Poll Question : Extent of signalling
Choice Votes Statistics
  Total 35 100%
Guests can't see poll choices and poll results. Try login or register. Guests can't vote. Try login or register.
Offline morsing
#1 Posted : 26 August 2020 11:53:21(UTC)
morsing
How many here go he whole way with signals? It's such a lot of money...
Please use the voting buttons.
Henrik
Edited by user 27 August 2020 10:31:24(UTC)  | Reason: Not specified
Marklin C-track + CS3+
thanks 6 users liked this useful post by morsing
Offline petestra
#2 Posted : 26 August 2020 15:26:14(UTC)
Originally Posted by: morsing Go to Quoted Post
How many here go he whole way wih signals? It's such a lot of money...
Henrik
Hi Henrik. I've always had a lot of signals, just love them! Anyway, I only went digital in 2014 and have operated Maerklin since the mid 60s. I have many
different generations of them on my layout including many digital ones now. I run a mostly automatic system now, some still controlled analog and then
I have 9 events programed on the CS3 for the digital ones. I have installed power off/on switches for main line blocks so that trains will pass a red light from the
opposite direction of travel.
I will not, however, purchase the braking modules. They are much too costly.
Cheers, Peter. Cool
#3 Posted : 26 August 2020 16:59:01(UTC)
They add a lot of life and realism to the layout.
I also found it interesting learning about how they work as it provides a good understanding of how trains are run.
I reduced the price buy buying the Viessmann kits and assembling them myself. See:
https://cabin-layout.mixmox.com/2014/08/Viessmann-5210.html
The Viessmann signals are also better priced than the ones from Märklin.
Once signals are setup properly, one can also use them as a source of information when you are running the layout. I can tell by the signals aspects where some trains are going on the layout, or that a train is coming etc.
Here is how I go about installing them:
https://cabin-layout.mixmox.com/2016/01/Installing-signals.html
thanks 4 users liked this useful post by DaleSchultz
Offline PeFu
#4 Posted : 26 August 2020 17:09:10(UTC)
PeFu
Those of us having a computer for automated train control, probably most often use signals for the visual effect only. I.e. they don’t control anything, but are controlled by the computer. We don’t use signals e.g. in hidden areas, so my response in this poll will only be ”Some signals”.
Smile
thanks 2 users liked this useful post by PeFu
#5 Posted : 26 August 2020 20:36:19(UTC)
I chose "Some signals".
I run analogue, so much of the braking-modules and decoders that you guys use, does not apply anyway.
(I do use braking, but it is a homemade series of analog power-feed)
All my visible stops has a signal. Some "vor-signalen" are also installed around the layout. Especially on the main line.
The main line has some stop-sections hidden in tunnels (no signals), so I use their vor-signal (posted on a visible part on the main-line) to inform me of the blocks state.
I have skimped a bit on "gleis-spehr" signals, but there are still quite a lot, so it looks almost real.
#6 Posted : 26 August 2020 21:10:19(UTC)
since I also have the ability to drive a train using a 'cab control' that shows the current signal's aspect, I have what I call virtual signals in hidden areas. They cost nothing but show up in the cab view. It enables the driver to know if they need to stop.
Cab control via phone: https://cabin-layout.mixmox.com/2019/03/mobile-phone-layout-control-app.html
Cab control via a browser: https://cabin-layout.mixmox.com/2014/08/browser-based-layout-control.html
Offline petestra
#7 Posted : 26 August 2020 21:43:21(UTC)
Hi Dale. I believe this is how the high speed lines operate with no signals. Peter. Cool
#8 Posted : 27 August 2020 04:31:25(UTC)
yes, signals are now being done away with completely. It is not possible to see them at high speed and kind of pointless at that speed anyway.
The step beyond that is to get rid of the driver completely. Makes no sense for the loco to tell the driver what speed is appropriate and then have the driver set that speed on the loco. Cut out the human source of error and just set the speed.
#9 Posted : 27 August 2020 07:48:47(UTC)
Its difficult with my layout as I run several different railway companies on my layout, I've started off with German signals and stayed with them, but they do differ from Austrian or Swiss signals and the same goes with the overhead system., having signals on my layout suits it as the length of tracks are long but at the same time they will be pre programmed with my automated train schedules
#10 Posted : 27 August 2020 09:19:28(UTC)
I use for this moment two of the Märklin digital light signals.
I decides to use Viessmanns analog semaphore but it seems they have reduced semaphore models in the list of cataloge.
If nothing happens from Viessmann i have to buy few more digital signals made of Märklin.
Offline morsing
#11 Posted : 27 August 2020 09:54:48(UTC)
morsing
Thanks for all the input.
I think I feel guilty, as always, on spending money on what is essentially a toy. The price of signals however, was dwarfed by the driveway quote we got yesterday... Puts things in perspective.
So, signals it is, I can definitely see the appeal. And I love the self-assembly Viessmann signals, didn't know they did that.
But, my layout is Danish, and one of my issues is that there doesn't appear to be any quality Danish signals. The built ones look like my niece made them and the self-assembly ones are usually a bit of badly cut plastic with two lose LEDs.
The German signalling seems to lack something compared to Danish signalling, but maybe I just don't understand German signalling.
I might just go for Viessmann signals and Marklin modules.
P.S. GOODNESS! Started looking at this again and it all came back to me. It's all very well I can get a set of main/distant signals for £20, but the Viessmann controller is £70 for one (set) of signals! It will be about £1500 for my relatively small layout. Madness!
thanks 2 users liked this useful post by morsing
Offline PeFu
#12 Posted : 27 August 2020 11:08:46(UTC)
PeFu
Have you tried out signals from the Swedish supplier ”Möllehem”? They have a good reputation:
http://www.mollehem.se/index.php/en/signals
thanks 3 users liked this useful post by PeFu
Offline morsing
#13 Posted : 27 August 2020 11:18:36(UTC)
morsing
Cool, they do look a lot better, although missing distant signals and branched signals.
Another problem would be controlling them. Danish signals have more complicated aspect combinations, don't know how you would do that.
I really need a good think about all this.
thanks 1 user liked this useful post by morsing
#14 Posted : 28 August 2020 04:16:04(UTC)
It is always difficult to make decisions when it comes to spending money on items which are extremely expensive, there is 1 solution which I've opted for, don't buy ready made controllers such as braking modules or other electronic gadgets, originally I've bought a braking module identical to the Märklin braking module, copied it with all its electronic components, I also have a friend in Berlin which offered to design a signal module with delayed light change and the third part I've designed my own opto couplers (replacing the switching tracks) and they fit between sleepers (K-track) and the signals come from Viesssmann., with the size of my layout I would estimate the savings of thousands of dollars.
Offline PeFu
#15 Posted : 29 August 2020 04:58:24(UTC)
PeFu
Möllehem have a Danish signal decoder too. You will need something that speaks LocoNet though. (Note that I have no relation with this company):
http://www.mollehem.se/i...ignaldecoder-dk10-detail
#16 Posted : 29 August 2020 09:27:28(UTC)
There is a hobby store name togcenter.dk that also produce danish signals and decoder too!
Offline morsing
#17 Posted : 29 August 2020 17:03:49(UTC)
morsing
Thanks, I did look at those before but honestly, the desciption says highest quality, but when you look at the enlarged photo it doesn't look like a Marklin or Viessmann signal, it just looks home-made.
Also, the controller says it can map Marklin aspects to the similar Danish signal aspects, which is a good start, but I'm pretty sure Danish signals can convey more messages that a German one. They normally have multiple combinations of steady, blinking and coloured lights.
But it's a good start though, still thinking about it.
Henrik
Setting Up Märklin 76393 Signals with CS3 and C-Track (Digital)
by tgj 27/04/2025 16:29:13(UTC)
Using M signals with C track (H0-scale)
by Luna 27/04/2025 05:02:03(UTC)
Does anybody recognise these signals ? (H0-scale)
by Johnvr 25/04/2025 15:50:45(UTC)
need help to reset viessmann multiplexer signals (Digital)
by fabstar68 19/04/2025 17:46:44(UTC)
Marklin Z-Scale Signals Part 2 (Small scale)
by Fluegelmeister 07/04/2025 01:07:03(UTC)
New Toporama Video - Z-scale Signals! (Small scale)
by Fluegelmeister 10/03/2025 04:36:10(UTC)
Manual enter linked signals into the CS3? (Digital)
by Nick_40034 13/02/2025 10:22:05(UTC)
info on distant signals with Rocrail (Model railroad software)
by fabstar68 11/02/2025 20:48:24(UTC)
Signals (H0-scale)
by Mjn2ts 07/02/2025 21:44:40(UTC)
Marklin or Viessman signals (General MRR)
by obb_taurus 13/01/2025 20:33:03(UTC)
External power supply for Märklin signals (General MRR)
by micknudsen 19/12/2024 21:30:03(UTC)
Static signals......supplier for Z gauge (Small scale)
by spinnerguy 12/12/2024 19:14:54(UTC)
dcc brake signals & marklin cs3 (Digital)
by fabstar68 12/06/2024 19:27:49(UTC)
C track signals (Digital)
by joyofmarklin 31/05/2024 19:46:52(UTC)
Marklin Semaphore Analog Signals (H0-scale)
by MALAVIKA 30/05/2024 14:45:23(UTC)
Automatic signals and braking without CS3 (Digital)
by intveltr 21/05/2024 02:48:31(UTC)
Connection of Fleischmann Signals to Märklin Systems (H0-scale)
by Eddie7979 18/05/2024 03:24:27(UTC)
Question about Marklin Semaphore Signals (H0-scale)
by WetterauSüd 13/05/2024 05:01:18(UTC)
switching Märklin Semaphore wingsignals with INFRARED gates (H0-scale)
by Holz1 25/04/2024 14:24:55(UTC)
Can Marklin signals work with the c-track from Trix? (General MRR)
by Sniklz 25/01/2024 23:35:50(UTC)
Light Signals (Track plans)
by PhilipS 04/01/2024 23:09:23(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
76442 braking module and 7649x signals (H0-scale)
by fabstar68 26/12/2023 23:44:25(UTC)
Set signal read after train passes with 7649x signals (H0-scale)
by fabstar68 26/12/2023 01:02:24(UTC)
New layout with C & K track. Will older M signals work? (Digital)
by matiSon 23/11/2023 02:53:09(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
viessmann signals multiplexer (Digital)
by Alfred Bugeja 20/08/2023 09:22:45(UTC)
where to put signals (H0-scale)
by heinrichhess 28/07/2023 21:39:03(UTC)
Use of Signals instead of Stop Markers in Train Controller (Model railroad software)
by garben 19/05/2023 20:18:57(UTC)
Question about Marklin signals (Digital)
by MegaExo 14/03/2023 18:58:43(UTC)
signals with yellow light (Digital)
by Mille 06/02/2023 04:15:35(UTC)
Signals and Ecos (Digital)
by cintrans 22/01/2023 14:06:59(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
How to mount analog signals to table? (H0-scale)
by Brian_BR96 06/10/2022 02:44:03(UTC)
Programming 763xx signals with CS3 help. (Digital)
by luckas 26/08/2022 15:57:31(UTC)
What do you control yours turnout and signals? (Digital)
by Goofy 11/07/2022 08:35:18(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New Marklin Digital Signals, any Online Primers or Guides? (Digital)
by 5HorizonsRR 29/05/2022 21:50:03(UTC)
Vintage signals, digital power and led bulbs (Model railroad wiring)
by BenP 08/05/2022 00:14:22(UTC)
Viessmann Regular or Multiplexer signals (in a computer controlled layout) (Digital)
by pmgsr 24/04/2022 21:21:35(UTC)
Circuit Track - HO K Track Configuration with Signals (H0-scale)
by rfeist 09/04/2022 20:58:07(UTC)
Cosmetic signals for CS3 (General MRR)
by Pasquiles 07/04/2022 23:16:09(UTC)
Advanced signals (General MRR)
by Thewolf 09/12/2021 04:01:46(UTC)
Signals in storage yard (Prototype)
by DaleSchultz 02/08/2021 00:05:41(UTC)
Viessmann signals with ESU SignalPilot and CS3 (Digital)
by swisslocofan 26/05/2021 23:56:39(UTC)
Märklin Model Signals Illustrated Handbook No.0341 (Collector's Corner general)
by phils2um 10/05/2021 01:45:00(UTC)
Signals (General MRR)
by Seacoast George 21/04/2021 17:26:38(UTC)
Correct Use of German Colored Light Signals? (Prototype)
by arnold894 14/04/2021 21:56:02(UTC)
HO scale signals for Marklin system (Model railroad wiring)
by biswasg 30/12/2020 08:56:46(UTC)
This page was generated in 0.764 seconds.
