Offline Mr. Ron
#1 Posted : 24 June 2023 21:55:49(UTC)
Mr. Ron
While watching some videos of British trains, I see double electric engines in push/pull service. The engines all have their pantographs (8 in all) up running on the wire. Is this standard practice. In the U.S. only the rear pantograph is used. Reason is: If the front pantograph snags the wire, it would take out the rear pantograph leaving the engine without power.
#2 Posted : 24 June 2023 22:13:18(UTC)
Hi Ron
In France only one pantograph is raised on any loco or consist (TGV, Z50000, etc)
The only exception is in low voltage zones (1500VDC) 2 pantographs are raised to cope with high start currents, until a medium speed is reached (not needed with 25000 VAC)
Offline torhb
#3 Posted : 23 July 2023 13:03:50(UTC)
torhb
When two (or more) loks are pulling the train, each lok will have ONE pantograph raised.
Tor Harald Bøhler
Tor Harald Bøhler
Oppegård, Norway
#4 Posted : 23 July 2023 19:49:46(UTC)
Nope.
Online applor
#5 Posted : 27 July 2023 01:19:20(UTC)
applor
Nope.
It needs to be pointed out here that it would also depend on the time period. With the modern spar type pantographs that have two contact points I believe Tor is correct.
However with the earlier SBS 9 single bar style pantographs you see from epocheIII etc then I they would normally run with both pantographs raised as per Toms photo.
#6 Posted : 27 July 2023 10:53:47(UTC)
I think it also depends on the region. Netherlands have low voltage and therefore high amps, so sometimes a single loco will use both pantographs.
Tor may be theoretically correct, but sometimes train drivers simply forget to lower a pantograph.
In case of ice on the catenary, both pantographs may also go up. So it also depends on the season and the weather conditions.
Maximum speed of the consist depends on the pantographs that have been raised. For maximum speed, as few pantographs as possible will be raised with as much spacing between them as possible.
Offline Toosmall
#7 Posted : 27 July 2023 15:41:23(UTC)
Toosmall
Copied from various sources:
4 pantographs used per train set, 8 carriages.
Australia, Sydney, Waratah train sets 78 in total, 8 carriages per set, as long as the train can be to fit in all the city stations. The network is 1500v DC conductor rated at 2000amps. Not a limitation in the city, but it is up the Blue Mountains west of Sydney which is an issue. But we are stuck with 1500v DC, far too complex to change the city network.
Sydney Trains EMUs are actually in two car blocks when it comes to power.
Each pantograph powers each two car block under normal circumstances, which means each pantograph powers 4 traction motors, one air compressor some sort of alternator to supply 120v, 240v, and 480v to various systems.
The two car blocks can get a remote feed from a neighbouring alternator, but when a pantograph is down, the traction motors in that 2 car block are not provided with power.
More reading material here:
Electrification of the Sydney Suburban Train Network
https://dictionaryofsydn...y_suburban_train_network
Offline Toosmall
#8 Posted : 28 July 2023 18:52:29(UTC)
Toosmall
A couple of photos I took at Artarmon station Sydney. The 4 pantographs are used (shot through very dence wire fencing also above head).
Offline Mr. Ron
#9 Posted : 28 July 2023 22:19:35(UTC)
Mr. Ron
Probably the answer is: The train will use as many pantographs as needed to power all the blocks.
Offline Toosmall
#10 Posted : 07 August 2023 11:14:46(UTC)
Toosmall
Not only are the Sydney trains using 4 pantographs. There are dual wires.
#11 Posted : 07 August 2023 19:25:57(UTC)
I've seen dual wires in Belgium, too.
At low voltages (1500 V, 3000 V), you need many amps to get 6 MW power.
Raising the pantographs on märklin 39365 (H0-scale)
by Evergreen 11/04/2025 21:53:23(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
M28590 piezo pantographs (H0-scale)
by QQQ1970 20/04/2024 21:04:43(UTC)
Pantographs (General MRR)
by river6109 05/07/2022 13:10:28(UTC)
Marklin 39126 - Pantographs not working (General MRR)
by tomdakl 24/06/2022 03:08:03(UTC)
39445 E 44.5 2020 Insider - Pantographs (H0-scale)
by Donb 28/10/2021 06:51:11(UTC)
How do I raise the pantographs on my Spur 1 5756 Krokodil? (Big scale)
by JPL44 24/04/2021 18:01:29(UTC)
Adjusting Pantographs (Big scale)
by Surge 01/10/2020 00:42:32(UTC)
Pantographs for DL 800 (H0-scale)
by rhschulz2000 11/08/2018 01:43:32(UTC)
Maerklin 39460 SBB Re 460 Helvetia with Faiveley Pantographs and new motor (Loco Reviews)
by mike c 28/12/2017 04:42:52(UTC)
Working pantographs (General MRR)
Belarus jcrtrains 07/03/2017 02:05:53(UTC)
Fixing pantographs (H0-scale)
by Gregor 18/04/2015 19:09:59(UTC)
Need pair of pantographs for Hag Bühler Ae 6/6 (older version) (H0-scale)
by Marklinista 22/10/2014 12:56:29(UTC)
How many models with Piezo Pantographs? (General MRR)
by cookee_nz 15/06/2014 04:14:22(UTC)
Pantographs with new marklin catenary (H0-scale)
by marklin61 16/02/2014 10:42:11(UTC)
37224 pantographs. (H0-scale)
by steventrain 10/12/2013 22:09:23(UTC)
fixing Märklin wobbly pantographs (General MRR)
by river6109 27/10/2013 09:31:09(UTC)
When Are Diner Pantographs In Use? (Prototype)
by Roman 09/08/2013 02:28:30(UTC)
remote control pantographs (H0-scale)
by sleepvark 02/08/2013 21:18:55(UTC)
Adjusting pantographs on locomotives (H0-scale)
by sjlauritsen 22/06/2013 12:54:33(UTC)
Marklin Budbet Traxx pantographs (H0-scale)
by danmarklinman 31/10/2012 14:40:02(UTC)
Pantographs?? (Prototype)
by Dimi194 13/06/2012 00:52:17(UTC)
Marklin ELok Pantographs. (H0-scale)
by James 25/02/2011 20:35:39(UTC)
Electric loco with 4 pantographs. (H0-scale)
by steventrain 26/10/2010 23:45:38(UTC)
Pantographs (Prototype)
by Dreadnought 22/09/2010 01:37:55(UTC)
by Dreadnought 08/01/2009 04:15:29(UTC)
Make dummy pantographs work (H0-scale)
by dandrikop 24/08/2008 01:32:25(UTC)
Raising pantographs on marklin 39221 (H0-scale)
by grnwtrs 11/01/2008 07:59:29(UTC)
M* and pantographs mounted the wrong way (General MRR)
by H0 05/04/2006 00:59:21(UTC)
Silly Question on Pantographs (H0-scale)
by wilki 04/03/2004 14:29:04(UTC)
by Nuno 22/01/2004 18:57:23(UTC)
This page was generated in 0.647 seconds.
