Offline Mr. Ron
#1 Posted : 06 January 2022 20:25:38(UTC)
Mr. Ron
Marklin couplers work great, but they are far from prototype. Marklin noted for their fine detail, has not produced a coupling that is close to prototype. That being the case, we have to adapt different couplings such as Kadee. In reality, railroads don't have automatic uncoupling. cars are coupled together manually. All countries in Europe use the English buffer and chain system. The English coupling system doesn't appear to be applicable to use on models. The AAR coupler in the USA is the best all-around coupler in use and is well represented in model form by the Kadee coupler. It is therefore the obvious coupling to choose for American models. European models have to rely on weird forms of couplings, the Marklin being one of them. In Europe, when cars have different couplings, a transition car is used with different couplings on each end to match the different couplings used; this happens at borders. So; what is the correct coupling to use on European models? Obviously Kadee couplers are not correct although there are some trains fitted with AAR style couplings. Passenger trains seem to still use the English coupling along with all cars with buffers. Marklin couplers seem to be the right ones for Marklin trains, so I have to stick with them. It just seems a shame that we can be so prototypical with the model, trackwork, etc, but can't get a coupling that is prototypical.
thanks 1 user liked this useful post by Mr. Ron
#2 Posted : 06 January 2022 20:43:34(UTC)
when they first brought out the close coupler (1980s) they made a very prototypical coupler that connected two NEM pocket coaches. You have to choose between being able to easily couple and uncouple cars, or, have prototypical couplers.
Offline Bogenschütze
#3 Posted : 06 January 2022 22:40:17(UTC)
Bogenschütze
When I was modeling British fine scale, it was common to fit locos and rolling stock with prototypical 3-link or screw link couplings. It was quite a delicate operation to couple and uncouple cars using all manner of homemade tools. With practice you could become pretty proficient at it.
I guess if you want the convenience of automatic coupling and buffers you just have to go with Märklin type couplers and add their unrealistic appearance to the long list of compromises we modelers make in order to enjoy our hobby.
Marklin - "The train set I never had as a child."
Keith Bowman
thanks 1 user liked this useful post by Bogenschütze
#4 Posted : 06 January 2022 23:06:27(UTC)
I support Dale’s commentThumpUp
I use Brawa 2250 in such circumstances. They are not “current-conducting” and can only be used with NEM pockets.
https://az95169.vo.msecn...2-447e-93f2-3fbd8e3e7069
Whilst they are best suited to permanently coupled consists, they can be uncoupled into units of, say, three or four wagons for storage though this is somewhat inconvenient.BigGrin
Online kiwiAlan
#5 Posted : 07 January 2022 00:35:48(UTC)
Umm, no they don't, they use a screw link coupling. The chain system was only used in early English trains, and nowadays would only be found on stock in preserved railways.
It is the screw link coupling that Marklin has done as mentioned by Dale, primarily as a conductive coupling for coach lighting, but could be used for any wagon with an NEM coupling pocket.
#6 Posted : 07 January 2022 01:11:58(UTC)
... It is the screw link coupling that Marklin has done as mentioned by Dale, primarily as a conductive coupling for coach lighting, but could be used for any wagon with an NEM coupling pocket.
Hello Alan,
Are these the couplers to which you referred, or are there newer items?
Philip
#7 Posted : 07 January 2022 10:03:15(UTC)
Some ore trains use automatic couplings. Roco made acceptable replications of this type of coupler.
Rail cars use Scharfenberg couplers of different sizes. Kato made an operational power-conducting model of the regular Scharfenberg couplers and used them with their Limburger Zigarre rail-cars.
A new type of automatic couplers is currently tested in Germany and Austria.
Narrow gauge trains use a different type of couplers. And there may be others I never heard of or forget to mention.
The coupler can be seen here between the coaches:
https://www.haertle.de/M...epaeckwagen+Spur+H0.html
Offline Mman
#8 Posted : 07 January 2022 12:15:35(UTC)
Mman
Buckeye couplers have been used on British passenger stock for many decades, these couple on impact with the various pipes and jumpers connected by hand. In more recent decades the type of automatic couplers are fully hands off as they incorporate all those various other connections. Loose coupled trains were eliminated in the 1970s here in the UK on British Railways, container trains use buckeyes as well. Probably only preserved railways have other methods of coupling.
The Pritchard Patent Product Company (Peco) produced a buckeye automatic coupler shortly after WW2 which Meccano Ltd applied to their post war Hornby Dublo range of trains, so I suspect that that was the most true to type model coupler.
Märklin prewar had a buckeye looking coupler on their range of 00/H0 trains but I’m not sure how well that worked.
Lines Bros/Rovex developed their tensionlock couplings for Triang Railways which is basically what most manufacturers use in modified form - who came up with it first I don’t know. Currently Triang Railways masquerade under the name ‘Hornby’ since the name was purchased in the early 1960’s when the manufacturers of Hornby Dublo went bust.
Personally I don’t find the Märklin close couplings very reliable and converted most of my fleet to the relex type, I found the Fleischmann type to be better still, using them in the semi fixed consists. I remember when a friend converted all his Fleischmann to Kadee couplers (at vast expense) and a while later converted them back again for the sake of operational efficiency rather than looks.
Z gauge from Märklin, my current interest, has the very out of scale but mostly efficient lateral hook type - almost buckeye like - couplers which are functional. North American Z manufacturers apparently have other types which are a mystery to me, why fix what isn’t broken?
ChrisG
Offline Nigel Packer
#9 Posted : 07 January 2022 15:05:57(UTC)
Nigel Packer
Part number E313790 for 10 couplers. Non-current-conducting, non-automatic, but the most realistic-looking option.
I use these a lot, mainly for goods trains.
Years ago, these were sold in boxes with the part number 7204.
Nigel
thanks 4 users liked this useful post by Nigel Packer
Offline 1borna
#10 Posted : 07 January 2022 19:59:05(UTC)
1borna
Croatia
Piko presented his I clutch about 50 years ago, it's a pity it didn't come to life!
UserPostedImageUserPostedImageUserPostedImage
Pico was then behind the "Iron Curtain" and could not be found in the west.
I will put more pictures later.
thanks 1 user liked this useful post by 1borna
Offline 1borna
#11 Posted : 09 January 2022 20:44:53(UTC)
1borna
Croatia
On the valuable page of RBD Breslau I found more pictures of that coupling link
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
Offline Mr. Ron
#12 Posted : 09 January 2022 23:50:47(UTC)
Mr. Ron
Very similar to the coupler used by Mantua in the U.S. many years ago. Very reliable, but not too prototypical.
Offline PeFu
#13 Posted : 10 January 2022 10:00:23(UTC)
PeFu
Here’s a glimpse from the near future:
thanks 2 users liked this useful post by PeFu
Relex to Close couplers (General MRR)
by Zeeboo04 08/02/2025 22:21:12(UTC)
Couplers not coupling (H0-scale)
by rg1911 20/01/2025 05:06:14(UTC)
Hornby Magnetic Couplers (General MRR)
by Drongo 01/01/2025 13:11:18(UTC)
How to replace Marklin Maxi F-7 couplers with kadee (Big scale)
by roddewr 16/11/2024 20:43:34(UTC)
39902 Class 290 Telex couplers acting stange? (H0-scale)
by LA2019 01/10/2024 00:10:48(UTC)
Question about couplers (H0-scale)
by fabstar68 18/06/2024 22:35:07(UTC)
Problems with couplers (H0-scale)
by Alex H 29/05/2024 19:05:49(UTC)
Close couplers for some of the 30xx series engines (H0-scale)
by lpesce 13/05/2024 08:44:15(UTC)
Marklin 4707 Couplers (General MRR)
by Bruce Clark 27/08/2023 00:42:47(UTC)
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
Replace all loco couplers with NEM pocket clutch bars (H0-scale)
by einotuominen 09/01/2023 14:48:53(UTC)
Replacement couplers for Märklin # 4722? (H0-scale)
by Coppas 20/11/2022 15:56:06(UTC)
Interior Lighting & Current Conducting Couplers (H0-scale)
by Eddie7979 18/10/2022 11:58:28(UTC)
Decouplers with the CS3 (Digital components and Software reviews)
by Keyser 11/08/2022 17:40:42(UTC)
How can we uncouple current‐conducting closed std. couplers? (H0-scale)
by Pronto5 05/06/2022 01:26:55(UTC)
What are Roco telex couplers like!! (H0-scale)
by danmarklinman 04/06/2022 19:47:12(UTC)
Couplers (H0-scale)
by Harvey 28/12/2021 02:32:07(UTC)
Prototype Couplers - Spur 1 (Big scale)
by Richard556 06/12/2021 08:55:44(UTC)
Scharfenberg couplers (H0-scale)
by oliver 14/11/2021 04:11:06(UTC)
Put proper couplers on Märklin 3132 V5 (H0-scale)
by MartinS 09/10/2021 15:04:39(UTC)
NEM couplers and startup (H0-scale)
by revmox 13/08/2021 13:35:39(UTC)
Help differentiate couplers pack (H0-scale)
by Puttputtmaru 15/07/2021 13:55:14(UTC)
controlling uncouplers (Digital)
by Don Morris 09/07/2021 04:33:12(UTC)
Kupplungs, clutches, and couplers (Small scale)
by husafreak 09/06/2021 18:50:29(UTC)
72021 current conducting couplers (H0-scale)
by marklinist5999 15/05/2021 21:02:42(UTC)
Uncouplers (H0-scale)
by Rwill 28/02/2021 11:22:23(UTC)
Couplers and buffers cause derailment (H0-scale)
by PeFu 14/02/2021 07:15:11(UTC)
Recommendation of 2-pole couplers? (H0-scale)
by PeFu 06/02/2021 17:34:16(UTC)
Magnetic marklin couplers (H0-scale)
by Lucky Trains 20/12/2020 14:02:32(UTC)
Anyone have a Roco locomotive with auto/remote control couplers (H0-scale)
by danmarklinman 16/12/2020 17:41:45(UTC)
current conducting couplers fro 4132 style coaches???????? (H0-scale)
by dominator 24/10/2020 09:50:02(UTC)
Kadee couplers (H0-scale)
by Harlov 05/10/2020 18:29:04(UTC)
Pickup shoes and couplers (H0-scale)
by alistairiancampbell 22/06/2020 10:27:53(UTC)
Current-Conducting close couplers 72021 (General MRR)
by ocram63_uk 25/05/2020 09:48:43(UTC)
Couplers (H0-scale)
by mikemasey 25/05/2020 00:10:10(UTC)
Digital uncouplers. (Digital)
by eberhardt 16/04/2020 11:04:09(UTC)
Where to purchace replacement couplers (H0-scale)
by tcatman 11/02/2020 03:29:48(UTC)
I need advice with Märklin E115737 current conducting close couplers NEM 72020 / 72021 (H0-scale)
by Janne75 06/02/2020 22:55:18(UTC)
Brawa's telex couplers. Opinions? (H0-scale)
by Copenhagen 23/01/2020 17:32:56(UTC)
Roco automatic couplers (H0-scale)
by danmarklinman 05/01/2020 10:45:51(UTC)
Is there some trick with Telex couplers? (H0-scale)
by LongHairedDavid 31/12/2019 18:51:00(UTC)
Is it possible to install Marklin close couplers on a Bachman car? (H0-scale)
by Uwe 29/12/2019 01:33:29(UTC)
change couplers (H0-scale)
by harris19 03/12/2019 11:39:12(UTC)
Couplers for 216 090-1 Engine (H0-scale)
by guitartoys 09/10/2019 05:40:38(UTC)
Marklin couplers for Fleischmann (H0-scale)
by Ivan 02/09/2019 20:38:58(UTC)
Marklin TRAXX Locos - couplers (H0-scale)
by LongHairedDavid 24/07/2019 13:59:01(UTC)
Query on replacing old metal couplers (H0-scale)
by madhu.gn.71 21/11/2018 07:32:11(UTC)
Couplers (H0-scale)
by Twisterdodger 13/11/2018 15:48:45(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Current conducting couplers (General MRR)
by morsing 18/10/2018 21:44:59(UTC)
This page was generated in 0.647 seconds.
