Offline Willr
#1 Posted : 30 January 2025 02:46:44(UTC)
Willr
Hi.
I recently acquired a 052-1911 model 34171 which was upgraded from delta at some point
in it's life to a DCC decoder.
I have it running with my CS2 but have no idea of make or model of decoder, or if and what other functions
are available.
Can anyone identify it for me please.
thanks 1 user liked this useful post by Willr
#2 Posted : 30 January 2025 09:13:51(UTC)
Looks like an ESU V4 decoder. Blue decoder PCB is typical for ESU decoders.
Reading CV 8 should give 151 for ESU.
#3 Posted : 30 January 2025 14:25:07(UTC)
That is my thought too. It may well be a multiprotocol version, so have MM2 and mfx as well.
Offline mario54i
#4 Posted : 30 January 2025 15:37:53(UTC)
mario54i
ESU decoders usually have a round white label with a code, not a square green one.
#5 Posted : 30 January 2025 17:08:20(UTC)
But I don't think that is the original heatshrink.
#6 Posted : 30 January 2025 21:52:32(UTC)
Speaking of ESU decoders, I have the body off my 39120 E 10 (soft drive sinus can motor) from 2007. The decoder is a blue 21 pin with a white round serial number sticker. An early MFX model, with a whistle and one station announcement. I'm curious as to weather an ESU upgrade sound decoder or a Marklin 21 pin msd3 with electric Loco. sounds would be appropriate. I don't have a decoder tool, and I don't know if ESU sells decoders with pre loaded sound files except with models.
Offline applor
#7 Posted : 30 January 2025 23:57:39(UTC)
applor
They used to with the old V3 / 3.5 but I believe now the process is to ask the dealer to pre-load the desired sound project from the ESU collection. You then adjust as required with CV values.
#8 Posted : 31 January 2025 00:27:02(UTC)
Then I don't see why a Marklin decoder wouldn't work. An ESU m4 decoder is mfx.
Offline Willr
#9 Posted : 31 January 2025 03:27:14(UTC)
Willr
Thanks for the input.
I did a quick google on Lokpilot V4.0 and yes it
definitely looks like that.
I'll get it on the program track tomorrow evening.
So, if I check CV8 and it shows 151, that confirms ESU?
Will I also be able to find a model number there?
Or, what should I be looking for to determine what model it is?
#10 Posted : 31 January 2025 07:33:40(UTC)
Yes.
I think by reading CV 7 and other CVs, you can identify the model or at least narrow it down.
Do you happen to know someone with an ESU LokProgrammer? 'That would find all the version information.
Offline Willr
#11 Posted : 01 February 2025 23:26:14(UTC)
Willr
I'm not able to find CV 8 or 7 when I'm looking at the CV table in Prog or POM .
It shows me 1,2,3,4,5, and 17, 18, 29.
#12 Posted : 03 February 2025 08:27:25(UTC)
I'm not able to find CV 8 or 7 when I'm looking at the CV table in Prog or POM.
Yep. Märklin made that bit very complicated on the CS2.
There should be a "+" button or something to that effect, that allows you to add lines for CVs 7, 8, and anything else you need. You can save that list as a template for future use.
#13 Posted : 03 February 2025 15:19:18(UTC)
I've read there is a difference between the original ESU NEM standard 21 pin interface, and the NMRR one, as for which terminal connect to what. So which did Marklin use from 2006 to 2008-ish, and aftewards for msd-3 decoders?
#14 Posted : 03 February 2025 17:27:30(UTC)
Märklin ignore the NEM specifications and the NMRA specifications, instead they adhere to the Märklin/Trix specification of 21mtc.
From 2006 until 2011 they used ESU decoders that were NEM compatible.
In 2008 they introduced homebrew mfx decoders that came in both flavours as needed.
MSD/3 and MLD/3 can be configured to be NEM compatible, NMRA compatible, or neither.
#15 Posted : 03 February 2025 17:47:42(UTC)
Thank's Tom! Would I need a decoder tool to configure a new msd-3 decoder which I want to replace for the original ESU decoder in a soft drive 39120 E-10? Can my dealer do it?
I don't know which Loco sounds are on the 69877 factory decoder, and I know a dealer can load a different sound file.
Offline Willr
#16 Posted : 04 February 2025 12:39:10(UTC)
Willr
Thank you for the info. I will take a look at that later today.
Offline Willr
#17 Posted : 07 February 2025 03:40:29(UTC)
Willr
Well, I can't find anything or any way that helps shed any light on identifying this decoder.
#18 Posted : 07 February 2025 11:31:49(UTC)
Did you read CV 8? What's the value?
Offline Willr
#19 Posted : 08 February 2025 17:08:04(UTC)
Willr
Hi Tom.
The 2nd screen shot is after I press "CV Access".
I'm sure I've pushed ever button. I can't find any place to add 7 or 8.
Thanks for any input you may have.
#20 Posted : 08 February 2025 20:25:00(UTC)
It's been a while since I used that dialogue, but I think this is the button to add new lines to get additional CV numbers:
Offline Willr
#21 Posted : 08 February 2025 20:52:13(UTC)
Willr
Ok, this time I scrolled after tapping that symbol and found some 0 cvs. entered an 8, tried to download from loco, got an error message
that transfer was not successful. I'm not sure if that's correct procedure. I can't find any documentation.
Thought you might be interested in the following pics. Abandoned Northlanders.
Last August I came upon them in North Bay Ontario.
CS3 Failure to Read and thus Write to DCC Decoder. (Digital)
by nikdog 06/04/2024 00:45:33(UTC)
What DCC decoder is in the Albatross (H0-scale)
Belarus Ken70 23/01/2023 13:03:53(UTC)
DCC decoder changed address, stopped responding (Digital)
by applor 27/12/2021 05:05:47(UTC)
Legacy Marklin DCC decoder wire color code (Digital)
by faithie999 13/04/2020 17:34:02(UTC)
DCC decoders full speed reverse after short circuit of programming track (Digital)
by Martin T 02/04/2020 22:55:07(UTC)
Adressing Marklin DCC decoders (Digital)
by amartinezv 01/01/2019 21:56:57(UTC)
CS3 not programming DCC decoders (Digital)
by John Ferguson 19/11/2018 20:37:45(UTC)
DCC decoder issue - CS2 reserved address range? (Digital)
by applor 30/10/2018 22:57:39(UTC)
How to activate DCC decoder (Digital)
by Wirring 04/08/2018 13:40:46(UTC)
Using CS2 to control DCC decoders (Digital)
by Torbjorn 31/07/2018 13:44:24(UTC)
Piko DCC decoder help, Please (Digital)
by danmarklinman 17/01/2017 08:59:12(UTC)
DCC Decoders (Digital)
by jacklr1 28/09/2016 23:06:47(UTC)
Where to buy DCC decoders in UK ? (Digital)
by ocram63_uk 29/12/2015 12:21:54(UTC)
Märklin Einheitsmesswagen 49960 - Conversion to DCC Decoder (H0-scale)
by Moritz-BR365 04/08/2014 08:43:45(UTC)
DCC decoder on M layout??? (Digital)
by duebjerg 07/01/2009 22:27:59(UTC)
do excuse my ignorance - DCC decoder with MS (Digital)
by tekin65 18/01/2007 15:42:59(UTC)
Digitrac DCC decoder and lamp wiring (Digital)
by Hans_Dietrich 22/08/2004 22:46:31(UTC)
This page was generated in 0.599 seconds.
