Offline Mjn2ts
#1 Posted : 24 October 2021 14:45:47(UTC)
Mjn2ts
I’m currently planning out my first layout using hand-me-down M track, wired for analog but the end goal is to slowly convert the layout and locos to digital. In thinking towards an eventual digital layout I’m leaning towards converting (and supplementing since I don’t think there is enough m track) to K track, mainly for the appearance. I am wondering if it is better to use the flex track or the individual straight and curved track and if there is a cost savings to either?
thanks 2 users liked this useful post by Mjn2ts
#2 Posted : 24 October 2021 15:15:13(UTC)
Hi (not sure who to call you, but I think Jeff)
Yes, K tracks does look nicer than M track and you could use M track for some sidings until you get things converted. (I use my old M track is my display cabinets.)
I found that using the 2205 flex track was cheaper than using the sectional pieces. It may be worth it to order direct from Germany.
Depending on what your modeling goals are you may also want to place the K-track in some ballast and I particularly like the Merkur ballast. This has to be ordered from Germany.
I have a small writeup about Merkur at https://cabin-layout.mixmox.com/2015/11/merkur-ballast.html
If you do plan on going digital you should also explore the various control options before you lay too much track as you will likely need to build sensors into the track in order to provide feedback to the control system so it knows how far the trains have progressed.
#3 Posted : 24 October 2021 15:44:40(UTC)
M track isn't the greatest for newer decoders and controllers I've been told, because of more shorts due to a metal roadbed. I do have a bit of it in my layout on a yard siding with an old analog semiphore signal. The classic Marklin style is then shown.
#4 Posted : 25 October 2021 04:48:58(UTC)
... I particularly like the Merkur ballast. This has to be ordered from Germany.
I have a small writeup about Merkur at https://cabin-layout.mixmox.com/2015/11/merkur-ballast.html ...
Hi Dale and Mjn2ts,
Couldn't agree more about K track and Merkur ThumpUp (there, I've said it again Blushing ) and at risk of sounding like a gramaphone record OhMyGod :
https://www.marklin-user...kur-track-bed#post629213
Offline mvd71
#5 Posted : 25 October 2021 07:18:12(UTC)
K track is really good, and the Merkur underlay is great. The Felix track is really good to create beautiful sweeping curves.
#6 Posted : 25 October 2021 13:31:09(UTC)
Hi Mjn2ts (funny first name!)
All the Märklin rail choices are OK. Here is how I see them:
M-Track
+ easy to find and cheap but inspection of 2nd hand purchases necessary.
+ goes real well with an historic flair to layout (like in the 50s)
+ perfectly compatible with digital operation
- difficult to make long detection stretchs
- may rust in humid environments
Note: avoid large lantern track pieces
K-Track
+ flexible track allows any elegant curves
+ track geometry allows more compact layouts than with M or C track
+ under the table switch motors (option
* must ballast the track: allows for more realism but more work
- contact issues when ballasting with glue
- rail size and general track design very much dated (like 20 years ago or more). Huge rails code 100
- motor fixation to switches very unreliable (except for fixed layouts
C-Track
+ by far the best: more realistic, more reliable allowing for very nice layouts
+ in full sync with latest Märklin designs
+ can do any long detection stretchs
+ the only offering intelligent switches (motor and decoder in track bed).
+ rolling qualities simply not comparable with M or K tracks: trains just go straight and smooth (no dancing on rails but pure translation)
- more expensive
- no flexible track
- no sleek double slip switch
I have used all 3 types and even have some pieces of Modellgleis 3800 and 3900 but now I stick to C Track
Just my viewpoint
Here is a short glimpse of my layout (sorry for the messBlushing )
Offline Mjn2ts
#7 Posted : 25 October 2021 18:13:55(UTC)
Mjn2ts
Thank you for the reply’s and yes Dale my name is Jeff, I guess I should update that 🤣
Yes I will be using plywood but it’s only going where there will be track/building so there won’t be much of it. My original plan was to build the more common (at least in the US) 2 rail layout but my father is elderly and is passing his Marklin collection to me. It’s a large collection and has some strong sentimental value from my time as a kid helping him with his various layouts, so it’s becoming an all Marklin layout. It’s starting out analog but I plan to upgrade the loco’s to digital and slowly replace the track. It’s still a toss up between C&K track but I’m leaning more and more towards K, I like the look of it better and I think working with flex track will make things much easier when trying to get the track to lineup correctly.
Thanks again.. Jeff
Offline mvd71
#8 Posted : 27 October 2021 21:35:18(UTC)
Hi Jeff,
I know what you mean about sentimentality of things from your dad.
I have used all three types of track too. At present I have opted for k track with Merkur roadbed. It costs a little more than a combo like cork underlay and hand ballasting. However as a cost per metre it is not a big difference, and it gives a fantastic look.
Quality of running is entirely down to how you lay the track, and being patient and setting yourself a high standard is the key to success for all track types. I’ve seen bad running and roughness in all types.
I don’t find the code 100 to be a real issue for me, especially if the sides of the rails are weathered. Also the code 100 does allow you to run early models with larger flanges that were not designed for the smaller rails of c track. This may be a issue for you depending on the models you are inheriting from you father (on c track some models have the flanges hitting the sleepers).
I have recently moved into mostly Roco 1:87 passenger coaches, and with the longer length geometry of the k track and flex track just makes sense to me.
Cheers….
Offline Mjn2ts
#9 Posted : 29 October 2021 21:40:58(UTC)
Mjn2ts
Hi Jeff,
Cheers….
Thanks Mike.
That may make a difference in what track I end up switching to. I'm not sure what you consider early models, he may have some stuff that is from the late 70's but I believe the bulk of his collection is from the 80's to stuff he purchased within the last couple of years. It's a large collection so if there are a few that don't like a particular type of track it probably isn't the end of the world, except for his 3015's.. those are my favorites, I don't care what I have to do, they will be on the layout.
Offline mvd71
#10 Posted : 30 October 2021 02:16:34(UTC)
The 3015 may need the larger track profile, so k track will be perfect.
Decoderwerk 80203 motorized digital switch for K track (Digital)
by diesel 02/01/2026 06:40:08(UTC)
What should I do with all the K track that I have accumulated? (General MRR)
by cwp_marklin 25/10/2025 17:59:34(UTC)
Marklin catenary K track posts for C track layout (General MRR)
by egonzinc 13/10/2025 18:22:11(UTC)
Mixing M and K tracks (analog only) (H0-scale)
by philippe99 20/04/2025 12:54:34(UTC)
Marklin K Track Points (H0-scale)
by Trevor G 27/01/2025 04:48:18(UTC)
The long slim X track in K track with 2 drives (Digital)
by bygger01 05/01/2025 15:15:58(UTC)
Link s88 / Diode Trick / C & K Track (General MRR)
by Marklin Nut 12/10/2024 22:44:17(UTC)
C to K Track Adaptor Location (H0-scale)
by Eddie7979 20/09/2024 02:11:36(UTC)
locomotives of other brands compatible with märklin mobile station on k track (H0-scale)
by Alex222 23/04/2024 22:55:14(UTC)
Marklin HO K Track Numbers (General MRR)
by matiSon 09/12/2023 05:21:27(UTC)
New layout with C & K track. Will older M signals work? (Digital)
by matiSon 23/11/2023 02:53:09(UTC)
Marklin K track (General MRR)
by Marklin30 01/11/2023 04:47:51(UTC)
K track, ski pick up shoe shorts out system over switches? (Model railroad wiring)
by mattj70 18/08/2023 03:55:24(UTC)
Powerloss on a section of K track (H0-scale)
Belarus einotuominen 06/05/2023 11:07:47(UTC)
Circuit Track - HO K Track Configuration with Signals (H0-scale)
by rfeist 09/04/2022 20:58:07(UTC)
k83 (6083) decoder for K track switches tutorial (Digital)
by Fireguy911 02/02/2022 00:17:19(UTC)
K Track, solid rail, hollow rail (H0-scale)
by Mr. Ron 06/10/2021 20:31:51(UTC)
K track switches and crossovers (General MRR)
by eurotrain 10/09/2021 16:29:31(UTC)
Contact Tracks for K track (H0-scale)
by Harvey 14/03/2021 01:34:22(UTC)
ACME coaches on Marklin K track, (H0-scale)
by danmarklinman 13/03/2021 19:15:44(UTC)
C Track and K track flex (H0-scale)
by Timnomads 08/02/2021 14:33:05(UTC)
Lsmodels on Marklin k track !!! (H0-scale)
by danmarklinman 15/01/2021 11:03:49(UTC)
Circuit track track diagram (Digital)
by QQQ1970 01/12/2020 00:17:25(UTC)
K Track Turnout Digital (Digital)
by kehdi737w 24/06/2020 18:33:40(UTC)
Soldering K Track to C Track (Model railroad wiring)
by cancan 03/05/2020 13:30:10(UTC)
Old K Track 2161 Turnout Lanterns (H0-scale)
by davo_vespa 15/04/2020 07:55:57(UTC)
Thoughts on K track Folge 53 from Marklin Magazine (Track plans)
by Demch 31/03/2020 02:58:32(UTC)
Looking into the future of Märklin's K track (General MRR)
by michelvr 29/12/2019 16:33:48(UTC)
K track turnout complete lever handle gizzmo thing? (Digital)
by Gramps 07/12/2019 05:22:14(UTC)
Are the rails on K track removable? (H0-scale)
by tommyheadleycox 11/11/2019 18:09:14(UTC)
Removing rail joiners from K track (General MRR)
by Drongo 05/10/2019 08:44:28(UTC)
K Track 3 way switch 2270 and servos (H0-scale)
by PMPeter 04/05/2019 18:30:22(UTC)
Moveable frog on k track points (General MRR)
by CTD81 03/02/2019 16:32:13(UTC)
K track electrical question (H0-scale)
by Harvey 13/11/2018 04:56:35(UTC)
K track plan with one level (Track plans)
by LoeM 12/11/2018 12:41:44(UTC)
Insulated and non-insulated rail joiners for K tracks (H0-scale)
by PeFu 21/10/2018 13:19:27(UTC)
Testing K track soldering - Success! (H0-scale)
by PeFu 08/04/2018 14:33:58(UTC)
Disposing of used K track (H0-scale)
by Rwill 23/02/2018 13:22:26(UTC)
C Track To K Track And Back Again (General MRR)
by skeeterbuck 05/02/2018 17:34:25(UTC)
K track and conputer software (Model railroad software)
by eurotrain 09/11/2017 14:54:30(UTC)
K Track Catalog & Pieces (H0-scale)
by JDennis 05/11/2017 00:24:06(UTC)
turnout mechanism in K track switches (H0-scale)
by applor 14/08/2017 00:48:11(UTC)
K track rail code (General MRR)
by Arcandier 21/04/2017 16:20:52(UTC)
AC and DC with Marklin K track ? (Model railroad wiring)
Belarus Mattawa 26/02/2017 12:41:36(UTC)
Railbus 3016 shorting out on K track switches (H0-scale)
Belarus louisbuddy 24/02/2017 00:00:47(UTC)
Insulated K track crossing - suitable for dual operation? (H0-scale)
by baggio 20/02/2017 18:22:16(UTC)
K track de-coupler question (H0-scale)
by Maurice 20/02/2017 04:03:04(UTC)
K Track Straight pieces (H0-scale)
by anthpao 17/02/2017 15:00:48(UTC)
K track + Code 100 (H0-scale)
by Hackcell 14/02/2017 00:05:37(UTC)
K Track Wide Radius Turnouts and Double Slip Switch Question (General MRR)
by Collector 01/02/2017 04:16:38(UTC)
This page was generated in 1.026 seconds.
