Offline rhfil
#1 Posted : 22 November 2023 15:19:10(UTC)
rhfil
I have a new to me Marklin loco, 37018, which looks and sounds great but occasionally it seems to hit spots where the drive wheels spin but the loco does not move. I dread replacing the traction tires and wondered if there was any way to make them less slick?
#2 Posted : 22 November 2023 16:07:24(UTC)
Good question rhfil. I use a liquid plastic polymer. Amazon sells it. I apply thinly with a toothpick. It comes in different colors. Buy the thin viscosity, but not a ruberized type for tool handles, etc.
If you can't power the wheels while upside down, turn them to expose the bare areas as it dries. It should dry clear within a couple of hours or so. It also works excellent on wheels without any tires. Any unevenly treated spots will wear down with running. Too much will cause rail contact dead areas.
Offline BenP
#3 Posted : 22 November 2023 16:56:01(UTC)
BenP
Try this first. Lift the tires from rim without removing them entirely. Clean rim and tires' inside with alcohol. Let dry and return tire to rim. This would remove any greasy residue that lowers tire-rim traction.
Offline rhfil
#4 Posted : 22 November 2023 22:36:00(UTC)
rhfil
The alcohol won't dry the rubber even more? I am hoping to get a link to the liquid plastic polymer mentioned above. A search on Amazon brings up way too many products.
#5 Posted : 23 November 2023 08:48:46(UTC)
That loco is very sensitive about upward changes of the incline. The weight of the loco will then rest on the running axles and the axle with the traction tyres will spin freely in the air.
Maybe that's the issue here. Does it always happen at the same spots? Are rail bent upwards at those spots?
#6 Posted : 23 November 2023 11:19:33(UTC)
Could we have a link or info regarding the make etc.
Offline Michael4
#7 Posted : 23 November 2023 12:09:20(UTC)
Michael4
If the tyres are a bit old and someone has done some generous lubrication it is possible that the tyres are slipping on the wheels...
Offline rhfil
#8 Posted : 26 November 2023 19:34:48(UTC)
rhfil
A very little bit of alcohol applied to the traction tires in locations I had access to applied with a q-tip worked. Thanks.
Changing traction tires on 37780 ICE 3 center power unit (General MRR)
by artvegas 05/10/2023 17:57:02(UTC)
cheapest traction tires ever!! (H0-scale)
by heinrichhess 05/09/2023 20:04:30(UTC)
Uneven traction tires on 39027 and 39491 (Br 02 0314 and DSB E 991) (H0-scale)
by bph 13/05/2022 23:24:15(UTC)
Rokuhan Traction Tires (Small scale)
by zoooctan 30/04/2022 19:39:18(UTC)
traction tires for marklin miniclub (Small scale)
by parakiet 12/11/2021 12:39:08(UTC)
Traction tires (H0-scale)
by Mr. Ron 28/06/2021 02:56:26(UTC)
Traction tires for 3007/SK 800 (Collector's Corner general)
by Soest 22/03/2017 18:24:42(UTC)
3048 traction tires/all loco tires (H0-scale)
by thomas buckley 27/03/2016 21:11:41(UTC)
Alternative to rubber traction tires on locos (General MRR)
by Danlake 09/10/2013 09:19:32(UTC)
Traction Tires / Brushes (General MRR)
by kimmiemck 07/09/2013 17:19:54(UTC)
traction tires for marklin engines (H0-scale)
by reverendpen 10/06/2013 19:36:21(UTC)
Traction Tires for King Ludwig Tristan Loco and #33041 Loco (Digital)
by wsscott 03/12/2012 18:36:30(UTC)
Old Plastic Traction Tires Stuck-Help Please (H0-scale)
by walters48 01/02/2010 03:09:46(UTC)
Senator traction tires (H0-scale)
by rschaffr 19/01/2009 23:47:59(UTC)
Contact track and traction tires (Digital)
by laalves 07/11/2006 00:49:04(UTC)
Traction tires on Marklin Locs (General MRR)
by biswasg 01/01/2006 23:46:26(UTC)
Aging of Traction Tires (General MRR)
by digilox1 04/11/2005 09:16:21(UTC)
Adding traction tires (H0-scale)
by Winst0n 21/06/2004 01:08:12(UTC)
This page was generated in 0.592 seconds.
