Offline jmallen622
#1 Posted : 28 December 2021 02:24:51(UTC)
jmallen622
I have the 2019 & 2020 Marklin Christmas cars. The couplers on one end seem to be lower than the other end and hits the center studs and does not connect to proper height couplers.
Is this an error for these 2 years? Can they be replaced?
Thank You
Jim Allen
Offline Harvey
#2 Posted : 28 December 2021 02:32:07(UTC)
Harvey
I have quite a few freight cars (44187 - M&M car as an example) and when I run them they disconnect. This seems random but some cars are more susceptible to this than others. Reason could be slight bumps on the rails, slight differences in height of couplers on different cars. To be sure that I am describing the coupler I have, it looks like part 72060 but connects to the car by pushing the coupler onto a "pin' on the car. That is, the coupler has a small hole for the pin to fit through. I do have part 7203 (701630) but these do not have the hole I described. I see that 7205 includes 2 types of couplers (1 for locomotives and 1 for cars). These seem to have similar holes. Are these what I am looking for? Anyone have experience with them?
Harvey
#3 Posted : 28 December 2021 06:03:23(UTC)
Hello Harvey,
The 7205 are the ones you want.
You can buy them in the packet of 40 (wagon) + 10 (loco).
I would imagine a Märklin dealer would sell them in pairs if you only need a few.
#4 Posted : 28 December 2021 10:01:15(UTC)
Merged both Coupler topics.
To answer Jim's question there is a coupler gauge available from Marklin - item 7001 - which you can use to set the proper coupler height.
From memory, the Christmas cars use close couplers which plug into a pocket in the coupler assembly. Make sure that the coupler is fully pressed home into the pocket.
The close couplers are available as a replacement (item 7203) which again you should be able to obtain from a Marklin dealer singly.
The pocket / drawbar assembly most likely are available as a spare part but you would need to email the Marklin Service Centre to find out what the part numbers are for each wagon.
Relex to Close couplers (General MRR)
by Zeeboo04 08/02/2025 22:21:12(UTC)
Couplers not coupling (H0-scale)
by rg1911 20/01/2025 05:06:14(UTC)
Hornby Magnetic Couplers (General MRR)
Belarus Drongo 01/01/2025 13:11:18(UTC)
How to replace Marklin Maxi F-7 couplers with kadee (Big scale)
by roddewr 16/11/2024 20:43:34(UTC)
39902 Class 290 Telex couplers acting stange? (H0-scale)
by LA2019 01/10/2024 00:10:48(UTC)
Question about couplers (H0-scale)
by fabstar68 18/06/2024 22:35:07(UTC)
Problems with couplers (H0-scale)
by Alex H 29/05/2024 19:05:49(UTC)
Close couplers for some of the 30xx series engines (H0-scale)
by lpesce 13/05/2024 08:44:15(UTC)
Marklin 4707 Couplers (General MRR)
by Bruce Clark 27/08/2023 00:42:47(UTC)
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
Replace all loco couplers with NEM pocket clutch bars (H0-scale)
by einotuominen 09/01/2023 14:48:53(UTC)
Replacement couplers for Märklin # 4722? (H0-scale)
by Coppas 20/11/2022 15:56:06(UTC)
Interior Lighting & Current Conducting Couplers (H0-scale)
by Eddie7979 18/10/2022 11:58:28(UTC)
Decouplers with the CS3 (Digital components and Software reviews)
by Keyser 11/08/2022 17:40:42(UTC)
How can we uncouple current‐conducting closed std. couplers? (H0-scale)
by Pronto5 05/06/2022 01:26:55(UTC)
What are Roco telex couplers like!! (H0-scale)
by danmarklinman 04/06/2022 19:47:12(UTC)
Couplers (H0-scale)
by Mr. Ron 06/01/2022 20:25:38(UTC)
Prototype Couplers - Spur 1 (Big scale)
by Richard556 06/12/2021 08:55:44(UTC)
Scharfenberg couplers (H0-scale)
by oliver 14/11/2021 04:11:06(UTC)
Put proper couplers on Märklin 3132 V5 (H0-scale)
by MartinS 09/10/2021 15:04:39(UTC)
NEM couplers and startup (H0-scale)
by revmox 13/08/2021 13:35:39(UTC)
Help differentiate couplers pack (H0-scale)
by Puttputtmaru 15/07/2021 13:55:14(UTC)
controlling uncouplers (Digital)
by Don Morris 09/07/2021 04:33:12(UTC)
Kupplungs, clutches, and couplers (Small scale)
by husafreak 09/06/2021 18:50:29(UTC)
72021 current conducting couplers (H0-scale)
by marklinist5999 15/05/2021 21:02:42(UTC)
Uncouplers (H0-scale)
by Rwill 28/02/2021 11:22:23(UTC)
Couplers and buffers cause derailment (H0-scale)
by PeFu 14/02/2021 07:15:11(UTC)
Recommendation of 2-pole couplers? (H0-scale)
by PeFu 06/02/2021 17:34:16(UTC)
Magnetic marklin couplers (H0-scale)
by Lucky Trains 20/12/2020 14:02:32(UTC)
Anyone have a Roco locomotive with auto/remote control couplers (H0-scale)
by danmarklinman 16/12/2020 17:41:45(UTC)
current conducting couplers fro 4132 style coaches???????? (H0-scale)
by dominator 24/10/2020 09:50:02(UTC)
Kadee couplers (H0-scale)
by Harlov 05/10/2020 18:29:04(UTC)
Pickup shoes and couplers (H0-scale)
by alistairiancampbell 22/06/2020 10:27:53(UTC)
Current-Conducting close couplers 72021 (General MRR)
by ocram63_uk 25/05/2020 09:48:43(UTC)
Couplers (H0-scale)
by mikemasey 25/05/2020 00:10:10(UTC)
Digital uncouplers. (Digital)
by eberhardt 16/04/2020 11:04:09(UTC)
Where to purchace replacement couplers (H0-scale)
Belarus tcatman 11/02/2020 03:29:48(UTC)
I need advice with Märklin E115737 current conducting close couplers NEM 72020 / 72021 (H0-scale)
by Janne75 06/02/2020 22:55:18(UTC)
Brawa's telex couplers. Opinions? (H0-scale)
by Copenhagen 23/01/2020 17:32:56(UTC)
Roco automatic couplers (H0-scale)
by danmarklinman 05/01/2020 10:45:51(UTC)
Is there some trick with Telex couplers? (H0-scale)
by LongHairedDavid 31/12/2019 18:51:00(UTC)
Is it possible to install Marklin close couplers on a Bachman car? (H0-scale)
by Uwe 29/12/2019 01:33:29(UTC)
change couplers (H0-scale)
by harris19 03/12/2019 11:39:12(UTC)
Couplers for 216 090-1 Engine (H0-scale)
by guitartoys 09/10/2019 05:40:38(UTC)
Marklin couplers for Fleischmann (H0-scale)
by Ivan 02/09/2019 20:38:58(UTC)
Marklin TRAXX Locos - couplers (H0-scale)
by LongHairedDavid 24/07/2019 13:59:01(UTC)
Query on replacing old metal couplers (H0-scale)
by madhu.gn.71 21/11/2018 07:32:11(UTC)
Couplers (H0-scale)
by Twisterdodger 13/11/2018 15:48:45(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Current conducting couplers (General MRR)
by morsing 18/10/2018 21:44:59(UTC)
This page was generated in 0.702 seconds.
