Offline ice 1
#1 Posted : 02 January 2015 11:05:58(UTC)
ice 1
I just have a question on MFX Decoders in locos.
What happens if you bought 2 locos the same with MFX Decoders is it straight forward changing the address etc.
#2 Posted : 02 January 2015 11:11:43(UTC)
Nothing...Märklin´s locomotive have unique adress programmed by of Märklin.
If you like,you can even name both models with difference name.
Or adresses too...
#3 Posted : 02 January 2015 11:46:58(UTC)
When using mfx, the address will be set by the digital controller automatically based on the serial number of the decoder.
Every decoder should have an individual serial number.
So there is no problem when using mfx - unless they forgot to set the serial number at the factory (and this is a problem only if you happen to get two locos where they forgot that).
For MM operation, you set the MM address like you do with programmable MM decoders.
Offline ice 1
#4 Posted : 02 January 2015 12:41:41(UTC)
ice 1
Thats fine thanks so they are very advanced decoders then
I see they have a newer MFX decoder in the new Class 152 that has extra sounds and can be used with the new central station for extra features one way to get people to upgrade i suppose.
I have a mobile station ref 60652 got it in an ice start set the problem im having is that i put in an FX loco address say 5 and away it goes on the small layout and then i stop it and run a loco say number 6 and away it goes and then i stop it and then i want to run number 5 again so i go in enter address 5 and it tells me Address used and i cant seem to be given another option to flick between locos or bring up an MFX Loco which is on the track into the display.
I went and entered all the loco address and names into my mobile station and then when i entered an address for any loco entered it told me addr used it just gives me the option of useing the database or the address so any time i want to run a loco again i keep having to hit the factory resset button.Please could you assist me
#5 Posted : 02 January 2015 16:03:03(UTC)
You can enter up to 10 locos into the MS loco list. By pressing the "loco" button you enter loco selection mode. Turn the speed knob until the desired loco shows up, then press the "loco" button again to control that loco.
Offline perz
#6 Posted : 10 January 2015 17:29:55(UTC)
perz
Do you know about anyone who has experienced this problem in reality? Or is it just a theoretical possibility?
#7 Posted : 10 January 2015 19:19:38(UTC)
I had two locos with serial number 0xffffffff (i.e. serial number was not set).
As expected those two locos could not be controlled independently.
And another problem made it worse: both Mobile Station and Central Station always forgot those locos when they were shut down. I presume 0xffffffff is the marker for deleted items. Loco would not register again as it remembered the controller, but the controller had deleted the loco.
And with the first new E 41 or 141, Märklin shipped a batch of locos where the serial number was not set. I don't have those, but many customers reported that problem.
This happens rarely - but it did happen and it may happen again.
Offline MikeR
#8 Posted : 11 January 2015 09:27:31(UTC)
MikeR
Hi Tom
Did you mange to reregister the locos? I have wondered if this is possible or if there is someway of doing a factory reset on the locos which might then forget the controllers?
Member of ETE
#9 Posted : 11 January 2015 09:49:58(UTC)
The locos remembered the Central Station and would not register again. The Mobile Station was a new controller for them and they registered. Now back to the Central Station and they would register. This had to be done each time the Central Station was restarted.
I sent the decoders to Märklin and got replacements with serial numbers. (Took only two attempts - at first they returned the unchanged decoder with the comment that it didn't need to have a serial number set).
Offline perz
#10 Posted : 14 January 2015 22:03:19(UTC)
perz
Well, this could explain some strange errors that I have read about. Personally I have never got an mfx loco or mfx decoder without the serial number set.
thanks 2 users liked this useful post by perz
Addresses for Mfx decoders (Digital)
by biswasg 19/04/2024 11:02:17(UTC)
Mapping 32 bit MFX decoders to production specs (Digital)
by Bryan 08/02/2023 03:39:49(UTC)
MFX decoders and occupied addresses (H0-scale)
by baggio 04/01/2017 04:50:05(UTC)
Hidden sounds with Märklin MFX decoders (Digital)
by Gert-Jan 16/11/2014 16:39:49(UTC)
Secondary address on mfx decoders (Digital)
by Lars Westerlind 30/08/2013 21:32:19(UTC)
Two MS, one connection box and some mfx decoders (Digital)
by Torstein 03/04/2012 14:39:38(UTC)
MFX decoders and IR controller (Digital)
by kskato 09/12/2011 02:12:18(UTC)
Programing Mars Light on ESU MFX decoders (Digital)
by eduard71 07/09/2011 05:49:44(UTC)
intellibox and mfx decoders (Digital)
by Andy Foster 13/11/2010 08:55:16(UTC)
Märklin mfx decoders (Digital)
by river6109 16/04/2010 07:02:09(UTC)
MFX Decoders (Digital)
by poppa-7 02/01/2010 22:19:13(UTC)
MS and mfx decoders (Digital)
by river6109 27/11/2009 07:43:38(UTC)
Reason why Blue Transformers kill mfx Decoders (H0-scale)
by H0 17/02/2009 23:48:09(UTC)
New Märklin mfx decoders (Digital)
by Hemmerich 17/01/2009 02:16:13(UTC)
Reprogramming of Märklin mfx decoders ? (Digital)
by MHauge 18/11/2007 19:35:00(UTC)
Question about MFX decoders (Digital)
by sebastian 14/06/2007 06:39:42(UTC)
MFX decoders that will not register in the CS (Digital)
by intruder 27/04/2007 00:40:33(UTC)
DCC/mfx decoders (News from Märklin and others)
by laalves 05/07/2006 03:53:24(UTC)
Speed steps with 6021 and mfx decoders (Digital)
by perz 12/09/2005 02:09:21(UTC)
Conversion with mfx decoders (Digital)
by kgsjoqvist 09/02/2004 15:11:41(UTC)
This page was generated in 0.573 seconds.
