Offline Deborail
#1 Posted : 18 October 2009 14:33:27(UTC)
Deborail
United Arab Emirates
My loco had one of its traction tires removed due to possible debris on the line, i managed to put back again without unscreweing anything...Is this a common occurence?? I noticed that the sound was different....
George
Given enough time, tasks manage themselves.
#2 Posted : 18 October 2009 14:36:25(UTC)
It can be a fairly common occurrence. I've had several locos drop a tyre lately. They can come of if they get worn down a bit. I just replace them with a new one.
#3 Posted : 18 October 2009 17:30:05(UTC)
The higher speed,the more wear of traction tire!
So you MUST change out the old one,to replacement a new one!
#4 Posted : 18 October 2009 17:51:51(UTC)
Worn tyres, greasy track or oil spilled track, too much load behind loco.
regards.,
#5 Posted : 18 October 2009 18:19:35(UTC)
This has happened to me when the loco wheels slip a lot. The friction causes excessive heat which makes the tyres expand and come off the wheel.
Solution - New tyres and clean track.
Offline gachar001
#6 Posted : 18 October 2009 18:58:21(UTC)
gachar001
India
I have a hobby loco that occationally drops one of it's traction tyres. The sound changes when the tyre is missing.
I use a paper clip to put it back.
None of my other locos have dropped a tyre so far.
Gautham
Atlanta, GA USA
#7 Posted : 18 October 2009 20:24:28(UTC)
<br />This has happened to me when the loco wheels slip a lot. The friction causes excessive heat which makes the tyres expand and come off the wheel.
Some of my electric locos (BR 101, BR 151, BR 182) use tyres quite easy when the wheels slip a few seconds (e. g. if one loco is pushing against another loco (which only occurs if I didn't pay attention)).
A friend told my to try the smaller tyres for these locos.
Since I didn't have this problem for many months now (sometimes I do pay attention), I haven't tried it yet.
Since there are only four sizes of traction tyres, they fit tighter on some locos and looser on others.
Offline al_pignolo
#8 Posted : 18 October 2009 20:54:20(UTC)
al_pignolo
Four sizes? [:0][:0][:0] I believed three!
7152: Large
7153: Medium
7154: Small
What is the fourth size???
Pietro
Offline Brakepad
#9 Posted : 18 October 2009 21:01:33(UTC)
Brakepad
France, Metropolitan
[size=1" face="Verdana" id="quote]quote:Originally posted by al_pignolo
<br />Four sizes? [:0][:0][:0] I believed three!
7152: Large
7153: Medium
7154: Small
Pietro
Märklin 7151 (I guess that these ones should be extra-large).
#10 Posted : 18 October 2009 23:08:55(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Brakepad
<br />Märklin 7151 (I guess that these ones should be extra-large).
No, XXS. wink
I know that BR 628 has 'em.
traction tire for Marklin 89005 engine (H0-scale)
by rabtab 04/02/2025 18:37:21(UTC)
3000 add traction tire (H0-scale)
by Brian_BR96 18/06/2024 01:41:48(UTC)
Traction tires (General MRR)
by rhfil 22/11/2023 15:19:10(UTC)
Changing traction tires on 37780 ICE 3 center power unit (General MRR)
by artvegas 05/10/2023 17:57:02(UTC)
cheapest traction tires ever!! (H0-scale)
by heinrichhess 05/09/2023 20:04:30(UTC)
Uneven traction tires on 39027 and 39491 (Br 02 0314 and DSB E 991) (H0-scale)
by bph 13/05/2022 23:24:15(UTC)
Rokuhan Traction Tires (Small scale)
by zoooctan 30/04/2022 19:39:18(UTC)
traction tires for marklin miniclub (Small scale)
by parakiet 12/11/2021 12:39:08(UTC)
Traction tires (H0-scale)
by Mr. Ron 28/06/2021 02:56:26(UTC)
Traction tire part number for 3060? (H0-scale)
by artfull dodger 24/02/2019 03:55:23(UTC)
Lok #3440 threw a traction tire on an oval (H0-scale)
by walters48 15/04/2017 02:33:25(UTC)
Traction tires for 3007/SK 800 (Collector's Corner general)
by Soest 22/03/2017 18:24:42(UTC)
traction tire help (H0-scale)
by thomas buckley 08/09/2016 01:22:23(UTC)
3048 traction tires/all loco tires (H0-scale)
by thomas buckley 27/03/2016 21:11:41(UTC)
Alternative to rubber traction tires on locos (General MRR)
by Danlake 09/10/2013 09:19:32(UTC)
Traction Tires / Brushes (General MRR)
by kimmiemck 07/09/2013 17:19:54(UTC)
traction tires for marklin engines (H0-scale)
by reverendpen 10/06/2013 19:36:21(UTC)
Traction Tires for King Ludwig Tristan Loco and #33041 Loco (Digital)
by wsscott 03/12/2012 18:36:30(UTC)
Traction Tire Replacement (H0-scale)
by Answ 25/10/2012 06:24:35(UTC)
Old Plastic Traction Tires Stuck-Help Please (H0-scale)
by walters48 01/02/2010 03:09:46(UTC)
traction tire fitting - Solved (H0-scale)
by Darren W 20/11/2009 21:36:24(UTC)
Senator traction tires (H0-scale)
by rschaffr 19/01/2009 23:47:59(UTC)
Contact track and traction tires (Digital)
by laalves 07/11/2006 00:49:04(UTC)
Traction tires on Marklin Locs (General MRR)
by biswasg 01/01/2006 23:46:26(UTC)
Aging of Traction Tires (General MRR)
by digilox1 04/11/2005 09:16:21(UTC)
Adding traction tires (H0-scale)
by Winst0n 21/06/2004 01:08:12(UTC)
This page was generated in 0.499 seconds.
