Offline fvri
#1 Posted : 04 November 2002 18:21:15(UTC)
fvri
Is there a possiblity to install a sound decoder in a Marklin loc that has already a delta/digital decoder built-in.
For example LokSound, but only the sound decoder, I still want to use the Marklin decoders.
Frank
Offline perz
#2 Posted : 04 November 2002 19:19:28(UTC)
perz
I'm quite sure that the LokSound decoder will work for sound even if it has no motor and lamps connected, so it should be possible to combine with a Märklin decoder if there is enough room for the decoder.
Offline KLB
#3 Posted : 04 November 2002 20:49:46(UTC)
KLB
I *think* that Märklin offers a sound module as a spare part<img src=icon_smile_question.gif border=0 align=middle>From all reports however the Loksound decoder is equal or better than the Märklin one.The sound of Loksound is superior to that Mä,IMHO.
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Kevin!
Offline Lars Westerlind
#4 Posted : 04 November 2002 21:16:19(UTC)
Lars Westerlind
I agree, I think it's possible to use the sound part of Loksound only. Of course, this decoder should have the same adress as the Märklin decoder etc. However, I can see no reason to keep the Märklin decoder. If you replace it, you solve the space problem, and you get the programming much easier - to adjust acceleration and the like in both decoders to corresponding values.
I'm not sure if it's straight forward to install a spare part sound card - Märklin does it like that, a sound card, connected to a decoder. Maybe a special version of the decoder is needed to get it work. Anyway, Kevin is right; Loksound always has much better sound. The only exception I've heard is Märklin diesel sound, which is almost as good as Märklins...
Lars
Offline perz
#5 Posted : 04 November 2002 21:43:31(UTC)
perz
IMHO a Märklin 6090x decoder (the motor control part) performs better than the LokPilot, so I wouldn't throw these Märklin decoders out if I didn't have to. But I have only tested the LokPilot (LokSound but without sound) in one loco so I'm no expert.
With Märklin Delta or the older 6080 decoders it is another thing. These Märklin decoders do not perform so well, but they work with AC motors. To use the decoder part of LokSound you then have to convert the motor to DC first (can be done with a HAMO magnet).
Offline KLB
#6 Posted : 05 November 2002 16:02:39(UTC)
KLB
<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote>IMHO a Märklin 6090x decoder (the motor control part) performs better than the LokPilot, so I wouldn't throw these Märklin decoders out if I didn't have to. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana" size=1 id=quote>
I agree.Since these loks run so well,I will not 'throw' them away!<img src=icon_smile_big.gif border=0 align=middle>
However,if someday I need to replace a decoder,and can fit a speaker in it,then I'll go for the LokSound.I did this in a BR86 (Delta) as perz said are horrible runners.
Lars I have not heard a LokSound diesel,but my Märklin V200 (39821) sounds fantastic!
Comparing the BR86 with the Mä dampfloks I have with sound(BR01.01&BR10),the LokSound is better,...
Kevin!
Kevin!
Offline Hans_Dietrich
#7 Posted : 06 November 2002 17:56:33(UTC)
Hans_Dietrich
Bogobit has some information on Maerklin sound modules.
http://www.bogobit.com/sound.html
Seems to me that trying to use Maerklin spare part modules may not be easy.
There are other offers:
http://www.ittsound.com/trainprod.htm
I think that the selection of sounds is somewhat limited, but affordable. Can be hooked up to the decoder output.
http://www.xtronics.com/kits/EM-105.htm
Very inexpensive but what does it do?
The Loksound approach seems the most straight forward, but at a cost.
The total upgrade (Loksound + possible DC conversion) seems to cost almost as much as a new loco with sound. For conversion info see conversion session by "Webmaster".
Some day I will try to add sound, though.
Hans
Hans ... Epoch I to V, M-track, IB with MS
Offline KLB
#8 Posted : 12 November 2002 16:04:42(UTC)
KLB
Just an FYI,check these new sound decoders:
http://www.tran.at/ <img src=icon_smile_cool.gif border=0 align=middle>
Webmaster,I'll add this to the Links&Downloads section too!<img src=icon_smile_big.gif border=0 align=middle>
Kevin!
Kevin!
#9 Posted : 12 November 2002 23:07:23(UTC)
As I understand, the CT Tran GE70 is a separate digital sound decoder that has its own address in DCC. As I also understand it follows the DCC signal itself and only works with DCC. This leads me to the conclusion that you cannot use it with a Märklin 6021 control unit. However, as I understand, with the IntelliBox you should be able to make a 2-loco "consist" with one Märklin loco and a DCC "loco" (the sound decoder) and get it to work that way.
I might be wrong, but with the minimal info about it on the site, maybe things clear up when a manual is available.
msd sound decoder (Digital)
Belarus vupti 17/11/2024 14:19:09(UTC)
Problem with Piko sound decoder 5.1 (Digital)
by Goofy 24/08/2024 07:36:38(UTC)
Marklin sound decoder bootloader/firmware update (60977) (Digital)
by dlwestphalen 08/08/2023 03:02:32(UTC)
Installing MSD3 Sound Decoder in SBB Ae 8/14 (Märklin 37593) (Digital)
by Johnvr 24/02/2023 07:46:31(UTC)
Sound decoder problems (Digital)
by Charles Farrugia 26/11/2022 16:58:44(UTC)
Conversion of the snow plow with recent loksound decoder (Digital)
by French_Fabrice 20/11/2022 18:16:17(UTC)
Which High efficiency motor retrift kit and sound decoder for Marklin ho br 218 diesel? (Digital)
by marklinist5999 21/02/2022 14:31:47(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
ESU sound decoder instructions (H0-scale)
by river6109 07/12/2021 11:36:41(UTC)
Sound decoder (General MRR)
by Vadim 01/04/2021 11:57:22(UTC)
Märklin 55741 Köf II Sound decoder (Big scale)
by pa-pauls 10/03/2021 21:53:42(UTC)
Sound decoder (H0-scale)
by gbrendem 05/02/2021 14:26:03(UTC)
A slight night mare programming a Zimo sound decoder (Digital)
by river6109 21/10/2020 04:09:12(UTC)
Problem with sound decoders 60975, 60976, 60977 (Digital)
by Best Ripper 17/09/2020 21:11:02(UTC)
Marklin Br24 sound decoder dead (H0-scale)
by fossie 08/06/2020 14:53:12(UTC)
Mfx Sound decoders having random ANNOYING issues (Digital)
by Martin T 02/04/2020 22:27:32(UTC)
CS3 sound decoder update.. Missing files (Digital)
by Nick_40034 25/02/2019 00:34:12(UTC)
60987 sound decoder problems. (Digital)
by Nonno FULVIO 11/01/2019 17:41:57(UTC)
Smoke Unit with ESU Loksound Decoder (H0-scale)
by skeeterbuck 20/12/2018 03:26:34(UTC)
4 AUX sound decoder (Digital)
by Nick2017 07/08/2018 20:20:46(UTC)
Sound Decoder (Digital)
by skeeterbuck 02/06/2018 00:01:46(UTC)
Has anyone had a problem with a Marklin sound decoder (Digital)
by dominator 30/04/2018 06:41:13(UTC)
Sound Decoder for Marklin 5579 (Big scale)
by Jaime 13/04/2018 02:23:40(UTC)
OBB 1116 - Sound Decoder (H0-scale)
by kganotop 09/04/2018 21:40:57(UTC)
sound decoders (Digital)
by river6109 20/07/2017 04:01:09(UTC)
Märklin sound decoder (Digital)
by river6109 07/03/2017 09:35:44(UTC)
Programming / Uploading sound scenes / files into ESU LokSound decoders (Digital)
by Minok 01/03/2017 00:06:32(UTC)
English Tutorial re Sound Project for mSD/3 Sound Decoder/Programming (Digital)
by Malcolm Smith 12/01/2017 02:26:31(UTC)
37184 Sound Decoder Issue (Digital)
by mb300e4m 12/12/2016 01:50:46(UTC)
Piko 96225 AC and Marklin MFX sound decoder help (H0-scale)
by danmarklinman 18/10/2016 20:22:16(UTC)
Reset Sound decoder on 39016 BR 01 (Digital)
by trainsman2001 18/05/2016 21:06:18(UTC)
Sound decoder problem (Digital)
by Inox 20/07/2015 23:33:29(UTC)
Märklin V80 (36080) Sound Decoder conversion (with Video) (H0-scale)
by Moritz-BR365 09/07/2015 08:26:52(UTC)
VT11.5 with dual sound decoders (H0-scale)
by biedmatt 27/06/2015 14:13:54(UTC)
ESU LokSound Decoder - English Instruction Booklet?? (Digital)
by Joseph Meiring 23/06/2015 21:29:22(UTC)
Märklin Ludmilla BR 232 now with Doehler&Haass Sound Decoder - Matthias Henning sound (with video!) (H0-scale)
by Moritz-BR365 03/06/2015 08:41:49(UTC)
ESU Loksound decoders for "old" V200 diesel 3021? (Digital)
by Joseph Meiring 31/05/2015 19:38:57(UTC)
Zimo sound decoder and Marklin Mobile Station 2 (Digital)
by Unholz 29/05/2015 14:45:38(UTC)
What Loksound Decoder Is This? (Digital)
by trainstamp 30/04/2015 16:04:14(UTC)
ESU Loksound Decoder (Digital)
by ice 1 21/01/2015 13:35:54(UTC)
Sound decoders in 3309 BR85? (Digital)
by Joseph Meiring 22/10/2014 23:19:56(UTC)
suitable sound decoder for Roco BLS Ae 6/8 (Digital)
by river6109 07/06/2014 10:50:39(UTC)
With or without sound decoder (Digital)
by Goofy 05/06/2014 18:28:24(UTC)
Sound decoders for loco's (Digital)
by Shamu 01/04/2014 07:36:32(UTC)
Sound decoder for Märklin Ludmilla (Digital)
by Hackcell 07/02/2014 17:40:46(UTC)
Roco ESU M4 sound decoder? (Digital)
by Goofy 06/01/2014 12:12:32(UTC)
ESU M4 sound decoder and 3 pole motor (Digital)
by Goofy 06/01/2014 11:36:47(UTC)
Have you ever been frustrated from a loco with sound decoder and noisy motor? (H0-scale)
by H0 12/12/2013 09:35:34(UTC)
ESU or Marklin Sound Decoder (Digital)
by camcath 04/10/2013 23:17:32(UTC)
Marklin sound decoders- which sounds? (Digital)
by kimballthurlow 24/09/2013 10:14:53(UTC)
This page was generated in 0.411 seconds.
