#1 Posted : 05 July 2022 13:10:28(UTC)
Hi, I'm having trouble with pantographs from the manufacturers such as Piko and Roco, the are not designed to run locos via the overhead system, I must say Märklin has kept up the standard and all of their pantographs are suitable for overhead power usage., some of them may be a bit robuster than the original but this is what I need., the main problem with other pantographs is the strength of the spring which is to weak to keep the wiper against the overhead wire, I've done a lot of modifications but some aren't working well at all.
#2 Posted : 05 July 2022 14:28:53(UTC)
Hi John
Current pick-up in analogue operation is OK with both pantographs up.
In digital operation it is both un-needed and not working properly (a lot of digital information gets lost because of electrical noise).
Seems to me that many manufacturers use long spiral springs.
Some brand adjusted the spring force to a minimum for the visual effect and not efficient current pick-up all this to keep the wear of the pantograph head (the one sliding on the catenary).
It can be easily fixed by reducing the number of loops in the spring and folding the last loop at a 90° angle. This will increase the force on the pantograph head but also increase its wear.
Note: I doubt Märklin does its own pantographs
Sommerfeldt is a pantograph manufacturer and may be (not sure) a subcontractor to Märklin.
See here if you look for a replacement. https://www.sommerfeldt.de/de/
#3 Posted : 05 July 2022 14:55:40(UTC)
Hi John
Sommerfeldt are between Märklin and the standard pantographs produced by Piko or Roco.
, some pantographs you can't reduce the spring as they already very short its mainly the strength of the spring which fails on most occasions, and it depends also on the type of pantograph suitable for each loco
#4 Posted : 06 July 2022 03:32:53(UTC)
Sommerfeldt has been the go-to OEM manufacturer for model train companies, starting with Fleischmann, then Liliput and finally also Maerklin. Roco has been making it's own models since the Rowa days. Other companies currently making their own pantographs include LS Models, ACME and Liliput-Bachmann (some recent models).
In addition to the models made for OEM customers, Sommerfeldt also manufactures models for it's own catalog, sometimes pretty much more detailed versions of the ones prepared for companies on spec.
Raising the pantographs on märklin 39365 (H0-scale)
by Evergreen 11/04/2025 21:53:23(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
M28590 piezo pantographs (H0-scale)
by QQQ1970 20/04/2024 21:04:43(UTC)
Pantographs (Prototype)
by Mr. Ron 24/06/2023 21:55:49(UTC)
Marklin 39126 - Pantographs not working (General MRR)
by tomdakl 24/06/2022 03:08:03(UTC)
39445 E 44.5 2020 Insider - Pantographs (H0-scale)
by Donb 28/10/2021 06:51:11(UTC)
How do I raise the pantographs on my Spur 1 5756 Krokodil? (Big scale)
by JPL44 24/04/2021 18:01:29(UTC)
Adjusting Pantographs (Big scale)
by Surge 01/10/2020 00:42:32(UTC)
Pantographs for DL 800 (H0-scale)
by rhschulz2000 11/08/2018 01:43:32(UTC)
Maerklin 39460 SBB Re 460 Helvetia with Faiveley Pantographs and new motor (Loco Reviews)
by mike c 28/12/2017 04:42:52(UTC)
Working pantographs (General MRR)
by jcrtrains 07/03/2017 02:05:53(UTC)
Fixing pantographs (H0-scale)
by Gregor 18/04/2015 19:09:59(UTC)
Need pair of pantographs for Hag Bühler Ae 6/6 (older version) (H0-scale)
by Marklinista 22/10/2014 12:56:29(UTC)
How many models with Piezo Pantographs? (General MRR)
by cookee_nz 15/06/2014 04:14:22(UTC)
Pantographs with new marklin catenary (H0-scale)
by marklin61 16/02/2014 10:42:11(UTC)
37224 pantographs. (H0-scale)
by steventrain 10/12/2013 22:09:23(UTC)
fixing Märklin wobbly pantographs (General MRR)
by river6109 27/10/2013 09:31:09(UTC)
When Are Diner Pantographs In Use? (Prototype)
by Roman 09/08/2013 02:28:30(UTC)
remote control pantographs (H0-scale)
by sleepvark 02/08/2013 21:18:55(UTC)
Adjusting pantographs on locomotives (H0-scale)
by sjlauritsen 22/06/2013 12:54:33(UTC)
Marklin Budbet Traxx pantographs (H0-scale)
by danmarklinman 31/10/2012 14:40:02(UTC)
Pantographs?? (Prototype)
by Dimi194 13/06/2012 00:52:17(UTC)
Marklin ELok Pantographs. (H0-scale)
by James 25/02/2011 20:35:39(UTC)
Electric loco with 4 pantographs. (H0-scale)
by steventrain 26/10/2010 23:45:38(UTC)
by Dreadnought 22/09/2010 01:37:55(UTC)
by Dreadnought 08/01/2009 04:15:29(UTC)
Make dummy pantographs work (H0-scale)
by dandrikop 24/08/2008 01:32:25(UTC)
Raising pantographs on marklin 39221 (H0-scale)
by grnwtrs 11/01/2008 07:59:29(UTC)
M* and pantographs mounted the wrong way (General MRR)
by H0 05/04/2006 00:59:21(UTC)
Silly Question on Pantographs (H0-scale)
by wilki 04/03/2004 14:29:04(UTC)
by Nuno 22/01/2004 18:57:23(UTC)
This page was generated in 0.355 seconds.
