Offline sudibarba
#1 Posted : 02 August 2006 05:24:00(UTC)
sudibarba
I am new to the new Central Station 60212. I know some of its features etc. but I am wondering if you can use 6604/66045s as boosters as with the 6021.
Eric
Offline Lars Westerlind
#2 Posted : 02 August 2006 12:30:41(UTC)
Lars Westerlind
The 6604/66045 should be usable to some degree with almost any digital central, as it has no digital intelligence and knows nothing about the protcol. It just boosts it.
But if you use it, there are two drawbacks:
1. The feedback info about what locos are present is lost =>
1a. When staring up, an loco run by mfx must be placed first on a section driven by the CS directly.
1b. When the mfx driven loco gets to the section powered by the Delta, the display will start to flash, howerver, still be working.
2. There is a slight delay in the Delta. When trains go from sections of the CS to sections of the Delta, there will be a minor short. Therefore it's often recommended not to mix Delta sections and CS/Mobstat sections, either by
- Using Deltas for turnout/sinals only
- Using only Deltas for the layout, and the output of MobStat/CS as programming track+turnouts.
In fact, the latter is a good way if you want to run a big layout from MobStat (the only way more or less). The first is a good way with a CS.
/Lars
#3 Posted : 03 August 2006 22:42:15(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />2. There is a slight delay in the Delta. When trains go from sections of the CS to sections of the Delta, there will be a minor short
Yes, that's right. One should use a rocker on the center rail to avoid the short (it's said that this short can damage a mobile station ...).
Offline MHauge
#4 Posted : 03 August 2006 22:53:37(UTC)
MHauge
How much can a Mobile Station handle ?
My current layout :
Around 10 meters of track, normaly 1-2 trains running at once, tried 4, went ok.
Lights/turnouts handled by another trafo.
It's the 1.2A Mobile Station from startset i have.
Am i close to the limit ?
Michael
Märklin C-tracks, Mobile Station, Danish Ep 4
DIY Boosters for CS3?? (Digital)
by BenPerr Yesterday at 04:37:38(UTC)
Recall of Märklin boosters 60175 (Digital)
by Unholz 29/07/2022 15:08:29(UTC)
Using boosters with MS2 (General MRR)
by Sean McClaymore 08/04/2022 11:32:08(UTC)
How to connect boosters please (Model railroad wiring)
by DV 25/11/2021 04:07:24(UTC)
CS3 with multiple boosters (Digital)
by Klarsyn 17/09/2020 17:01:47(UTC)
Old Transformers and boosters (Digital)
by Drjoe11 25/08/2018 19:59:56(UTC)
Connecting CS2, L88, Boosters (Digital)
by Harvey 20/02/2017 16:32:03(UTC)
Boosters and free booster recall/upgrade (General MRR)
by baggio 24/01/2017 05:37:59(UTC)
Boosters, power supplies and overload situations (Digital)
by sjlauritsen 15/11/2014 10:30:33(UTC)
Rocker insulator(s) needed for separate boosters (Model railroad wiring)
by michelvr 30/10/2014 15:51:44(UTC)
Boosters and emergency stop (Digital)
by sjlauritsen 10/09/2014 10:04:06(UTC)
60215 compatible Boosters (Digital)
by Hackcell 27/01/2014 00:00:01(UTC)
Connecting Mobile Station to non-mfx boosters (Digital)
by Gregor 05/08/2013 20:43:43(UTC)
"Large" layouts and boosters (Digital)
by PMPeter 20/04/2013 05:50:47(UTC)
Extra boosters with the CS2 (Digital)
by charles Sharpe 17/04/2013 05:50:54(UTC)
boosters and cs2 and electrical shorts (Digital)
by Andreas K 16/11/2012 12:34:27(UTC)
Power - Boosters? (Model railroad wiring)
by NewMB 19/06/2012 16:44:02(UTC)
Marklin CS1, 6017 Boosters & MFX loco (Digital)
by ycliew 27/12/2011 11:34:18(UTC)
Ecos 1 and power 3 boosters (Digital)
by pab 20/11/2011 10:57:05(UTC)
Layouts with boosters and MS2 and CS2 (Digital)
by Kodiak 28/04/2010 11:26:36(UTC)
CS, Boosters and ski-lifters (Digital)
by mjrallare 24/10/2009 20:27:05(UTC)
Homemade boosters (Digital)
by rschaffr 11/04/2009 01:30:22(UTC)
Grounding betw. transformers connected to boosters (Digital)
by svgeorgiad 28/03/2009 13:15:07(UTC)
Difference between 60173 and 6015/17 boosters? (Digital)
by mjrallare 09/01/2009 18:13:12(UTC)
CS/ New Boosters (Digital)
by charles Sharpe 27/11/2008 20:33:22(UTC)
CS & Boosters (Digital)
by David Dewar 28/06/2008 17:56:23(UTC)
Power/boosters (Digital)
by charles Sharpe 23/02/2008 21:59:27(UTC)
power/boosters (General MRR)
by charles Sharpe 01/06/2007 21:47:09(UTC)
Boosters (Digital)
by charles Sharpe 31/05/2007 21:19:34(UTC)
Boosters? (Digital)
by Dick 26/05/2007 02:31:58(UTC)
Marklin boosters 6015 and 6017 and ECOS (Digital)
by diesel 15/04/2007 01:52:52(UTC)
Reasonably Priced 6017 Boosters? (Digital)
by kerz 18/01/2007 07:58:35(UTC)
Power and Boosters (Digital)
by huttel 27/10/2006 21:14:26(UTC)
Boosters (Digital)
by Andy18 05/10/2006 04:15:23(UTC)
Understanding boosters (Digital)
by tommyheadleycox 19/03/2006 18:12:49(UTC)
60129 Connect 6017 for old boosters. (Digital)
by steventrain 11/12/2005 11:15:22(UTC)
The new boosters and 6021 (Digital)
by Nuno 23/11/2005 21:06:30(UTC)
LDT Boosters (Digital)
by robertrt 11/10/2005 02:19:20(UTC)
Digital Help: CS/Intellibox/6021 w/ Boosters (Digital)
by 5HorizonsRR 14/09/2005 09:48:11(UTC)
Boosters (Digital)
by tnx jake 26/04/2005 06:36:38(UTC)
Multiple boosters (Digital)
by Gregor 06/12/2004 21:35:51(UTC)
Boosters and s88 (Digital)
by xxup 05/11/2004 13:55:03(UTC)
Marklin Boosters (Digital)
by tnx jake 28/09/2003 21:56:10(UTC)
This page was generated in 0.410 seconds.
