Offline markinalameda
#1 Posted : 28 May 2017 01:31:51(UTC)
markinalameda
Hi Folks, getting back into the hobby after long years of absence. Decided to get going with Marklin 29000 starter set and digital loco. After I plug in everything as instructed, nothing happens. Power pack does not get warm, no sign of life in Mobile Station. All connected and digital loco on track. Am I missing anything? There is no switch on Mobile Station. Should it power on just by being plugged in?
Thanks so much, and sorry for asking such a basic question. Thanks, Mark!!
Offline trainsman2001
#2 Posted : 28 May 2017 02:21:44(UTC)
trainsman2001
Hi Mark, I just purchased the same Digital set and didn't have any trouble with it. Did you purchase your set from a dealer in the U.S.? The set as sold from Marklin comes with a 220/230 volt power pack which needs to be replaced with a 110/120 power pack to work properly in the U.S. The mobile station itself is powered up from the power pack itself through the supplied track box. The power to the track is supplied by pressing the "stop" button on the mobile station and power is supplied to the track through the track box.
If you are getting power to the mobile station the "stop" button should be red and turn green once it is pressed. Also the mobile station's screen should read "Marklin". If the mobile station does not come to life after plugging in the power supply and you have plugged in the power supply and mobile station correctly through the track box then I would first check to see that you are receiving power to the power pack. If power to the pack is available, then check to see if you are getting power from the power pack to the track box. If the track box is receiving power and the mobile station does not come to life, check the connection between it and the mobile station for correct alignment of the plug from the mobile station to the track box. I have had issues with the track box before.
If all your connections are correct and you have a U.S. power pack, you may just have to return the set to your supplier with an explanation of what your are experiencing and hopefully you will get a replacement set or part sent quickly in return. Hope this explanation helps. Good luck, Sandy
locomotives of other brands compatible with märklin mobile station on k track (H0-scale)
by Alex222 23/04/2024 22:55:14(UTC)
Mobile station 1 and CS3plus compatibility (Digital)
by biswasg 25/03/2024 10:00:10(UTC)
Mobile station 2 not recognizing MFX decoder (Digital)
by Ivanmbrown 24/02/2024 01:55:36(UTC)
Mobile station vs. Central Station - and new C track layout application (Digital)
by bpitchkites 19/02/2024 17:42:29(UTC)
Mobile station 60657 extension cable (Digital)
by SamGreen 03/02/2024 20:36:36(UTC)
where is the problem with the 60652 mobile station (H0-scale)
by mike@complexplastics 16/01/2024 17:10:14(UTC)
by mike@complexplastics 15/01/2024 18:36:38(UTC)
Märklin digital mobile station 1 compatible trains etc (Digital)
by Alex222 04/01/2024 18:57:50(UTC)
Configure M83 with Mobile Station 2 (Digital)
by abeeche 14/12/2023 19:46:36(UTC)
Mobile Station 2 - Changing Addresses (General MRR)
by camcath 29/11/2023 23:26:23(UTC)
Connecting Mobile station (Digital)
by DhG 09/08/2023 09:09:22(UTC)
Turnout decoder, mobile station (Digital)
by pBonavoglia 31/05/2023 17:04:10(UTC)
Mobile station 2 updating help (Model railroad software)
by Model Railway shed D 13/04/2023 22:00:22(UTC)
Marklin mobile Station 60657 (Digital)
by Barton 17/03/2023 20:36:56(UTC)
Mobile station 60657 (Big scale)
by Zurky 08/03/2023 16:04:07(UTC)
Märklin 34989 DSB T 298 with Mobile Station 2 (Digital)
by sbendtsen 17/02/2023 18:24:39(UTC)
Will this schematic work with mobile station 2? (Model railroad wiring)
by 0Danne0 04/02/2023 15:14:28(UTC)
Feasibility of Running 4 separate Marklin C Track Loops Using 2 Mobile Stations 60653 (General MRR)
by mjborelli 31/01/2023 02:44:06(UTC)
Uploading unknowns into a Mobile Station 2 (H0-scale)
by tinroofrusted 18/01/2023 01:43:04(UTC)
Problem Running Marklin 39568 Engine w Marklin 60653 Mobile Station (General MRR)
by mjborelli 15/01/2023 18:47:41(UTC)
Mobile Station 2 (60657) software update without any CS (Digital)
by Pronto5 14/01/2023 17:56:23(UTC)
Can I use mobile station 1's with a CS3? (Digital)
by Allan2805 08/01/2023 01:26:43(UTC)
Mobile Station bug? or mfx decoder fault? (Digital)
by nikdog 04/12/2022 22:45:58(UTC)
Mobile Station 2 update from V1.1 fails from MS2 or 3 (Digital)
by gcanton 30/04/2022 17:30:56(UTC)
Changing address of 6080/6090 with mobile station v 3.148 (Digital)
by Michanglais 24/04/2022 16:26:12(UTC)
Central Station, Mobile Station & 32 Volt controller not working? (General MRR)
by mattj70 06/04/2022 05:43:05(UTC)
Mobile Station 2 with DCC loco? (Digital)
by LA2019 03/03/2022 23:45:32(UTC)
Mobile station 2 update to v3.55 in uk (General MRR)
by Christos -uk 31/01/2022 21:53:56(UTC)
dcc controller (Mobile station) compatibility (Digital)
by MalvernStation 12/12/2021 21:35:41(UTC)
Mobile Station 60653 (Digital)
by mramstedt 23/10/2021 18:53:42(UTC)
Mobile Station automation (Digital)
by robertmamlok 08/08/2021 19:02:47(UTC)
Mobile Stations Re-Booting; Proper Way to Use (H0-scale)
by alehrfeld 25/07/2021 16:12:22(UTC)
MS2 mobile station connections - basic questions (Digital)
by kimballthurlow 19/05/2021 08:44:41(UTC)
About Mobile station 2 voltage (H0-scale)
by Nalgangdo 10/02/2021 00:40:56(UTC)
Main station and mobile station app not found (Digital)
by eduard71 07/02/2021 14:49:34(UTC)
Mobile station 2 (General MRR)
by Gunnar 04/02/2021 20:13:01(UTC)
LokPilot 3 DDC with Mobile Station 2 (Digital)
by crow79 29/01/2021 09:03:45(UTC)
MARKLIN digital TRIX Mobile Station 2 (Digital)
by lrlgartner 26/01/2021 12:17:01(UTC)
Lokpilot V4 and Mobile Station (Digital)
by Kenneth1 19/01/2021 20:42:44(UTC)
Mobile station not working - please help (Digital)
by fejobelo 03/01/2021 19:38:38(UTC)
bizarre problem CS2 / iPhone mobile station with turnout control (Digital)
by applor 03/01/2021 01:23:21(UTC)
Mobile Station 2 and 29186 Delta set (Digital)
by jmallen622 24/12/2020 04:19:05(UTC)
Mobile Station 2 Finding an MFX Locomotive (Digital)
by MarcP 14/11/2020 21:19:59(UTC)
Mobile station (H0-scale)
by joyofmarklin 20/10/2020 05:00:13(UTC)
Mobile Station 60653 (H0-scale)
by Gunnar 27/09/2020 12:28:37(UTC)
Mobile station 2 problem (Digital)
by Stiewie 16/09/2020 21:25:02(UTC)
Resetting 74461 turnout decoder with Mobile Station 2 (Digital)
by Arnello 11/09/2020 20:42:12(UTC)
Mobile station 60653 (Digital)
by Gunnar 09/09/2020 16:30:50(UTC)
Controlling BEMO HGe 4/4 II - Nr. 107 - Grimsel with Mobile Station 2 (Digital)
by dott.erich 25/07/2020 22:19:52(UTC)
Conflict in running two DCC Trains on Mobile Station 2 (Digital)
Belarus Laurence 19/07/2020 12:46:45(UTC)
This page was generated in 0.365 seconds.
