Offline Winst0n
#1 Posted : 27 January 2004 17:17:35(UTC)
Winst0n
Hi everyone, Cool
I'm thinking of buying a track cleaning car, to regularly clean my track in hard to reach places like tunnels etc.
Some of my locomotives behave jerky on dirty spots when running slow.
What kind of track cleaning car do you use and does it work well on c-track ?
Winston
Offline dikken
#2 Posted : 27 January 2004 18:52:51(UTC)
dikken
If you can get your hands on a 'schienenboy', your well off.
Unfortunately This one doesn't work well on turnouts.
Dikken
Check out my site:
http://www.modelspoorhobby.be
Offline rschaffr
#3 Posted : 27 January 2004 21:43:29(UTC)
rschaffr
I use the Lux track cleaning car. I am generally pleased with it. I had a problem on turnouts and on the sharper curves because it had an enormous pickup shoe as originally equipped and would short out. I replaced the shoe with a shorter Marklin one and solved that problem.
I am less satisfied with it in the catenary cleaning mode. You have to get the tension just right or the rotating polisher will flip the car on it's side.
-Ron
Offline Thanos
#4 Posted : 28 January 2004 09:27:06(UTC)
Thanos
This topic has been discussed before so check out the following forum topic:
https://www.marklin-users.net/fo...archTerms=track,cleaning
Continuing from those topics has anybody tried the Marklin 46010 Anniversary Track Cleaning Car for Insider members?
Thanos
Offline dikken
#5 Posted : 28 January 2004 10:30:38(UTC)
dikken
I'c got the anniversary cleaning car in order. Tests will be done as soon as i get it from my supplier. I will inform!
Actually, i'm using the roco- clean wagon. As long as you dont have to cross turn-outs, it works fine.
dikken
Dikken
Check out my site:
Offline Thanos
#6 Posted : 28 January 2004 11:27:26(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:I'c got the anniversary cleaning car in order. Tests will be done as soon as i get it from my supplier. I will inform!
Cool!biggrin I really need some feedback because I sort of believe that the one who creates the tracks knows how to clean them - so the 46010 might be the best way to clean Marklin tracks.
Thanos
Offline tnx jake
#7 Posted : 28 January 2004 16:35:10(UTC)
tnx jake
I have the anniversary track cleaning car and have run some tests. It seems to work very well. The cars seem a little light and I am considering putting some weight in them to give them a little more stability and pressure against the track. However, too much pressure might be trouble on turnouts. I also have used the Centerline track cleaning cars which I discussed in the topic shown in Thanos' posting.
Jack
Offline Zack
#8 Posted : 29 January 2004 02:38:05(UTC)
Zack
Trix offers item #24050 track cleaning car in 2004 (70 0150 ~wheels). It looks almost identical to the ones offered in the insider club ... same chassis and cleaning pads!
Offline Thanos
#9 Posted : 29 January 2004 09:01:29(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:I have the anniversary track cleaning car and have run some tests. It seems to work very well.
[size=1" face="Verdana" id="quote]quote:Trix offers item #24050 track cleaning car in 2004 (70 0150 ~wheels).
Thanks for the info guys!biggrin
Thanos
Offline Winst0n
#10 Posted : 29 January 2004 15:45:24(UTC)
Winst0n
Thanks for all the information !
Think i'll go for the Trix, now just wait untill it shows up in the stores.
Offline rschaffr
#11 Posted : 29 January 2004 16:41:15(UTC)
rschaffr
According to the LokShop, the Trix 24050 won't be available until the third quarter 2004
-Ron
Offline Frostie
#12 Posted : 29 January 2004 22:58:39(UTC)
Frostie
The Trix Track Cleaning car has a pad that is set up to clean the two rails. Is there any requirement to clean the center rail ?? Or does the pickup shoe constitute a self cleaning feature ??
CS/MS Digital Era 1/2
Offline dikken
#13 Posted : 31 January 2004 14:34:12(UTC)
dikken
Hey,
does anybody has any experience with the Centerline railcleaner?
dikken
Dikken
Check out my site:
Offline tnx jake
#14 Posted : 31 January 2004 16:54:21(UTC)
tnx jake
Hi Dikken,
Yes, I have. I use two of them in tandem. The first car is "wet" with whatever cleaning agent you use. I use lighter fluid. The second one is dry to pick up the residue from the first. This is the best combination I have tried and I have tried many. The track gets clean. My suggestion is that you do it on a regular basis. If there is a lot of build up, no track cleaning car will get it totally clean. I am using C track.
Jack
Jack
Offline dikken
#15 Posted : 31 January 2004 19:07:54(UTC)
dikken
Hi Jack,
thanks for the info. I suppose you have the marklin version. Is the roller specially grooved? How does it passes the turnouts? If it is a flat surface, I suppose it looses all contact with the rails as it is beeing lift up by the centerrail? Do the cleaningpads wearout quickly in the middle (friction with the studs of the centerrail)?
I Know , a lot of questions. I dont want it to become another waste of money.wink
greetz, dikken
Dikken
Check out my site:
Offline tnx jake
#16 Posted : 31 January 2004 20:41:44(UTC)
tnx jake
Hi Dikken,
Yes I have the Marklin version. It is not groved, but the pads are put on in such a way that they do not loose contact with the rails on turnouts. The pads are a type of cleaning rag that we use here in the US available at any market. Called Handi-Wipes. You must have same or equivalent in Belgium. Quite a bit of it comes with the car, so you don't need to buy very soon. Does not tear or rip over studs. You can wash them and use them again if you wish. It is very simple and uncomplicated, but it works. Take it from a guy who tried everything from Lux to Rocco. This works the best for me. Again, I don't know what track you are using so if you are using K or M I can't comment accurately.
I am leaving for the airport for Germany and the Toy Fair so I won't be able to respond further for about a week.
Jack
Offline verheyen
#17 Posted : 03 February 2004 02:17:41(UTC)
verheyen
I have the Herkat <http://www.herkat.de> track cleaning cars and run them in tandem, the rubber disk first, then the wet cleaner. This order removes some of the stuff on the tracks first, meaning the wet cleaner has less work... At least it seems to work better that way. In any case, I've VERY happy with them. Try not to run over the cleaned track until it is dry though. I've seen my strongest engine spin its wheels due to the slipperyness.
Offline dikken
#18 Posted : 20 February 2004 20:17:19(UTC)
dikken
biggrinbiggrinbiggrinbiggrinbiggrinbiggrin
I've just bought 2 centerrail trackcleaning cars. The tests are wonderfull. As adviced, I us one with cleaning fluid (isopropanol) eand the other dry. The cleaning effect is astonishing. After a couple of passes a slight black line becomes visible on the dry pad. This means only one thing : it works.
Furthermore, there are no problems on turnouts. Al passes smooth.
Thanks for the good advice Jack
greetz
Dikken
Check out my site:
Offline tnx jake
#19 Posted : 24 February 2004 04:04:54(UTC)
tnx jake
Dikken,
You are welcome. Glad that you found them as I did!
Jack
Offline usbeauty
#20 Posted : 24 February 2004 07:14:36(UTC)
usbeauty
I am curious, dikken.. where did you find the centerline cars? In a store in Belgium or on the web?
Bruce
Modeling the Bruxelles - Nord to Knokke - Heist line on my layout, complete with pommes frites stand (frituur). (Epoch IV, digital and analog)
Offline usbeauty
#21 Posted : 24 February 2004 08:47:18(UTC)
usbeauty
And Jack, do you remember where you got yours?
Bruce
Offline dikken
#22 Posted : 24 February 2004 13:03:24(UTC)
dikken
[size=1" face="Verdana" id="quote]quote:Originally posted by usbeauty
<br />I am curious, dikken.. where did you find the centerline cars? In a store in Belgium or on the web?
Bruce
hi bruce,
WWW.softlok.nl supplies part of europe. Centerline is American so I guess you'll find them in some shop or webshop nearby!
greetz
biggrin
Dikken
Check out my site:
Offline tnx jake
#23 Posted : 24 February 2004 15:57:01(UTC)
tnx jake
Bruce,
Try <u>RJFtrains.com</u> He is located in New York state.
Jack
Offline usbeauty
#24 Posted : 24 February 2004 17:49:07(UTC)
usbeauty
Thanks both of you - I've been trying RJF with no luck.
Bruce.
Offline tnx jake
#25 Posted : 24 February 2004 20:34:59(UTC)
tnx jake
Offline Winst0n
#26 Posted : 28 April 2004 00:52:30(UTC)
Winst0n
Some time has gone by since I've opened this topic., in the meantime I managed to get hold on an insidere aniversary cleaningcar, luckily for me my local dealer had one for saleSmile...
The cars work well for me, after some cleaning runs on the track thev've picked up al lot of dirt, so no jerky-behaving loco's anymoreCool
I can imagine it won't remove greasy stuff because it doesn't use cleaning fluid, but overal I'm very satisfied with the cars.
Winston
Offline rschaffr
#27 Posted : 28 April 2004 02:17:57(UTC)
rschaffr
Since this thread started, I have re-evaluated my position. I still use the Lux car...it really polishes the rails, but I have added a CenterLine car to my cleaning consist. Now just to save up for the Lux vacuum car and I'm in good shape.
-Ron
Online xxup
#28 Posted : 28 April 2004 12:46:34(UTC)
I have ordered two TRIX 24050 Cleaning Cars with replacement AC wheel sets from my dealer. They look similar to the Insider car. I'll let you know how well they work, if anyone is interested.
Offline oz_train
#29 Posted : 29 April 2004 01:44:00(UTC)
oz_train
Hi Adrian,
[size=1" face="Verdana" id="quote]quote:I'll let you know how well they work, if anyone is interested.
YES, I'm definitely interested - especially in a good solution which would be available domesticallywink
Online xxup
#30 Posted : 25 October 2004 14:02:06(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by oz_train
<br />Hi Adrian,
YES, I'm definitely interested...
The new Trix cars arrived last weekend - complete with A/C wheels.. As you can see in the picture below, they look a little bit like the Insider cars. The doors over the bins open, just like the Insider cars.
They come with heaps of extra cleaning wipes, but like the Insider cars they cannot clean the center rail. I have added 4 lead fishing sinkers to each wagon, as they are lighter than the Insider cars. No problems on M-track or turnouts. The little loco easily pulls both cars up the 4% incline to the mountain..
Recommended.. While I do agree that they are no substitute for the centerline cars for dirty tracks, these cars keep clean tracks clean.
Edited by moderator 10 January 2011 20:28:39(UTC)  | Reason: Not specified
Offline laalves
#31 Posted : 25 October 2004 14:20:16(UTC)
laalves
In the other side of the world, but I'm using a similar solution to you: a 37654 plus the insider version I got on ebay....
Luis
#32 Posted : 25 October 2004 14:27:34(UTC)
Always thought it never rains in Australia but looking at that Lady in Yellow ... biggrin
Online xxup
#33 Posted : 25 October 2004 14:34:07(UTC)
<br />Always thougt it never rains in Australia but looking at that Lady in Yellow ... biggrin
Actually, it is supposed to be Switzerland.. Actually the only flat place in Switzerland that has a Gum tree on the far side of the mountain (that Miss 5 does not want me to show here)..
In Australia we drive our cars on the right wink side of the road..
#34 Posted : 25 October 2004 14:56:24(UTC)
Oh well, Switzerland - they really have lots of that stuff ... [xx(]
Offline dikken
#35 Posted : 25 October 2004 17:35:13(UTC)
dikken
I recently received my MArklin 10-year-membership trackcleaning cars. Not satisfied at all with them. The de-rail on turnouts and they continuously loose their cleaningpads. A Wast of money. Maybe, When I try to raise their weight it will be more succesfull?
Dikken
Check out my site:
Offline Davy
#36 Posted : 25 October 2004 18:52:30(UTC)
Davy
I have the Trix cleaning car and I have with the M-rails of my track no trouble what so ever.
M-track with a CS2.
Offline laalves
#37 Posted : 25 October 2004 21:00:08(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by Davy
<br />I have the Trix cleaning car and I have with the M-rails of my track no trouble what so ever.
Mine is cleaning C track rails with standard and slim turnouts, double and curved turnouts with no problems either.
Luis
Offline rschaffr
#38 Posted : 29 October 2004 00:10:32(UTC)
rschaffr
Last week I got a set of the Noch cleaning pads that hook on to the wheels of any 2-axle wagon. I saturated a pad with Goo-Gone and ran it around my C-track layout a couple of times. Worked great! Inexpensive, too. You get five units on the card for Noch. I don't have the Noch number here at the moment but these things work pretty good.
-Ron
Offline Nuno
#39 Posted : 29 October 2004 21:14:58(UTC)
Nuno
Hi Ron
I also got the Noch pads, but haven't tried them yet. What kind of fluid shall I use? What is Goo-gone? Can you tell me of something that I can easily find?
Nuno Smile
Offline rschaffr
#40 Posted : 29 October 2004 21:52:03(UTC)
rschaffr
Hi, Nuno. "Goo Gone" is a cleaning solvent that dissolves grease and picks up dirt. I don't know if it is available there. Here is their web site: http://www.googone.com/products_gg.shtml
It is a citrus based tar and gum dissolver..I'm sure you have an equivalent product available if this brand is not. Check in the household cleaning section of your store. I sometimes use lighter fluid for track cleaning, also. I don't know how that would work with the Noch pads since they are on a plastic base, but it works well with my Centerline car.
I put the GooGone on the pad and ran it once around my new C-track and the pad turned black with the stuff it picked up. Really amazing that there was that much dirt on new track.
I have spent a good deal of money trying to find a solution to dirty track in my hidden areas (Lux, Centerline), but this is a good and really inexpensive solution.
-Ron
Offline Tamrac
#41 Posted : 30 October 2004 00:05:02(UTC)
Tamrac
Ron,
Where did you purchase them from.
I have a posting in the HO forum called "NOCH Cleaning Car"
But the part number is not in there.
I have been having trouble finding these.
Offline Tamrac
#42 Posted : 30 October 2004 00:09:32(UTC)
Tamrac
[size=1" face="Verdana" id="quote]quote:Originally posted by Tamrac
<br />Ron,
In September I posted in the HO forum "NOCH Track Cleaner"
Offline rschaffr
#43 Posted : 30 October 2004 04:11:33(UTC)
rschaffr
Tamrac:
Got them from the Lok Shop. I believe the Noch number is 60157. I am not at home this weekend. I will check my invoice Sunday when I get there, but I'm pretty sure it's 60157. ETS also carries them. http://www.modelleisenbahn.com
-Ron
Offline drstapes
#44 Posted : 31 October 2004 03:29:30(UTC)
drstapes
The only track cleaning car I have seen in the UK was one by roco. It had a heavy abrasive pad underneath which caused the car to be derailed too often on points (turnouts) to make it useful.
The liquid cleaners sound a bettrer bet, anyone know of soumthing available in the UK.
Geoff (UK)
Help with Marklin Track Cleaning cars (H0-scale)
by jimwallace1652 11/04/2024 23:55:53(UTC)
Marklin HO 46049 Track Cleaning Car 3-Rail (General MRR)
by mjborelli 19/02/2023 23:19:59(UTC)
Track cleaning car comparison - Lux vs Dapol (H0-scale)
by Minok 10/03/2019 22:46:06(UTC)
LUX Track Cleaning Car 9130 (Reviews of rolling stock)
by PMPeter 13/12/2018 22:34:32(UTC)
Marklin Track Cleaning Car (Small scale)
by BillO 02/11/2016 03:05:17(UTC)
Track Cleaning Car (H0-scale)
by Jabez 12/09/2016 23:23:57(UTC)
Marklin German Track Cleaning Car of the DB (H0-scale)
by baggio 28/03/2015 18:08:24(UTC)
Can anyone identify this track cleaning car? (General MRR)
by kc6uvm_George 21/11/2012 20:33:27(UTC)
Cleaning Track Pads on 46042 Track Cleaning Car (General MRR)
by petestra 20/03/2012 16:16:37(UTC)
by swanpondwv 19/12/2011 01:53:43(UTC)
ANY GOOD Z SCALE TRACK CLEANING CARS (Small scale)
by darticus 09/12/2010 02:18:44(UTC)
Track Cleaning Cars (H0-scale)
by Ranjit 21/10/2009 22:50:07(UTC)
Home madeTrack Cleaning Car (General MRR)
by FMS 31/05/2009 00:08:21(UTC)
Track cleaning cars (Small scale)
by ozzman 17/12/2008 01:21:51(UTC)
What track cleaning car would you suggest? (H0-scale)
by Eisenhower 10/11/2008 23:18:49(UTC)
46042 Track Cleaning Car (H0-scale)
by MHauge 30/11/2005 08:09:17(UTC)
Track cleaning cars (H0-scale)
by PeFu 26/09/2003 12:09:42(UTC)
This page was generated in 0.750 seconds.
