Offline MarkMMKT
#1 Posted : 25 November 2024 16:44:56(UTC)
MarkMMKT
Hi everyone!
Im completely new to this hobby and im currently checking out the various of starter packs. One thing though is that all the tracks seems to be curved with only 15degrees angles at maximum. Can this be right? my space for the hobby is limited in width but from what i can deduce a width of minimum 76centimeters is required to make the "turn" is this correct or is there other solutions to make a more "slim track" ?
Thank you for any assistance you can provide a newbie on this exciting hobby :)
thanks 2 users liked this useful post by MarkMMKT
#2 Posted : 25 November 2024 17:01:46(UTC)
Welcome to the forum!
With C track, 360 mm is the smallest radius. Each curve is 30° and 76 cm is the space you need for a full circle in H0 gauge.
Both K track and M track offer smaller radii for H0 gauge.
Maybe look at N gauge and Z gauge to have smaller trains and smaller radii.
Offline Copenhagen
#3 Posted : 25 November 2024 17:39:29(UTC)
Copenhagen
H0 is correct. But I think most model railroaders will advice against using smaller radius than R1 (360 mm radius/760 mm diameter) in H0 scale.
#4 Posted : 25 November 2024 21:25:53(UTC)
In view of limited space I would go for N gauge to allow some dedcent running of locos.
Offline TrainIride
#5 Posted : 26 November 2024 08:18:45(UTC)
TrainIride
Originally Posted by: MarkMMKT Go to Quoted Post
Hi everyone!
Hello !
Welcome to the forum !
Perhaps you can give us more information on the width and length available for your layout.
As for curves, I never had a problem with the R1 radius of 360mm.
All starter set trains use these tracks.
Only some high-end Märklin models are recommended for a minimum R2 radius.
Also see if it is possible to have space at home for looping only,
the rest of the layout can be much narrower.
In the case of my layout,
it is 1m wide at the loops, but not more than 50cm over a long length.
Best Regards
Joël
thanks 3 users liked this useful post by TrainIride
Some Newbie Questions about Analogue Control of Devices (H0-scale)
by AlanC 09/04/2022 16:25:33(UTC)
Spur 1 Märklin/Hübner track newbie questions (Big scale)
by hvc 04/01/2022 10:41:10(UTC)
Newbie Questions (H0-scale)
by berkgenc 13/12/2021 18:57:53(UTC)
Newbie question regarding the M-track (H0-scale)
by popsicle 06/09/2019 17:26:04(UTC)
Some newbie questions on how to connect feeder tracks and lighting (Digital)
by rhNOR 18/04/2019 01:12:19(UTC)
C-track newbie question (H0-scale)
by AshdownSteve 19/01/2017 13:26:17(UTC)
LED strip lighting newbie question (General MRR)
by DV 02/09/2016 06:06:55(UTC)
Newbie Question (General MRR)
by Rkieser 06/12/2015 17:45:52(UTC)
Newbie question re coupler compatibility (H0-scale)
by arawata 21/06/2014 12:23:22(UTC)
Newbie questions...MS2 and K83, and 24624 decoder install (Digital)
by alexaqui 08/01/2013 22:11:13(UTC)
Absolute newbie questions from oldie! (H0-scale)
by marklinboy 23/10/2012 13:33:33(UTC)
Newbie question, loco 37071 (Digital)
by jdk998 06/12/2009 21:38:53(UTC)
Newbie Question (H0-scale)
by walters48 07/09/2009 23:30:13(UTC)
by Mloughran 10/12/2007 05:32:36(UTC)
newbie question on coupling cars (H0-scale)
by Darren W 02/04/2007 21:31:30(UTC)
Newbie question on kadee couplers (General MRR)
by Pianne 30/12/2006 12:27:34(UTC)
Newbie Question: what bits can be upgraded? (General MRR)
by Minok 06/11/2006 07:43:19(UTC)
5 pole motor conversion newbie question (Digital)
by Pianne 31/10/2006 21:37:43(UTC)
Newbie Questions: Prices & FAQ ? (General MRR)
by Minok 15/10/2006 04:25:49(UTC)
Newbie question for Central Station and K83 / K84 (Digital)
by Gert-Jan 14/12/2005 09:25:39(UTC)
Newbie question regarding Circuit Track...solved! (H0-scale)
by ulf999 03/10/2005 13:47:21(UTC)
Newbie question on Delta Control 4f (Digital)
by LionelMPC 04/05/2005 00:28:10(UTC)
A few newbie questions, sorry if already covered.. (Digital)
by Sam 06/02/2005 17:48:42(UTC)
Another Newbie question:Delta decoders (H0-scale)
by Bill190D 26/11/2003 01:42:51(UTC)
Newbie Question (Digital)
by john 23/11/2002 15:21:31(UTC)
This page was generated in 0.294 seconds.
