Offline Pfalzbahn
#1 Posted : 19 October 2019 03:44:07(UTC)
Pfalzbahn
Hallo out there,
my CS2 has the hardware version 3.1 for many years. Shouldn't there be an upgrade to this version?
Palzbahn
Offline Legless
#2 Posted : 19 October 2019 04:07:05(UTC)
Legless
Hi Pfalzbahn,
It's your software version that gets upgraded.
The latest upgrade is Version 4.2.9 (0) June 2019
This should help you out.
Legless
Offline TEEWolf
#3 Posted : 19 October 2019 05:16:20(UTC)
Originally Posted by: Pfalzbahn Go to Quoted Post
Hallo out there,
Palzbahn
How do you want to update the hardware? New screen? New processor chip? Whatever, but for me the software update is the most important incident. For the hardware buy a CS 3. Yes, expensive, but probably it will be the cheapest way updating a CS hardware.BigGrin
Here read more about the CS 2 software update.
https://www.maerklin.de/...e/downloads/cs2-updates/
https://www.maerklin.de/...ate_4-2-9_info-01-en.pdf
According to your picture that CS 2 has the latest software version.ThumpUp
Offline Pfalzbahn
#4 Posted : 22 October 2019 01:37:37(UTC)
Pfalzbahn
I am not looking for a software update. The software of my CS2 is updated.
Some locos with mfx decoders take many minutes to register themselves on my CS2. My supplier in Germany suggested that this may be a "firmware" (hardware) problem and it should be updated.
"Manchmal kommt es vor, dass sich eine Lok extrem langsam anmeldet. Eventuell kann das auch an der nicht aktuellen Firmware in Ihrer CS2 liegen. Falls Sie nicht die aktuellste Firmware in Ihrer CS2 haben, aktualisieren Sie sie doch mal. vielleicht geht das Anmelden danach ja schneller."
I will follow up with Maerklin.
Pfalzbahn
#5 Posted : 22 October 2019 02:59:19(UTC)
If it is a hardware update then the easiest way to update it is to buy a later version of the CS2. Any later CS2 that you did buy would be a 2nd hand CS2 as they are no longer being sold new.
You could ask Marklin whether you could send your CS2 back to them for a hardware upgrade, but be aware that they might not have spare hardware parts to sell you. Any upgrade would be at a time and materials cost plus shipping and taxes. Probably cheaper to go and buy a CS3.
My 60214 CS2 is also at hardware version 3.1, but I don't see any need to upgrade it. A CS3 would logically be my next upgrade.
Offline TEEWolf
#6 Posted : 22 October 2019 03:09:59(UTC)
Pfalzbahn
First of all I do have CS 3+ and never had a CS 2.
But I read several times that a software update for a CS 3 needs about 5 minutes for a CS 2 it can last up to 2 hours. If your mfx decoder needs some minutes this can be too. I have to confess at my CS 3+ as well as with my MS 2, sometimes the mfx reacts pretty quick, but sometimes it needs a long time in my opinion and I get impatient. Mainly it happens, if the tracks and/or the wheels of the loco are dirty. Either I put it on another place, clean tracks and wheels or just wait till registration is done.
Then there are software updates, they had to be done twice, before there are completly installed at your CS.
Third you may have a faulty update. At the CS 3 I have the possibility for a bootloader update to update the faulty update again and hopefully then correctly.
But Mäerklin wrotes you nothing about this. Your German words say, if you do not have the latest update at your CS 2, update it. Then perhaps it is going quicker. On your picture you showed you have the latest update already.
Offline Pfalzbahn
#7 Posted : 22 October 2019 04:12:41(UTC)
Pfalzbahn
Thanks to both of you for your reply.
As I mentioned earlier I will contact Maerklin and see what they have to say. I would not go for another CS2. If need be I will rather upgrade to a CS3+.
And yes, the software update takes 2 uploads - I noticed that.
Pfalzbahn
Offline DB Fan
#8 Posted : 22 October 2019 04:15:04(UTC)
DB Fan
TEE Wolf is correct. “Firmware update” actually means software update so that you have the latest/newest software update on your CS 2 and not the original installed software done by the manufacturer (Firma/Hersteller) hence the name Firmware. Hope this helps.
Happy Model Railroading
Robert
Offline Pfalzbahn
#9 Posted : 22 October 2019 04:28:43(UTC)
Pfalzbahn
My German must be rusty. I didn't correlate "Firmware" with Software!
Thanks for pointing it out, Robert (& TEE Wolf).
Pfalzbahn
#10 Posted : 22 October 2019 06:28:13(UTC)
That's an interesting if incorrect statement on the origins of the word 'Firmware'.
Firmware has always referred to when you need a combination of software and hardware - neither hard or soft, but in between.
https://en.m.wikipedia.org/wiki/Firmware
Online mvd71
#11 Posted : 22 October 2019 08:14:06(UTC)
If you want a quicker response from your CS2, then the only viable option is a CS3. I was using one today and it is considerably quicker than the CS2. if you did buy a cs3, your old cs2 will still get good money on eBay, if you want to minimise the cost of upgrade
Offline ktsolias
#12 Posted : 22 October 2019 10:32:49(UTC)
ktsolias
The CS2 is from 2008 and the CS3 is from 20017 after 9 years!!!!
The hardware of the CS2 is obsolete, with the computer technology standards 9 years are ages!!! The CPU is slow the peripherals (memory etc) are slow too.
You can nothing do about it....
Sometimes the old hardware with new software is getting slower, till the moment that can't run the new software at all...
That's happen with CS2. The modern mSD3 decoders etc are designed for the CS3.
Of course can work on the CS2 but slower
If you want more speed the only solution to this problems, as many other members noticed above, is to buy a new CS3.
Costas
Offline Rwill
#13 Posted : 22 October 2019 12:43:59(UTC)
Rwill
Slightly amusing
I reckon I have one of the last CS2's to come out of the factory. I bought at a very very good price 18 months ago a brand new LGB start set including a CS2 from a "toyshop" so it had probably been sat there for a year or more. That info page shows Hardware version 5.1 and serial number 41470. When I bought it people were having issues with the new CS3 and waiting for bug fixes etc. I find my CS2 very good but my comparison was to an MS2. it updates when needed I have no idea whether that is slow or fast as I will do something else watching a computer update is like watching paint dry. It does everything I expect of it. I have the best help line in the world - this forum I have yet to find a CS2 topic that has not been covered. When it dies I shall buy a CS3
#14 Posted : 22 October 2019 13:02:21(UTC)
The delay with registering. Is this a new loco or locos already registered on the CS2.
Offline Pfalzbahn
#15 Posted : 22 October 2019 23:40:08(UTC)
Pfalzbahn
Thank you all for the response to my "problem".
Yes, the delay was with a new Loco.
I am getting closer to buy the CS3+.
Pfalzbahn
CS2 and catenary analogue (General MRR)
by Bryan 12/04/2024 23:50:12(UTC)
CS2 60215 with 6021 slave (Digital)
by Willr 09/03/2024 00:05:11(UTC)
CS2 upgrade to CS3 (Digital)
by rhfil 11/12/2023 00:39:07(UTC)
CS2/CS3 multiprotocol Wave form (Digital)
by peter_moulin 07/11/2023 12:43:12(UTC)
CS2 firmware update (Digital)
by gbel78 20/10/2023 17:45:06(UTC)
Central Station CS2 (General MRR)
by gbrendem 13/10/2023 19:52:37(UTC)
Marklin CS2 60213 (H0-scale)
by Kuhan 09/09/2023 14:41:33(UTC)
Setting up CS2 (General MRR)
by Drongo 25/08/2023 02:01:03(UTC)
CS3/CS2 - same loco different photos (Digital)
by twmarklinfan 26/07/2023 00:51:29(UTC)
CS2 and programmer programming decoder question (H0-scale)
by billyamy 18/07/2023 21:37:04(UTC)
CS2 : s88Link and Booster use same port : how do I connect them both ? (Digital)
by Johnvr 06/07/2023 13:04:58(UTC)
Märklin MFX+ is not registering to CS2 after factory reset (Digital)
by applor 11/06/2023 23:12:15(UTC)
Mapping and adjusting functions on the Giruno using CS2 (Digital)
by PeFu 29/05/2023 06:46:31(UTC)
CS2 failure to start (Digital)
by gamolina 23/05/2023 01:08:52(UTC)
Does the CS2 have "events" like the CS3 (General MRR)
by Drongo 31/03/2023 08:40:57(UTC)
RailControl Pro — CS2 and CS3 controller for iPhone, iPad and Mac (Model railroad software)
by northstar 24/02/2023 15:29:28(UTC)
Which is latest software version for CS2 60213 ? (Digital)
by Johnvr 13/02/2023 19:58:43(UTC)
Voltage input for CS2 (Digital)
by Juan Carlos Carbonel 05/02/2023 04:28:02(UTC)
Märklin CS2.exe (Model railroad software)
by w4sepp 09/11/2022 10:44:12(UTC)
Little problem with my CS2 (Digital)
by Thewolf 07/11/2022 23:52:12(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
Lenz LS150 address change not responding - CS2 vs lokprogrammer (Digital)
by applor 26/10/2022 01:12:52(UTC)
CS2 compared to CS3 (Digital)
by mrunix 30/09/2022 23:44:03(UTC)
Märklin CS2 (Digital)
by Rolando 07/09/2022 13:08:56(UTC)
Central Station CS2 (Digital)
by Rolando 31/08/2022 13:19:36(UTC)
by Rolando 24/08/2022 10:11:46(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
Need help upgrading CS2 (Digital)
by nelson77 17/06/2022 18:06:58(UTC)
Computer software with Marklin CS2 (General MRR)
by Christo Swanepoel 25/04/2022 19:16:22(UTC)
New Updates for CS2 ( Software 4.3.0 ) and MS2 ( Software 3.148 ) (Digital)
by FrankF 23/03/2022 14:49:22(UTC)
cs2 back (Digital)
by Thewolf 11/12/2021 18:32:28(UTC)
Cable extension from S88Link (60883) to cs2 (60215) (Digital)
by Thewolf 06/12/2021 23:19:19(UTC)
Accessories/Cables for CS2? (Digital)
by Shay 16/09/2021 17:32:30(UTC)
CS2 update and Digital Switch recognition and action (Big scale)
by Inspectorate56 19/08/2021 15:55:07(UTC)
CS2 software upgrade. (Digital)
by Barby & Stan 16/08/2021 22:37:28(UTC)
Adding sounds to a Shuttle route using a CS2 (Digital)
by Elsleuth1 29/06/2021 21:56:13(UTC)
Loco Icons & CS2 (Digital)
by Timnomads 21/06/2021 08:37:42(UTC)
MUs in CS2 and CS3 (H0-scale)
by Timnomads 10/05/2021 10:07:53(UTC)
CS2 issues (H0-scale)
by Airfix05 20/04/2021 17:03:56(UTC)
CS2 60215 English manual (Digital)
by Donb 16/04/2021 17:36:40(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
New Software-Update for CS2 (60215/60214/60213) and MS2 (60653/60657) (Digital)
by FrankF 26/02/2021 22:23:59(UTC)
Copy data from CS2 to CS3 plus (Digital)
by gachar001 24/02/2021 07:15:23(UTC)
Märklin CS2 is loading, loading, loading but not starting? (Digital)
by jaakkomu 11/02/2021 19:27:06(UTC)
How to setup the turnout indication in Marklin CS2 (Digital)
by arniland 23/01/2021 17:20:23(UTC)
Mfx locomotives not found by CS2 - Solutions? (Digital)
by Martin T 21/01/2021 20:22:52(UTC)
bizarre problem CS2 / iPhone mobile station with turnout control (Digital)
by applor 03/01/2021 01:23:21(UTC)
7286 turntable with LDT TT-DEC - CS2 step turn doesn't work properly (Digital)
by applor 29/12/2020 22:56:15(UTC)
LokPilot 4 decoder OK in LokProgrammer but not with CS2 (Digital)
by PeFu 28/12/2020 17:46:56(UTC)
CS2 or PSU issue? (Digital)
by Borsig-Werke 08/12/2020 17:38:36(UTC)
This page was generated in 0.919 seconds.
