Offline mbarreto
#1 Posted : 19 December 2009 02:59:40(UTC)
mbarreto
You have been a member since:: 18/02/2008(UTC)
I have used, and still use mostly Märklin short couplers, but the coupling fails several times. This happens with smooth or non-smooth operation. I think it is due to exactly the same height from rails or excessive difference in height, damage or wrong positioned with respect to the car.
I found the Roco couplers (not the short couplers) to have extremely smooth and reliable action, and they can be easily decoupled with the decoupling track, the against being that the coupling is not so short as the Märklin (anyway is not much longer).
The Fleischman short coupler are really short but they are not smooth for coupling and they don´t work well with the Märklin decoupling track (this last issue could easily be solved by Fleischman...).
I have not tested yet the Roco short couplers. I don´t know if the dcoupling track works ok with them!
Has anyone tested the later with Märklin rolling stock and got good results, even with the decoupling track?
Or have you tested some other couplers that work as good as the Roco and are shorter?
Miguel
Mostly Märklin H0.
Offline Armando
#2 Posted : 19 December 2009 05:29:32(UTC)
Armando
You're very right about the Märklin short couplers, Miguel. But I would say that they work fine most of the time. However, you will see that it gets even worse with the Märklin current-conducting short couplers. They can be nightmarish!
As for Roco, I assume that you are referring here to the "universal" couplers #40395. I have no experience with these, and I am glad to hear that they perform well on the uncoupling track. The short coupling #40270 is the one I use on all my Roco 303mm passenger coaches. They perform very satisfactorily most of the times. However, if the consist is rather heavy (more than 6 coaches), they could tend to snap sometimes on the way. And they cannot be uncoupled remotedly via the Märklin uncoupler track, unfortunately. The bright side is that they fit very closely and can be uncoupled just by lifting the coach or car with your hand (same as Fleischmann couplers).
Actually, the Fleischmann short couplers are my preferred ones. However, they do not easily fit into the Roco NEM socket on the coaches. It requires some extra pressure and the result is not so good. They work best with either Märklin or Trix. And my experience has been that they can be uncoupled with the Märklin uncoupling track.
Hope this helps.
Armando García
#3 Posted : 19 December 2009 09:59:35(UTC)
Interesting topic Miguel. I assume you are talking about couplers that are compatible with the NEM standard coupler box.
I have been using the latest style Märklin coupler, and I find them very good generally.
However they have shortcomings:
- they will not couple on curves
- sometimes, they do not couple well with earlier style Märklin couplers.
While talking couplers, perhaps someone might know what this is? It looks like a very positive coupler. The half bar is metal.
I also found the older Fleischmann coupler excellent, it is very simple, and robust.
Offline Philip
#4 Posted : 19 December 2009 10:29:54(UTC)
Philip
<br />Interesting topic Miguel. I assume you are talking about couplers that are compatible with the NEM standard coupler box.
This is a ROCO item
See this:
http://roco.co.at/index....&artikelnummer=40395
Philip
Philip.
Let's keep it simple.
MFDWPL
#5 Posted : 19 December 2009 11:01:12(UTC)
these are very good couplers and I use them on most of my carriages.
The extra function these couplers have is, the halfbar locks on both sides behind a hook, a coupler which will not uncouple but again some carriages buffers lie to low and it interferes with the coupling and can cause de-railments (very rare and seldom).
Fleischmann & Roco couplings have a stiffer couplingshaft fork and therefore under heavy load they do not glide out of the couplingshaft, whereas Märklin couplings have a tendency to seperate.
regards.,
#6 Posted : 19 December 2009 11:36:56(UTC)
John, as you describe, both couplers are a positive lock on the little hook on the Roco 40395 universal coupler.
I really like that coupler. I guess it couples OK to most Märklin couplers in operation?
#7 Posted : 19 December 2009 12:55:15(UTC)
<br />I guess it couples OK to most Märklin couplers in operation?
Because of the halfbar it doesn't couple well with standard hook and loop couplers (they decouple on the first turn to the left).
I use it for all non-Märklin items and it works great.
Couples easily with Märklin short couplers.
Offline Rinus
#8 Posted : 19 December 2009 13:21:12(UTC)
Rinus
I'm actually replacing all my Marklin short couplers / Brawa couplers, Roco short couplers, ACME couplers etc with the Roco Universal coupler as decriberd by kimballthurlow and river.
The Marklin short couplers dont mix with ACME coaches (too short), and tend to uncouple in climbs with heavy loads.
The Brawa standard couplers are a nightmare. They are rubbish. Wont spend any words on them.
ACME couplers are very sturdy (metal??) but too long
The Roco short couplers tend to uncouple with heavy loads or in climbs. Cant have that.
I see the Roco universal couplers as a nice alternative: right lenght, sturdy, wont uncouple.
#9 Posted : 19 December 2009 13:32:15(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by H0
Tom,
your observations are absolutely correct.
mixing Märklin short couplers with Roco (as mentioned) although they couple easy, I prefer, either both Märklin or both Roco.
What frustrates me sometimes you take a video and the Märklin couplings wont couple or uncouple.
regards.,
Offline PierreGILLARD
#10 Posted : 19 December 2009 15:30:04(UTC)
PierreGILLARD
For my American rolling stock, I use Kadee couplers. For those of you interested in previous topics about these couplers, simply introduce "Kadee" in the search field.
Pierre.
Offline mbarreto
#11 Posted : 20 December 2009 00:27:52(UTC)
mbarreto
After my experience and reading your appends the Roco universal couplers seems to be the ones I will adopt for all my non-Märklin wagons. Anyway I will not mix them with the Marklin short couplers. When I want really short coupling and without a strong need to couple and uncouple frequently I will use the Fleischman short couplers.
The problem for the Fleischman short couplers on the Marklin uncoupler track are the holes on the movable piece of the uncoupler track.
Miguel
Mostly Märklin H0.
Offline Dreadnought
#12 Posted : 21 December 2009 01:45:13(UTC)
Dreadnought
I have been planning to use Marklin current conducting couplers on my 43100, and 43110 cars (the green compartment cars). I have the 43119 which has the pick up shoe, and tail lights. I thought it would be less drag to have only one pick up.
What kinds of problems have you hit? Am I crazy to do it, or should I light each car independently?
Offline sudibarba
#13 Posted : 21 December 2009 02:16:27(UTC)
sudibarba
[size=1" face="Verdana" id="quote]quote:Originally posted by Dreadnought
<br />I have been planning to use Marklin current conducting couplers on my 43100, and 43110 cars (the green compartment cars). I have the 43119 which has the pick up shoe, and tail lights. I thought it would be less drag to have only one pick up.
You are heading the right way with the current conducting couplers. The Marklin ones are made by a sub contractor (RCTS or something like that I think).The fewer the pickups the better.
Eric
Offline Armando
#14 Posted : 21 December 2009 02:35:12(UTC)
Armando
[size=1" face="Verdana" id="quote]quote:Originally posted by sudibarba
[You are heading the right way with the current conducting couplers. The Marklin ones are made by a sub contractor (RCTS or something like that I think).The fewer the pickups the better.
Eric
Yes, they are made by RTS, but they are a nightmare to couple and uncouple!
Armando García
Offline Macfire
#15 Posted : 21 December 2009 11:33:13(UTC)
Macfire
Views messages in topic : 2,652
My choice are the Fleischmann 38-6515 Profi couplings for freight wagons and unlit passenger coahes.
Being vertical rather than horizontal in allignment means that they handle differing gradients better.
I have still to decide what I will use for my lighted coaches. Wether to feed off the loco or a single slider on a coach. Some will be permanent couplers I think but others - well I am unsure at this stage.
Lord Macca
Relex to Close couplers (General MRR)
by Zeeboo04 08/02/2025 22:21:12(UTC)
Couplers not coupling (H0-scale)
by rg1911 20/01/2025 05:06:14(UTC)
Hornby Magnetic Couplers (General MRR)
by Drongo 01/01/2025 13:11:18(UTC)
How to replace Marklin Maxi F-7 couplers with kadee (Big scale)
by roddewr 16/11/2024 20:43:34(UTC)
39902 Class 290 Telex couplers acting stange? (H0-scale)
by LA2019 01/10/2024 00:10:48(UTC)
Question about couplers (H0-scale)
by fabstar68 18/06/2024 22:35:07(UTC)
Problems with couplers (H0-scale)
by Alex H 29/05/2024 19:05:49(UTC)
Close couplers for some of the 30xx series engines (H0-scale)
by lpesce 13/05/2024 08:44:15(UTC)
Marklin 4707 Couplers (General MRR)
by Bruce Clark 27/08/2023 00:42:47(UTC)
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
Replace all loco couplers with NEM pocket clutch bars (H0-scale)
by einotuominen 09/01/2023 14:48:53(UTC)
Replacement couplers for Märklin # 4722? (H0-scale)
by Coppas 20/11/2022 15:56:06(UTC)
Interior Lighting & Current Conducting Couplers (H0-scale)
by Eddie7979 18/10/2022 11:58:28(UTC)
Decouplers with the CS3 (Digital components and Software reviews)
by Keyser 11/08/2022 17:40:42(UTC)
How can we uncouple current‐conducting closed std. couplers? (H0-scale)
by Pronto5 05/06/2022 01:26:55(UTC)
What are Roco telex couplers like!! (H0-scale)
by danmarklinman 04/06/2022 19:47:12(UTC)
Couplers (H0-scale)
by Mr. Ron 06/01/2022 20:25:38(UTC)
Couplers (H0-scale)
by Harvey 28/12/2021 02:32:07(UTC)
Prototype Couplers - Spur 1 (Big scale)
by Richard556 06/12/2021 08:55:44(UTC)
Scharfenberg couplers (H0-scale)
by oliver 14/11/2021 04:11:06(UTC)
Put proper couplers on Märklin 3132 V5 (H0-scale)
by MartinS 09/10/2021 15:04:39(UTC)
NEM couplers and startup (H0-scale)
by revmox 13/08/2021 13:35:39(UTC)
Help differentiate couplers pack (H0-scale)
by Puttputtmaru 15/07/2021 13:55:14(UTC)
controlling uncouplers (Digital)
by Don Morris 09/07/2021 04:33:12(UTC)
Kupplungs, clutches, and couplers (Small scale)
by husafreak 09/06/2021 18:50:29(UTC)
72021 current conducting couplers (H0-scale)
by marklinist5999 15/05/2021 21:02:42(UTC)
Uncouplers (H0-scale)
by Rwill 28/02/2021 11:22:23(UTC)
Couplers and buffers cause derailment (H0-scale)
by PeFu 14/02/2021 07:15:11(UTC)
Recommendation of 2-pole couplers? (H0-scale)
by PeFu 06/02/2021 17:34:16(UTC)
Magnetic marklin couplers (H0-scale)
by Lucky Trains 20/12/2020 14:02:32(UTC)
Anyone have a Roco locomotive with auto/remote control couplers (H0-scale)
by danmarklinman 16/12/2020 17:41:45(UTC)
current conducting couplers fro 4132 style coaches???????? (H0-scale)
by dominator 24/10/2020 09:50:02(UTC)
Kadee couplers (H0-scale)
by Harlov 05/10/2020 18:29:04(UTC)
Pickup shoes and couplers (H0-scale)
by alistairiancampbell 22/06/2020 10:27:53(UTC)
Current-Conducting close couplers 72021 (General MRR)
by ocram63_uk 25/05/2020 09:48:43(UTC)
Couplers (H0-scale)
by mikemasey 25/05/2020 00:10:10(UTC)
Digital uncouplers. (Digital)
by eberhardt 16/04/2020 11:04:09(UTC)
Where to purchace replacement couplers (H0-scale)
by tcatman 11/02/2020 03:29:48(UTC)
I need advice with Märklin E115737 current conducting close couplers NEM 72020 / 72021 (H0-scale)
by Janne75 06/02/2020 22:55:18(UTC)
Brawa's telex couplers. Opinions? (H0-scale)
by Copenhagen 23/01/2020 17:32:56(UTC)
Roco automatic couplers (H0-scale)
by danmarklinman 05/01/2020 10:45:51(UTC)
Is there some trick with Telex couplers? (H0-scale)
by LongHairedDavid 31/12/2019 18:51:00(UTC)
Is it possible to install Marklin close couplers on a Bachman car? (H0-scale)
by Uwe 29/12/2019 01:33:29(UTC)
change couplers (H0-scale)
by harris19 03/12/2019 11:39:12(UTC)
Couplers for 216 090-1 Engine (H0-scale)
by guitartoys 09/10/2019 05:40:38(UTC)
Marklin couplers for Fleischmann (H0-scale)
by Ivan 02/09/2019 20:38:58(UTC)
Marklin TRAXX Locos - couplers (H0-scale)
by LongHairedDavid 24/07/2019 13:59:01(UTC)
Query on replacing old metal couplers (H0-scale)
by madhu.gn.71 21/11/2018 07:32:11(UTC)
Couplers (H0-scale)
by Twisterdodger 13/11/2018 15:48:45(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
This page was generated in 0.566 seconds.
