:27(UTC)
traction tyres etc (Collector's Corner general)
Belarus drstapes 23/05/2009 22:11:12(UTC)
Decoder & Traction ??? (Digital)
by Frostie 23/02/2009 01:21:33(UTC)
This page was generated in 0.579 seconds.
