Offline Mjn2ts
#1 Posted : 07 February 2025 21:44:40(UTC)
Mjn2ts
I’m contemplating going digital but trying to cut down on some costs. To that end I attempted to use m-track era signals on c-track with digital train control (apologies if I’ve missed worded that). I isolated the stop section and connected the red wires in their appropriate places, ran the blue wires to a circuit track (the one with the toggle switch built in) then ran the yellow wire and added a crown wire that was connected to an old blue transformer. The lights on the signal worked fine, the stop section worked manually but the circuit track wouldn’t change the signal. Is there another way I should have wired this or can I not use the old analog signals?
Jeff
Offline Martti Mäntylä
#2 Posted : 08 February 2025 01:21:57(UTC)
Martti Mäntylä
Hi Jeff, if I understood correctly, you are using a separate transformer to power the signals, in addition to the transformer powering the tracks? If so, you should connect the ground sockets of the two transformers to make this setup work.
- Martti M.
thanks 2 users liked this useful post by Martti Mäntylä
#3 Posted : 08 February 2025 14:44:04(UTC)
Hi Jeff
In complement to Martii's excellent answer (most probable cause) I have two suggestions:
- replace the bulbs MS4 in clear, red or green with LED MS4: they never burn, never heat up and never cause a discoloration on semaphore signals (7039, etc), the current need is way smaller than with regular bulbs. Here is an example of GOOD LED MS4 (must have a double wave rectifier, be 19 V, with LED firmly attached to the lamp base) https://www.ebay.de/itm/39322250...D%7Ctkp%3ABk9SR6DwntucZQ
- install the large signal base into a rectangular opening into the layout's plywood with the bottom of the hole closed with thick carboard with small apertures for the wires to come from under the table. Easy to make the rectangular hole using a vibrating tool with a cutting blade
It goes like this
Here is the result
Offline BenP
#4 Posted : 08 February 2025 20:14:08(UTC)
BenP
You can use vintage signals in digital mode by connecting to a k83 or m83 decoder that controls 4 units. No need for red wires as train power is controlled by central station.
Ben
Offline Mjn2ts
#5 Posted : 08 February 2025 20:38:06(UTC)
Mjn2ts
Yes exactly. I have a mobile station connected to the track for control and an old blue transformer to power the signal. Never thought to connect the brown wires together but it makes sense.
Thank you. Jeff
thanks 1 user liked this useful post by Mjn2ts
Converting old signals to LED (H0-scale)
by DaleSchultz 14/08/2025 04:10:49(UTC)
How to clean old solenoid signals and turnouts (points) (General MRR)
by Aussie Susan 19/06/2025 07:44:46(UTC)
Weinert Bavarian Signals (H0-scale)
by BwanaJoe 19/05/2025 15:47:10(UTC)
Rocrail - synchronized signals? (Model railroad software)
by JohnMishler 17/05/2025 03:19:04(UTC)
Setting Up Märklin 76393 Signals with CS3 and C-Track (Digital)
by tgj 27/04/2025 16:29:13(UTC)
Using M signals with C track (H0-scale)
by Luna 27/04/2025 05:02:03(UTC)
Does anybody recognise these signals ? (H0-scale)
by Johnvr 25/04/2025 15:50:45(UTC)
need help to reset viessmann multiplexer signals (Digital)
by fabstar68 19/04/2025 17:46:44(UTC)
Marklin Z-Scale Signals Part 2 (Small scale)
by Fluegelmeister 07/04/2025 01:07:03(UTC)
New Toporama Video - Z-scale Signals! (Small scale)
by Fluegelmeister 10/03/2025 04:36:10(UTC)
Manual enter linked signals into the CS3? (Digital)
Belarus Nick_40034 13/02/2025 10:22:05(UTC)
info on distant signals with Rocrail (Model railroad software)
by fabstar68 11/02/2025 20:48:24(UTC)
Marklin or Viessman signals (General MRR)
by obb_taurus 13/01/2025 20:33:03(UTC)
External power supply for Märklin signals (General MRR)
by micknudsen 19/12/2024 21:30:03(UTC)
Static signals......supplier for Z gauge (Small scale)
by spinnerguy 12/12/2024 19:14:54(UTC)
dcc brake signals & marklin cs3 (Digital)
by fabstar68 12/06/2024 19:27:49(UTC)
C track signals (Digital)
by joyofmarklin 31/05/2024 19:46:52(UTC)
Marklin Semaphore Analog Signals (H0-scale)
by MALAVIKA 30/05/2024 14:45:23(UTC)
Automatic signals and braking without CS3 (Digital)
by intveltr 21/05/2024 02:48:31(UTC)
Connection of Fleischmann Signals to Märklin Systems (H0-scale)
by Eddie7979 18/05/2024 03:24:27(UTC)
Question about Marklin Semaphore Signals (H0-scale)
by WetterauSüd 13/05/2024 05:01:18(UTC)
switching Märklin Semaphore wingsignals with INFRARED gates (H0-scale)
by Holz1 25/04/2024 14:24:55(UTC)
Can Marklin signals work with the c-track from Trix? (General MRR)
by Sniklz 25/01/2024 23:35:50(UTC)
Light Signals (Track plans)
by PhilipS 04/01/2024 23:09:23(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
76442 braking module and 7649x signals (H0-scale)
by fabstar68 26/12/2023 23:44:25(UTC)
Set signal read after train passes with 7649x signals (H0-scale)
by fabstar68 26/12/2023 01:02:24(UTC)
New layout with C & K track. Will older M signals work? (Digital)
by matiSon 23/11/2023 02:53:09(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
viessmann signals multiplexer (Digital)
by Alfred Bugeja 20/08/2023 09:22:45(UTC)
where to put signals (H0-scale)
by heinrichhess 28/07/2023 21:39:03(UTC)
Use of Signals instead of Stop Markers in Train Controller (Model railroad software)
by garben 19/05/2023 20:18:57(UTC)
Question about Marklin signals (Digital)
by MegaExo 14/03/2023 18:58:43(UTC)
signals with yellow light (Digital)
by Mille 06/02/2023 04:15:35(UTC)
Signals and Ecos (Digital)
by cintrans 22/01/2023 14:06:59(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
How to mount analog signals to table? (H0-scale)
by Brian_BR96 06/10/2022 02:44:03(UTC)
Programming 763xx signals with CS3 help. (Digital)
by luckas 26/08/2022 15:57:31(UTC)
What do you control yours turnout and signals? (Digital)
by Goofy 11/07/2022 08:35:18(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New Marklin Digital Signals, any Online Primers or Guides? (Digital)
by 5HorizonsRR 29/05/2022 21:50:03(UTC)
Vintage signals, digital power and led bulbs (Model railroad wiring)
by BenP 08/05/2022 00:14:22(UTC)
Viessmann Regular or Multiplexer signals (in a computer controlled layout) (Digital)
by pmgsr 24/04/2022 21:21:35(UTC)
Circuit Track - HO K Track Configuration with Signals (H0-scale)
by rfeist 09/04/2022 20:58:07(UTC)
Cosmetic signals for CS3 (General MRR)
by Pasquiles 07/04/2022 23:16:09(UTC)
Advanced signals (General MRR)
by Thewolf 09/12/2021 04:01:46(UTC)
Signals in storage yard (Prototype)
by DaleSchultz 02/08/2021 00:05:41(UTC)
Viessmann signals with ESU SignalPilot and CS3 (Digital)
by swisslocofan 26/05/2021 23:56:39(UTC)
Märklin Model Signals Illustrated Handbook No.0341 (Collector's Corner general)
by phils2um 10/05/2021 01:45:00(UTC)
This page was generated in 0.485 seconds.
