Offline Ken70
#1 Posted : 23 January 2023 13:03:53(UTC)
Ken70
Does anyone know what specific mfx decoder is in the Albatros. Thank you. Ken70
#2 Posted : 23 January 2023 13:16:05(UTC)
It will be an msd/3, with the appropriate sound project.
The sound project is availble on the product page.
Offline Ken70
#3 Posted : 23 January 2023 13:27:18(UTC)
Ken70
Hi kiwiAlan, Thanks very much for the quick answer. This will really help us. I found that chip in Decoder Pro so I hope things will go smoothly. Ken70
#4 Posted : 23 January 2023 13:30:16(UTC)
A special decoder not being sold separately.
"mfx+" is only available with factory-installed decoders, but not with upgrade decoders.
But it should support most, maybe even all, of the CVs documented for the MSD/3 mentioned by Alan.
#5 Posted : 23 January 2023 15:44:30(UTC)
What exactly is an upgrade decoder? Marklin says each motor/sound decoder they have for retrofitting is MFX.
#6 Posted : 23 January 2023 16:29:53(UTC)
A decoder you buy without a loco.
Yep. But only pre-installed decoders come with "mfx+".
So there is a difference between the Albatros decoder and the retrofit decoders - probably just the firmware. But there may be differences in the CVs supported under DCC.
#7 Posted : 23 January 2023 16:54:05(UTC)
The Decoderpro definition will only have the CVs for the 'upgrade' mfx decoder as that was the only documentation available. I'm not aware of any documentation on any extra CVs an mfx+ decoder may have.
#8 Posted : 23 January 2023 17:22:02(UTC)
Yep. But maybe some of those do not work. The factory-installed decoder could be different or limited. Still worth a try and the basic settings should work.
#9 Posted : 23 January 2023 20:15:23(UTC)
I thought that MFX + meant they have more functions, and or available function terminals for them.
Offline owidgie
#10 Posted : 23 January 2023 23:11:41(UTC)
owidgie
Hi Mike, the "+" in MFX+ means it has a cab view available on the CS2/CS3. I think that is whats called "World of Operation".
Rick
thanks 2 users liked this useful post by owidgie
#11 Posted : 24 January 2023 00:21:59(UTC)
Rick
Correct. Typically function 31 is also reserved for use by World of Operation.
#12 Posted : 24 January 2023 01:05:06(UTC)
Thank's guy's! I should've known that by now. It makes total sense not to have it on aftermarket decoeders as they go into different models. However, I have toggled differnt cabs in the set up config. window while using the w.o.o. cab driver feature.
Offline franciscohg
#13 Posted : 24 January 2023 01:11:42(UTC)
franciscohg
Chile
Hello
The msd3 project should work fine. The decoder of my Br06 burnt due to - in my opinion - a little desigh flaw in the tender (other story). Claiming a warranty would be more time and money consuming for me.so i just got an msd3 and donwloaded the project, other than the lack of cab view, wich i rarely use, the loco works fine with all its functions.
This page was generated in 0.671 seconds.
