Offline Nuno
#1 Posted : 22 January 2004 18:57:23(UTC)
Nuno
You have been a member since:: 27/05/2003(UTC)
Does anyone know whether there is a rule for which pantograph should be raised? I mean, should the front or the rear pantograph be up when travelling in front? Because I think it's never both at the same time!
And what about trains like the ICE? Normally, they have 2 pantographs on, but why only 2 and which 2 of them?
Nuno Smile
Offline craigericks
#2 Posted : 22 January 2004 19:28:55(UTC)
craigericks
Nuno,
Will answer based on memory of what I read on a train related site awhile ago. My apologies if it was someone in this forum.(I did a search but could not find)
Rear always used unless the first car after lok carries a flammable substance or is a passenger car. Rationale: If front pantograph is in use and collapses or breaks apart then the debris could possible damage rear pantograph. Rear is not used for flammable or passenger for safety considerations.
All, please correct me where I have gon wrong.
Craig
Marklin:CS2 and TrainController Gold v10
Offline Thanos
#3 Posted : 23 January 2004 11:28:14(UTC)
Thanos
I have a manual for the Class 46 Electric Locomotive for a specific line. I will post some points concerning pantographs. I think that rules are different according to the locomotive, the nature and condition of the overhead wires, the load of the train, the required speed, etc.
If you want to check out how the electric locomotives work go to: http://www.trainweb.org/railwaytechnical/tract-02.html.
Some of the points in the manual follow:
<ul>
<li>Raising or lowering of pantographs must never be done whilst any current is being drawn. Current is being drawn when either the throttle is open or any of the four auxiliary high tension machines are running.</li>
<li>During light engine running the rear pantograph only is to be employed.During all train working both pantographs are to be employed. If only one pantograph is employed in train working all of the machines may be adequately fed, but severe sparking would take place if the current draw was heavy. However, between Westmead and points East thereof where two or more locomotives are attached, only one pantograph is to be employed on each locomotive. This exception is due to the lighter nature of the overhead wire.</li>
<li>A Red Stop Board means stop and lower and isolate all pantographs if the 46 class locomotive is required to be hauled beyond that point.</li>
<li>Pantograph Raising and lowering reactions are to be visually inspected by the fireman-observer, with report to the driver.</li>
<li>Before entering a high tension compartment as well as operating the lowering and isolating pantograph mechanism, it is essential to observe that the pantographs have folded down. It is quite possible for the pantograph to remain in contact with the overhead wire
after lowering magnet valves have been operated, due to stiffness of the pantograph details.</li>
<li>To raise a pantograph it is necessary to have a supply of compressed air and to route it to the pantograph cylinder on the roof.</li>
<li>To lower a pantograph it is necessary to prevent air flow to the roof cylinder and to discharge that air already present.</li>
<li>These actions may be made by hand manipulation of the armature plate of the pantograph magnet valve, and this method may be used when a fault exists in the raising or lowering buttons on the cab desk panel.</li>
</ul>
Thanos
Offline Gregor
#4 Posted : 23 January 2004 13:22:41(UTC)
Gregor
Hi All,
I live close to the tracks and most (Dutch) trains use the rear pantograph only, regardless whether the first car is a passenger or flammable freight car.
I have seen once a train depart with both pantographs in use, and lower one after getting to speed. There were no sparks, which would mean that there might be some kind of internal switch, that was opened, before the pantograph was lowered. Whether the engineer was following the rules or not, I cannot know of course.
We have to keep in mind that the Dutch railway net operates on realy low voltage (1500V DC) hence high current, so an internal anti-arc switch might be possible, I guess.
Gregor
Offline KLB
#5 Posted : 24 January 2004 00:54:53(UTC)
KLB
I have also heard that if weather conditions are bad(ice,snow,freezing rain)that both can and should be used,...true?
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Offline rugauger
#6 Posted : 25 January 2004 01:45:03(UTC)
rugauger
I'm with Craig on this one - rear pantograph, unless flammable liquid in the first car in freight trains (the Dutch are obviously not worried about setting fire to their trains wink ). An exception could be bad contact, e.g. in icy conditions, where both are used, although I cannot recollect ever having seen this myself.
Richard
Offline perz
#7 Posted : 25 January 2004 02:13:25(UTC)
perz
I have read in an old book (from 1956) about Swedish trains that they did not build streamlined electric locos because it didn't work with the pantographs. On a loco with streamlined front, the air stream pressed the front pantograph upwards and caused it to wear out too quickly. If they used the rear one, the turbulence on the other hand caused bad contact and sparkling. So they decided to use the front pantograph and have square fronts on the locos. Since then, knowledge about aerodynamics have improved a lot, but the aerodynamics of the loco may still play an important role when deciding upon which pantograph to use.
Offline Gregor
#8 Posted : 25 January 2004 15:39:42(UTC)
Gregor
Until today all the electric trains on my layout used the rear pantograph only (I applied the Dutch system H0-worldwide), but now I understand that I have to change it for at least the non-Dutch loc's.
I remember that in a Marklin catalogue of somewhere in the 80's a story is told about the Swiss crocodile. One pantograph was covered with snow, and because of the weight of the snow, the pantograph would not rise. The engineer wanted to push the pantograph up, using a broom, but his assistant noticed that the other pantograph had already reached the catanary, so full voltage was present on the first one as well (no switch apparently in the crocodiles). He was just in time to kick the broom out of the engineer's hand.
Gregor
Offline rugauger
#9 Posted : 25 January 2004 21:55:01(UTC)
rugauger
[size=1" face="Verdana" id="quote]quote:Originally posted by Gregor
<br />... He was just in time to kick the broom out of the engineer's hand.
So much for electric locos being safer... wink
Richard
Offline Nuno
#10 Posted : 27 January 2004 20:49:09(UTC)
Nuno
Thanks a lot, all of you.
I'm amazed with so many rules and options and problems and opinions [:0]. I thought the answer could be much simpler!
And I am also really impressed with so much expertise from you.
Now I can impress my friends when I show them my layout, explaining why that loco has this or that pantograph on! biggrinbiggrin
Nuno Smile
#11 Posted : 16 February 2004 19:07:43(UTC)
I'd like to add two points to the discussion:
1. Locos with old-style pantographs (single wiper) would normally run with both pantographs up. Locos with modern double-wiper pantographs (introduced 1954) only raise one pantograph.
2. I think there is a misunderstanding about "passenger cars" with respect to pantographs.
German locos use the rear pantograph unless the following car has windshield windows (loco, passenger car with windshield (i.e. cab car), freight car with new cars) or carries flammable substances.
If two locos pull a train, the first loco normally raises the front pantograph, the second loco raises the rear pantograph (to maximize the distance between pantographs to reduce the effects of swinging catenary). If two locos pull a train with new cars or flammable liquids, both will raise the front pantograph - the train may have to reduce speed because of the swinging catenary.
Thomas wink
Raising the pantographs on märklin 39365 (H0-scale)
by Evergreen 11/04/2025 21:53:23(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
M28590 piezo pantographs (H0-scale)
by QQQ1970 20/04/2024 21:04:43(UTC)
Pantographs (Prototype)
by Mr. Ron 24/06/2023 21:55:49(UTC)
Pantographs (General MRR)
by river6109 05/07/2022 13:10:28(UTC)
Marklin 39126 - Pantographs not working (General MRR)
by tomdakl 24/06/2022 03:08:03(UTC)
39445 E 44.5 2020 Insider - Pantographs (H0-scale)
by Donb 28/10/2021 06:51:11(UTC)
How do I raise the pantographs on my Spur 1 5756 Krokodil? (Big scale)
by JPL44 24/04/2021 18:01:29(UTC)
Adjusting Pantographs (Big scale)
by Surge 01/10/2020 00:42:32(UTC)
Pantographs for DL 800 (H0-scale)
by rhschulz2000 11/08/2018 01:43:32(UTC)
Maerklin 39460 SBB Re 460 Helvetia with Faiveley Pantographs and new motor (Loco Reviews)
by mike c 28/12/2017 04:42:52(UTC)
Working pantographs (General MRR)
by jcrtrains 07/03/2017 02:05:53(UTC)
Fixing pantographs (H0-scale)
by Gregor 18/04/2015 19:09:59(UTC)
Need pair of pantographs for Hag Bühler Ae 6/6 (older version) (H0-scale)
by Marklinista 22/10/2014 12:56:29(UTC)
How many models with Piezo Pantographs? (General MRR)
by cookee_nz 15/06/2014 04:14:22(UTC)
Pantographs with new marklin catenary (H0-scale)
by marklin61 16/02/2014 10:42:11(UTC)
37224 pantographs. (H0-scale)
by steventrain 10/12/2013 22:09:23(UTC)
fixing Märklin wobbly pantographs (General MRR)
by river6109 27/10/2013 09:31:09(UTC)
When Are Diner Pantographs In Use? (Prototype)
by Roman 09/08/2013 02:28:30(UTC)
remote control pantographs (H0-scale)
by sleepvark 02/08/2013 21:18:55(UTC)
Adjusting pantographs on locomotives (H0-scale)
by sjlauritsen 22/06/2013 12:54:33(UTC)
Marklin Budbet Traxx pantographs (H0-scale)
by danmarklinman 31/10/2012 14:40:02(UTC)
Pantographs?? (Prototype)
by Dimi194 13/06/2012 00:52:17(UTC)
Marklin ELok Pantographs. (H0-scale)
by James 25/02/2011 20:35:39(UTC)
Electric loco with 4 pantographs. (H0-scale)
by steventrain 26/10/2010 23:45:38(UTC)
by Dreadnought 22/09/2010 01:37:55(UTC)
by Dreadnought 08/01/2009 04:15:29(UTC)
Make dummy pantographs work (H0-scale)
by dandrikop 24/08/2008 01:32:25(UTC)
Raising pantographs on marklin 39221 (H0-scale)
by grnwtrs 11/01/2008 07:59:29(UTC)
M* and pantographs mounted the wrong way (General MRR)
by H0 05/04/2006 00:59:21(UTC)
Silly Question on Pantographs (H0-scale)
by wilki 04/03/2004 14:29:04(UTC)
This page was generated in 0.371 seconds.
