Offline charles Sharpe
#1 Posted : 31 May 2007 21:19:34(UTC)
charles Sharpe
Hi I know this subject has been talked about lots of times but here goes.I have the centrel station with a mobil station connected to it. I am using c track . On the lower level I am running 2 trains 1 with lights in all 3 of the carriages and both with lights on the front of the trains also on that level are 73 feet of track and 22 turnouts. On the first floor I am running a BR160 with lights and sound on also BR03 with lights/sounds /smoke/etc 64 feet of track 31 turnouts and 2 uncouplers.Today the smoke on the BR03 and the lights on the uncouplers would not work unless I turned lots of fuctions off I have put this down to lack of power am I right wave length. Please could you help me.As I am new to this I do not know the old maerklin digital system.
CHARLES SHARPE
#2 Posted : 31 May 2007 22:41:05(UTC)
I've read this on another forum, too.
Are you using an AC transformer?
The CS should have enough power for your trains, but maybe the buffering capacitor is too small.
A booster will definitely help; a new power supply for the CS could help. Adding buffering capacitors might help, too, but I haven't seen the inside of a CS yet so I can't say if there's space for that.
Offline hemau
#3 Posted : 01 June 2007 14:21:41(UTC)
hemau
Have you changed anything to the wiring? I had a problem with a BR 18 not smoking which was caused by having the + and - (from the programming track to the boosters) wrong (the outputvoltage of the MS/CS is not symmetrical).
Otherwise look for a shortcut. A lack of power does not come out of the blue.
Regards, Henk
C and M track; CS1R and 2 MS
#4 Posted : 01 June 2007 21:38:16(UTC)
charles Sharpe
Hi Hemau. No I have not changed anything to the wiring and at the moment I have no booster.
CHARLES SHARPE
Offline hofan
#5 Posted : 17 June 2007 02:29:54(UTC)
hofan
I have similar power issues, perhaps due to layout size 120 feet of C track. Mobile station is running w/ 6001 transformer. I have two spare 6001 transformers and just got a CS for Father's Day and wondering if the following advice from the Ditital Corner "Dummies" article would work. Part Number for Delta controller? Red cable to Digital signal? anyone with more specific advice?
"The second is a smart and cheap thing. The DELTA Control may be used as a booster, if the knob is set to the rightmost position, the DELTA Pilot connections are connected together, the red cable connected to the digital signal of the Central unit. It delivers maximum about 30 VA, and is much cheaper than the standard booster."confused
Rick Hall
Let 'em Roll
#6 Posted : 17 June 2007 18:31:44(UTC)
The number of trains and coaches with lighting should not be a problem for your CS.
Turnouts which you will use one at a time I presume also will not effect the performance. Lights on the uncouplers again do not take much power...does the uncoupler work not not the light?
What transformer are you using?
My layout runs with more than you are using and I have not as yet had any problems.
David
Offline hemau
#7 Posted : 17 June 2007 19:46:30(UTC)
hemau
Hi Rick, welcome to the forum!
The part number of the Delta Control is 6604 (old model) and 66045 (newer model). I have two MS on a separate programming track and I use two of those Delta's to power my layout in two sections. This works fine since the Delta's have more and more stable power than the MS (even the 1,9 A version which I have). Some time ago the wiring scheme was even publicised by Marklin Netherlands. See for instance http://home.wanadoo.nl/j...oen.visser/marklin15.htm (I just got this with Google and delta control booster as search items). Text is in Dutch but the picture is clear enough.
But if you just got a CS, using a Delta Control as booster is not a good solution. I don't think the CS and the Delta Control could work on two only electrically separated parts of the layout since there is some delay in the signal from the Delta. And maybe other (severe) problems for the newer electronics if they get connected through a passing loco. You would need a ski-jumper.
And it would be a waste to use the CS only to power a programming track.
Best regards, Henk
#8 Posted : 17 June 2007 23:41:30(UTC)
Welcome to the forum,Rick.Smile
Offline hemau
#9 Posted : 18 June 2007 00:09:41(UTC)
hemau
Rick,
If you're only using one feed for your 120 feet of C-track maybe you should try more feeding wires (separate wires from the connecting track/box to other parts of the layout). In every rail connection you loose a little bit of power.
Regards, Henk.
Recall of Märklin boosters 60175 (Digital)
by Unholz 29/07/2022 15:08:29(UTC)
Using boosters with MS2 (General MRR)
by Sean McClaymore 08/04/2022 11:32:08(UTC)
How to connect boosters please (Model railroad wiring)
by DV 25/11/2021 04:07:24(UTC)
CS3 with multiple boosters (Digital)
by Klarsyn 17/09/2020 17:01:47(UTC)
Old Transformers and boosters (Digital)
by Drjoe11 25/08/2018 19:59:56(UTC)
Connecting CS2, L88, Boosters (Digital)
by Harvey 20/02/2017 16:32:03(UTC)
Boosters and free booster recall/upgrade (General MRR)
by baggio 24/01/2017 05:37:59(UTC)
Boosters, power supplies and overload situations (Digital)
by sjlauritsen 15/11/2014 10:30:33(UTC)
Rocker insulator(s) needed for separate boosters (Model railroad wiring)
by michelvr 30/10/2014 15:51:44(UTC)
Boosters and emergency stop (Digital)
by sjlauritsen 10/09/2014 10:04:06(UTC)
60215 compatible Boosters (Digital)
by Hackcell 27/01/2014 00:00:01(UTC)
Connecting Mobile Station to non-mfx boosters (Digital)
by Gregor 05/08/2013 20:43:43(UTC)
"Large" layouts and boosters (Digital)
by PMPeter 20/04/2013 05:50:47(UTC)
Extra boosters with the CS2 (Digital)
by charles Sharpe 17/04/2013 05:50:54(UTC)
boosters and cs2 and electrical shorts (Digital)
by Andreas K 16/11/2012 12:34:27(UTC)
Power - Boosters? (Model railroad wiring)
by NewMB 19/06/2012 16:44:02(UTC)
Marklin CS1, 6017 Boosters & MFX loco (Digital)
by ycliew 27/12/2011 11:34:18(UTC)
Ecos 1 and power 3 boosters (Digital)
by pab 20/11/2011 10:57:05(UTC)
Layouts with boosters and MS2 and CS2 (Digital)
by Kodiak 28/04/2010 11:26:36(UTC)
CS, Boosters and ski-lifters (Digital)
by mjrallare 24/10/2009 20:27:05(UTC)
Homemade boosters (Digital)
by rschaffr 11/04/2009 01:30:22(UTC)
Grounding betw. transformers connected to boosters (Digital)
by svgeorgiad 28/03/2009 13:15:07(UTC)
Difference between 60173 and 6015/17 boosters? (Digital)
by mjrallare 09/01/2009 18:13:12(UTC)
CS/ New Boosters (Digital)
by charles Sharpe 27/11/2008 20:33:22(UTC)
CS & Boosters (Digital)
by David Dewar 28/06/2008 17:56:23(UTC)
Power/boosters (Digital)
by charles Sharpe 23/02/2008 21:59:27(UTC)
power/boosters (General MRR)
by charles Sharpe 01/06/2007 21:47:09(UTC)
Boosters? (Digital)
by Dick 26/05/2007 02:31:58(UTC)
Marklin boosters 6015 and 6017 and ECOS (Digital)
by diesel 15/04/2007 01:52:52(UTC)
Reasonably Priced 6017 Boosters? (Digital)
by kerz 18/01/2007 07:58:35(UTC)
Power and Boosters (Digital)
by huttel 27/10/2006 21:14:26(UTC)
Boosters (Digital)
by Andy18 05/10/2006 04:15:23(UTC)
Boosters (Digital)
by sudibarba 02/08/2006 05:24:00(UTC)
Understanding boosters (Digital)
by tommyheadleycox 19/03/2006 18:12:49(UTC)
60129 Connect 6017 for old boosters. (Digital)
by steventrain 11/12/2005 11:15:22(UTC)
The new boosters and 6021 (Digital)
by Nuno 23/11/2005 21:06:30(UTC)
LDT Boosters (Digital)
by robertrt 11/10/2005 02:19:20(UTC)
Digital Help: CS/Intellibox/6021 w/ Boosters (Digital)
by 5HorizonsRR 14/09/2005 09:48:11(UTC)
Boosters (Digital)
by tnx jake 26/04/2005 06:36:38(UTC)
Multiple boosters (Digital)
by Gregor 06/12/2004 21:35:51(UTC)
Boosters and s88 (Digital)
by xxup 05/11/2004 13:55:03(UTC)
Marklin Boosters (Digital)
by tnx jake 28/09/2003 21:56:10(UTC)
This page was generated in 0.733 seconds.
