Offline Gunnar
#1 Posted : 09 September 2020 16:30:50(UTC)
Gunnar
My mobile station stops the trains after around 5 - 8 seconds runnig. The old Mobile Station | Article No. 60652 run the trains perfect with no stopping.
In fact I have two 60652 mobile stations but bought this 60653 some years ago. It has worked perfect but suddenly, after extending the track have started
to stop the train I am runniing. I have only connected it to the tracks, no accessories whatsover.
Any ideas anyone?
I wonder if I need to reset it to the factory standard but hope to avoid this.
Take care and stay away from Corona all of you.
Gunnar
#2 Posted : 09 September 2020 20:13:33(UTC)
Sounds like a defect section of rail.
Be systematic; Go back to the original layout, and then begin adding new sections little by little, if you can't find the guilty section just by inspection.
Offline Gunnar
#3 Posted : 09 September 2020 20:41:26(UTC)
Gunnar
Seems a litte odd to me as there should be the same problem with the old 60652 mobile station. I know for sure it worked perfect before for some years but will check everything over again. When it stops I press the Stop button again and then it starts again and runs for 5 seconds or so. I will check the connetion from the power supply box. Can I use the power supply box from the 60652?
Thanks for your advice and will try again
OceanSpiders 2.0
Mobile Station 60653 (Digital)
by mramstedt 23/10/2021 18:53:42(UTC)
Mobile Station 60653 (H0-scale)
by Gunnar 27/09/2020 12:28:37(UTC)
by charles Sharpe 27/06/2020 13:54:42(UTC)
Mobile Station 60653 software ver. 3.3.5 (H0-scale)
by ParisTsirchoglou 12/02/2020 20:19:24(UTC)
Marklin mobile station 60653 (Model kits & layout details, kitbashing and such)
by Normmeister 11/08/2016 09:04:24(UTC)
Upgrading between Mobile Station 60653 and 60657 (Digital)
by aclassifier 13/02/2016 12:33:27(UTC)
Troubleshooting Mobile Station 60653 (Digital)
by elite194 22/05/2015 14:47:12(UTC)
Mobile Station 60653 (Big scale)
by Rocca 29/11/2014 14:38:58(UTC)
mobile station 60653 (Digital)
by Varun R 22/10/2014 11:11:30(UTC)
Mobile Station 60653 Freezing (Digital)
by Cyborg 10/03/2014 03:22:03(UTC)
Mobile Station 60653 Replacement Cable (Digital)
by chrisisrang 09/06/2013 02:47:25(UTC)
Mobile station 60653 (H0-scale)
by jackmac 21/09/2011 16:33:23(UTC)
Mobile Station 60653 - Reg 1 & 75 change (Digital)
by huttel 17/10/2010 12:44:54(UTC)
This page was generated in 0.332 seconds.
