Offline osoraku
#1 Posted : 26 December 2025 19:28:29(UTC)
osoraku
Dear All -
A few weeks ago, dave55uk mentioned an interaction between two MS2s that I'd never heard of previously. He said,
3. Yes, you can connect a second MS2 to the trackbox, as I have done. One of them will be the 'Master' and operate normally.
The other one will be the 'slave' and when you select a loco, there will be a short pause, then it will load the details for that
loco from the 'Master'. Then you're good to go. And yes, both controllers can have the same loco selected and you can control
that loco from either controller.
The 'Master' will be the one with the LOWEST serial number - the bottom number on the silver sticker on the back of the MS2.
I would like to know the digital details of this interaction. By digital, I mean that the only way that the two MS2s can communicate is over the CAN bus connecting them to the gleisbox that they are both attached to. Consequently, there must be undocumented commands in Marklin's CS2 protocol that allows one MS2 to query the other to download loco information (name, address, protocol, etc.) I'm familiar with the public documentation for the CS2 protocol, but this interaction is not described anywhere in it.
Does anybody have a CAN bus trace of this happening that they could share? Or a link to another forum where it is described? I would like to incorporate it into a program that I'm developing to run my own layout.
Osoraku
thanks 2 users liked this useful post by osoraku
Offline dave55uk
#2 Posted : 26 December 2025 22:12:55(UTC)
dave55uk
Watching this even though the digital details will be way above my head LOL
thanks 2 users liked this useful post by dave55uk
Offline dsinn
#3 Posted : 07 January 2026 18:31:56(UTC)
dsinn
Originally Posted by: osoraku Go to Quoted Post
Dear All -
Osoraku
Would that not be the same thing that happens with the new MS2 software connecting to a CS2/CS3? Upon boot they resync from the "master" the set of loco's they are aware of and recopy down the settings of each. Or put another way, they are just re-adding the loco's from the "master" so they have the most current settings for each loco they are configured with.
thanks 1 user liked this useful post by dsinn
Offline osoraku
#4 Posted : 09 January 2026 14:39:05(UTC)
osoraku
Dear dsinn -
Yes, you're right that the only way an MS2 plugged into a CS2/CS3 can interact is over the CAN bus. Hence the CS2 protocol governs their loco data exchange too. However, that part of the protocol is not completely documented by Marklin, particularly "Anfordern Config Data" (0x20) and "Config Data Stream" (0x21). (Some old threads on the topic are in this forum, but lack details.) I'm observing the interactions between MS2s and figuring out how it works. When done, I hope to distill what I found and report how this works here. (Unless you already know and can spare me the effort of working it out!)
Osoraku
Edited by user 15 January 2026 11:14:04(UTC)  | Reason: Used correct codes not CAN IDs
Offline osoraku
#5 Posted : 14 January 2026 19:43:39(UTC)
osoraku
Dear All -
Here's a brief summary of the MS2 - MS2 interaction. For full details (annotated trace of the exchange), see the attachment. Recall that all of the devices are attached through the CAN bus connecting them to the CS2/CS3 or to a Gleisbox.
A key command used by the MS2s (probably CS2/CS3s, too) is the "Anfordern Config Data (0x20)" command (ACD for short henceforth). The ACD command is followed by a response as a "Config data stream (0x21)" that all other agents connected to the CAN bus can read and use to update their internal state. Hence, the config data stream is never flagged as a response packet according to the Märklin CS2 v 2.0 protocol document.
The boot process starts with the master MS2 (lowest serial number MS2) issuing a CAN BOOT command. The Gleisbox responds. A SYSTEM STOP is issued, presumably for safety. Then another slightly different CAN BOOT command is issued to the Gleisbox to tell it to start.
The master MS2 sends a PING to discover other MS2s, followed by another general CAN BOOT and SYSTEM STOP. Then the master queries the other MS2 about its onboard files (an ACD "ms2-conf" inquiry). The ACD response is a config data stream labeled [config]. Next, the master MS2 asks the other MS2 what files it has (akin to a Windows dir command / Unix ls command). The response is a [files] data stream.
Loco information can only be changed on the master MS2. When it is, it is automatically rebroadcast to all other devices by a config data stream with the [lokliste] identifier.
When a loco is selected by an MS2 that is not the master, it asks the master for an update of the loco's properties. This interaction is an ACD inquiry for "lokinfo xxxx" where xxxx is the loco name. The response is a config data stream labeled, [lokomotive]. It contains all the info about the loco (name, functions, MFX UID, etc.)
The [config], [files] and [lokliste] are not documented data streams. [lokomotive] is, however, in Sec. 8.1 of the protocol document.
Sorry, not so brief (but compared to the attachment, it is).
Osoraku
Attachment (updated 8 Feb. 2026): v3 MS2-MS2-log.pdf (56kb) downloaded 1 time(s).; v2 MS2-MS2-log.pdf (55kb) downloaded 7 time(s).; v1 MS2-MS2-log.pdf (54kb) downloaded 8 time(s).; v0 MS2-MS2-log.pdf (55kb) downloaded 14 time(s).
Edited by user 09 February 2026 18:22:23(UTC)  | Reason: Another attachment update
thanks 6 users liked this useful post by osoraku
Offline osoraku
#6 Posted : 15 January 2026 12:41:04(UTC)
osoraku
Dear All -
FYI, here are the guts of a 60122 used to connect up to 5 MS2s to one gleisbox DIN10 outlet. Not much inside except for connectors. It is a CAN bus expander, essentially.
Osoraku
Edited by user 22 January 2026 03:44:17(UTC)  | Reason: Not Aston Martin, Deutsches Institut für Normung!
thanks 3 users liked this useful post by osoraku
#7 Posted : 21 January 2026 22:47:07(UTC)
FYI, here are the guts of a 60122 used to connect up to 5 MS2s to one gleisbox DIN9 outlet.
I would caution against using the term expander, certainly without context.
And also ensure that the term "CAN bus" is not used in the fuller context of the "System Bus" cabling for Central stations
A few initial points
* the 60122 will not work directly with a CS2/CS3 - as it picks up/passes on its power differently
** similarly plugging a 60122 into another 60122 will not work (You may have one in each of the TrackBox's 2 x 10pin device ports)
* the CAN bus (usually 2 wires) is incorporated in System Bus , which also accommodates a sync signal (TrackSync/RailSync(sic) ) for boosters.
The main point being that the CAN bus needs correct termination at each end.
"Devices" - e.g. (Mobile Stations, L88, 6021-Connect, Booster) may tap onto the bus in such a way that they do not upset the quality of the main bus signal. And the length of that connection is restricted and nothing like the 100m of the main CAN-bus as specified.
Sorry, if the above is off topic for the OP. (Marklins command implementation over the CAN-Bus Master<>Slave )
In that discussion, I cannot add anything other than to agree with interest.
However, related, there has been much expectation/hope in some quarters that Marklin would provide
a) devices for the MS2 like a CAN-bus connected 7072/Keyboard for accessories
b) a supported configuration for direct Booster connection. (The cable plugs might be a show stopper but the wires are there)
Most of this is just software, and I note FWIW, that a number of years ago one version of MS code had a setting referencing "Booster" that didn't appear to do anything and disappeared in the next release.
Offline osoraku
#8 Posted : 04 February 2026 18:11:14(UTC)
osoraku
Dear All -
The log (attached above) of the information passed between the two MS2s attached to the same Gleisbox includes a Config Data Stream whose title is "[lokomotive]". This is mostly described in the CS2 Protocol document, section 8.1.3 and an example is shown in section 8.4.
The MS2's data stream includes some other fields, particularly one labeled ".fkt2" with subordinate fields "..typ2", "..dauer2" and "..wert2". If anybody knows what these are specifically (other than their being some additional loco function information), please point me at the appropriate references/code using them.
Signed, Puzzled
(Osoraku)
Later added note: This is an informed guess based on a list of functions given in the documentation of a 39468 and the Config Data Stream from an MS2 that registered it.
The .fkt series documents the first 16 functions (F0-F15) available on older controllers (CS1, MS1). The .fkt2 series documents the extensions beyond F15 to F16-F30 that new controllers (MS2, CS2, CS3) can actuate. So for a modern controller, .fkt and .fkt2 give the full set of loco functions that may be operated.
Edited by user 05 February 2026 19:49:31(UTC)  | Reason: Described informed guess
This page was generated in 0.301 seconds.
