MS2
Offline HO Collector
#1 Posted : 14 April 2019 17:34:24(UTC)
HO Collector
Afternoon all
Cleaning more locos and trying to run some on the new MS2 ended with limited success.
I was trying to register the Borsig 3602 but had no luck, tested the loc on an analogue track and it did work so I know that the loc is fin.
The MS2 did not find the loc so I have tried to log it manually. The loc address is 07 (dip switches, so I guess that it is MM coding switches") but I could not get a "0" in the address field of the MS2, only a "7". I did try with "7" but nothing did happen. Then I have tried to load from the data base using the model No. 3602 but nothing. The address should be factory set as I have the loc from new and have never change it, yet I wanted to check by opening the tub but could not find a way, any hints? Also, any ideas about the registration process? What am I doing wrong?
Ben
#2 Posted : 14 April 2019 18:02:37(UTC)
For a 3602 i would expect the factory set address to be 53 as it is a full digtal loco, not a Delta. The Marklin standard was to have the first two digits of the loco class as the factory set address, so this being a Br53 I would expect the address to be 53.
#3 Posted : 14 April 2019 18:08:18(UTC)
Hi Ben,
The tender comes apart by taking out the screws holding the bogies. Check that the address DIP switches are set to what you think they should be.
I have found that the "Find Loco" process doesn't always find locos, and it's possible that the MS2 could benefit from a default reset. Try resetting the MS2 and then doing a manual entry.
For the manual address entry you use the + and - keys to set the address, so if you are trying to enter digits individually there's something you're not doing right.
Good luck!
#4 Posted : 14 April 2019 18:48:53(UTC)
HO Collector
KiwiAlan
Thanks. Will try with 53.
Thanks for the tip about the tender.
A default reset? The unit is new from the box, never been used before.
I have used the -/+ keys but had no '0'.
Thanks you guys.
Ben
A light bulb moment. Is the '0' comes after the 9? I need to check, that might be the answer.
Offline Rwill
#5 Posted : 14 April 2019 19:12:39(UTC)
Rwill
CS2 agrees with MS2 that the default address should be 7 which corresponds to dip switch on at 2,5 and 7
#6 Posted : 14 April 2019 20:24:03(UTC)
OK, they must have decided they filled up the address space then.
#7 Posted : 14 April 2019 21:23:05(UTC)
Originally Posted by: HO Collector Go to Quoted Post
KiwiAlan
Thanks you guys.
Ben
I don't follow what you mean. When you are setting up the new loco entry, after you specify the DIP switch selection, you are then prompted for the address. It starts with default address "1" on the screen. If you press the "+" button six times you will get to address "7". That's it, you've set the address to 7, or 07 as it is written in 2 digit format. You don't need to enter a preceding zero, nor is there any way to do so.
Once you have address 7 selected you press OK and it goes on to prompt you for the loco name, with the default "ABC" showing on the screen. After that you enter the pictogram and then the setting up is finished.
If this is not working then there may be a fault in the decoder.
#8 Posted : 15 April 2019 21:58:46(UTC)
HO Collector
Hi RayF
Thanks very much. What you described is exactly what I have done, the loco didn't want to move and lights didn't come on. Will try again and see just in case I've done something wrong. In any case I want to upgrade to sound so will not lose much sleep over a faulty decoder.
Thanks again
Ben
#9 Posted : 19 April 2019 20:27:30(UTC)
HO Collector
Good evening and Happy Easter to you all.
All trains that refused to move are now in motion, yet one of them has a strang symptom that I don't understand. it is the 3471 TEE Delta. The lights will not stay on when the loc is not in motion, i.e. the MS2 even does not allow the option (I guess) as I don't get the bulb symbol or even any 'F' buttons.
Any ideas?
Ben
#10 Posted : 19 April 2019 20:31:54(UTC)
Good evening all and Happy Easter to you all.
Any ideas?
Ben
Hi Ben,
This is normal behaviour for older Delta locos. It imitates the way the lights work in analogue mode, ie. Lights on when train is moving.
The MS2 will not show any functions for Delta locos selected from the database.
#11 Posted : 20 April 2019 21:41:34(UTC)
HO Collector
Thanks. Good to know as I have another Delta loco.
MS2 - Backspace? (Digital)
by dave55uk 26/12/2025 22:18:41(UTC)
Multiple MS2s connected to the same gleisbox (Digital)
by osoraku 26/12/2025 19:28:29(UTC)
Something better than MS2 but cheaper than CS3 - does this exist? (Digital)
by scraigen 19/11/2025 16:40:40(UTC)
MS2 with new update version at 5.3 (Digital)
by Goofy 28/10/2025 19:31:12(UTC)
60113 trackbox - MS2 stuck on Marklin (Digital)
by applor 23/10/2025 00:10:01(UTC)
Macro commands for the MS2 (Digital)
by revmox 20/10/2025 01:19:51(UTC)
MS2 and wireless MS update (Digital)
by paulcushing 09/10/2025 00:06:38(UTC)
CS3/CS2 minor update - New GFP-Update to v3.96 and MS2 v5.3 (Digital)
by jonas_sthlm 18/09/2025 09:18:21(UTC)
MS2 won't power up except connected to CS2 (H0-scale)
by applor 29/06/2025 08:14:07(UTC)
V160 loco not running with MS2? (Digital)
by LA2019 26/05/2025 02:17:38(UTC)
ms2 question (Digital)
by jmg 11/04/2025 16:36:15(UTC)
Updating a MS2 via a MSW - is it possible? (Digital)
Belarus Minok 24/03/2025 00:41:53(UTC)
Driving MFX locomotives without CS 2/3 or MS2 (Digital)
by bobyAndCo 20/03/2025 21:47:22(UTC)
Gleisbox-only operation (without MS2/CS2/CS3) - Testers wanted (Digital)
by osoraku 22/01/2025 11:46:45(UTC)
Dual Traction Marklin Ms2 (H0-scale)
by DDAM1ANN 03/12/2024 20:52:47(UTC)
Märklin has released downgrade today CS3/MS2 (Digital)
by jonas_sthlm 19/11/2024 16:45:24(UTC)
MS2 and MS2 WLAN (Digital)
by Aussie Mark 17/11/2024 07:25:48(UTC)
MS2 (60657) correct version today? (Digital)
by Goofy 12/10/2024 07:38:54(UTC)
MS2 update help in St. Louis (Digital)
by Slylock3 19/07/2024 07:38:15(UTC)
MS2 automatically going to "stop" mode (General MRR)
by impulsetaco 01/07/2024 05:32:44(UTC)
MS2 “only possible at main device“ message (Digital)
by Slylock3 16/06/2024 08:20:34(UTC)
MS2 vs CS3 (Digital)
by sfophx 16/06/2024 06:45:54(UTC)
CS 3/3+ UPDATE 2.5.2(6) & MS2 4.13 is now Online (Digital)
by jonas_sthlm 29/02/2024 15:11:35(UTC)
Help with Roco loco vs MS2 (General MRR)
by The Crocodile 16/01/2024 19:29:01(UTC)
Reset loco to default using MS2 (Digital)
by Alex H 10/10/2023 20:17:50(UTC)
MS2 Breakdown (Digital)
by Alex H 26/09/2023 16:06:07(UTC)
how Do I double header trains MS2 (H0-scale)
by heinrichhess 15/09/2023 11:32:46(UTC)
Need updates for my MS2 Controller- Fort Wayne, Indiana (Digital)
Belarus vnangli 10/09/2023 19:33:14(UTC)
MS2 (last update) problem after pushing STOP button; HELP (Small scale)
by RhbFan079 11/08/2023 15:37:58(UTC)
MS2 place switch (H0-scale)
by heinrichhess 07/07/2023 15:11:39(UTC)
MS2 language stuck (H0-scale)
by revmox 24/06/2023 04:40:00(UTC)
MS2 WLAN memory are limited? (Digital)
Belarus Goofy 11/06/2023 10:38:17(UTC)
Steps to add CS3 into a system running MS2 (Digital)
by Cmondialo 15/04/2023 01:09:17(UTC)
MS2 3.55 and trouble registering 39771 (E71) (Digital)
by aclassifier 26/03/2023 16:38:58(UTC)
Trix 185/Traxx 2 22656 not recognised in ms2 (Digital)
by Vic 04/03/2023 13:26:16(UTC)
HELP needed - MS2 reset (UK) (Digital)
by rugauger 29/01/2023 16:42:57(UTC)
Big scale - WLAN MS2 - dead rail idea ;-) (Big scale)
by Purellum 28/01/2023 22:00:38(UTC)
MS2 replacement power supply (H0-scale)
by revmox 23/01/2023 23:30:41(UTC)
Loco 244389 with MS2 (H0-scale)
by Johan 28/12/2022 13:25:49(UTC)
Roco 78293 will not run (MS2 3.55) (Digital)
by aclassifier 27/12/2022 12:25:59(UTC)
Connecting MS2 to three different layouts (Digital)
by Twinrover1965 16/12/2022 11:15:42(UTC)
Removing MS2 blank spaces (Digital)
by baggio 24/11/2022 06:51:28(UTC)
Using MS2 to control Brawa LOK with Brawa Premium-Digitaldecoder version 3.0 (Digital)
by Johnny rum rider 20/11/2022 14:20:16(UTC)
MS2 (Digital)
by mrunix 17/11/2022 20:17:54(UTC)
Märklin my world - "TGV" Starter Set 29306 - MS2? (Digital)
by mramstedt 29/10/2022 19:17:41(UTC)
How many locos can be powered by 60116 (MS2) (Digital)
by einotuominen 25/09/2022 15:48:39(UTC)
Setting up 6021 with MS2 (Digital)
by GenDemo 02/09/2022 01:20:52(UTC)
37116 MS2 help please? (H0-scale)
by Pismono 11/08/2022 20:20:57(UTC)
Mobile Station 2 update from V1.1 fails from MS2 or 3 (Digital)
by gcanton 30/04/2022 17:30:56(UTC)
MS2 29000 - Instructions?! (Digital)
by Michanglais 22/04/2022 09:56:37(UTC)
This page was generated in 0.513 seconds.
