Offline poppa-7
#1 Posted : 29 June 2020 12:21:13(UTC)
poppa-7
Dear All
What speaker ohm rating should be used with ESU decoder 62499 V3.0 M4
Regards RussellConfused
Edited by user 30 June 2020 02:06:31(UTC)  | Reason: Not specified
#2 Posted : 29 June 2020 12:58:42(UTC)
Hi Russel
Apparently this is a LokSound V3.0 M4
Early ESU decoders (prior to V4) cannot use 4 Ohms speaker. ESU says there is a risk of destruction
So IMO you need to use an 8 Ohm speaker but the ESU Website doesn't provide any advice for prior-V3.5 decoders
(see: http://www.esu.eu/en/products/accessories/loudspeakers/)
To play it safe you may start wiring a 8 Ohm speaker but with a 10 Ohm resistor in series
#3 Posted : 29 June 2020 13:15:17(UTC)
The manual indicates 100 ohms.
Some Märklin locos used speakers with only 50 ohms - and quite often the speaker got damages.
Better do not go below 50 ohms.
Speakers with 8 ohms will most likely damage your decoder, even with 10 ohms in series. In the best case the speaker blows up before the decoder gets damaged...
The ESU speakers marked LokSound V3.5 should be fine for that decoder.
Offline mmervine
#4 Posted : 29 June 2020 16:31:08(UTC)
mmervine
That is correct, a 100ohm speaker is required for a LS3/3.5
Offline poppa-7
#5 Posted : 30 June 2020 03:53:33(UTC)
poppa-7
Hi Russel
Hi Jean
Thanks for the info it was very helpful
Russell
Offline poppa-7
#6 Posted : 30 June 2020 03:59:28(UTC)
poppa-7
Great. I fitted a 100ohm and it sounds fantastic
Thank you
RussellBigGrin
#7 Posted : 30 June 2020 06:23:07(UTC)
That's my understanding!
#8 Posted : 30 June 2020 09:28:09(UTC)
That's not safe. You risk overloading the sound decoder. The manual shows 100 ohms for the speaker.
ESU Decoder 58923 (General MRR)
by poppa-7 26/10/2025 03:38:06(UTC)
Esu decoder in loco with C-Sinus. Worth it? (Digital)
by EMD_645 26/07/2024 14:03:06(UTC)
ESU Decoder question (Digital)
by cintrans 27/11/2022 13:53:04(UTC)
ESU Decoder Language (Digital)
by owidgie 08/05/2020 00:39:14(UTC)
Adding stayalives to ESU decoders. (Digital)
by lewistrain 27/04/2019 04:31:23(UTC)
New esu decoder buzzing, drawing current. (Digital)
by lewistrain 23/02/2019 04:26:57(UTC)
Esu decoders parameters (Digital)
by foumaro 24/02/2018 06:33:42(UTC)
Cheap USA (or EU for that matter) Source for ESU Decoders? (Digital)
by 5HorizonsRR 13/10/2017 16:47:59(UTC)
Chokes on Esu decoders? (Digital)
by Danlake 24/05/2017 22:19:15(UTC)
New V4 ESU decoder . (Digital)
by Tom Jessop 25/05/2016 08:12:07(UTC)
LEDs for use with ESU decoders (Digital)
by IsItDigitalAlready? 04/03/2015 21:59:50(UTC)
ESU Decoders - Upgrade (Digital)
by camcath 03/05/2014 09:07:14(UTC)
by charles Sharpe 31/03/2014 08:04:07(UTC)
3015 with ESU decoder (Digital)
by biedmatt 26/07/2012 04:53:44(UTC)
ESU decoders versatility (Digital)
by river6109 25/07/2012 14:11:58(UTC)
ESU Decoder installation question (Digital)
by Chris6382chris 13/07/2012 16:20:09(UTC)
ESU decoder upgrade/update ? (Digital)
by French_Fabrice 28/06/2012 20:05:42(UTC)
Mixed results tonight with ESU decoders and CS2 and advice sought (Digital)
by ac jacko 13/04/2012 16:46:18(UTC)
Problem with MS2 and ESU decoders (Digital)
by anthpao 29/12/2011 13:19:30(UTC)
Help with Problem with ESU Decoders in train consist (Roco BLS 420 & Liliput EWIII AC) (Digital)
by mike c 19/09/2010 02:48:09(UTC)
Converted locos with 5 pole motor and ESU decoders (H0-scale)
by river6109 19/07/2010 19:43:17(UTC)
Help about ESU decoder extended information! (Digital)
by hjmo08 18/05/2009 03:54:53(UTC)
Programming of ESU decoders with MS (Digital)
by Hemmerich 25/03/2009 22:55:34(UTC)
ESU decoder manual (Digital)
by sudibarba 10/08/2008 05:35:43(UTC)
ESU decoder reader (Digital)
by diesel 26/03/2008 08:08:02(UTC)
ESU Decoder Instructions (Digital)
by Frostie 20/04/2007 04:50:07(UTC)
Function invertor for ICE lights with ESU decoder? (Digital)
by Gert-Jan 03/12/2005 20:44:01(UTC)
This page was generated in 0.319 seconds.
