Offline Bones
#1 Posted : 03 September 2021 12:29:10(UTC)
Bones
I am wonder what type of solder should be used and should a temp controlled iron
Once I start to fully wire my layout I don't want to take the risk that the crimp terminals may slide off
#2 Posted : 03 September 2021 12:44:35(UTC)
With Märklin H0 C track I use standard solder and a non-regulated soldering iron (15 W) and it works like a charm.
Soldering wires to the steel rails is a different challenge, but the tabs on the C track make it easy.
#3 Posted : 03 September 2021 15:05:38(UTC)
can you show what you mean exactly by the 'crimp terminals' you are using.
Modern IDC Connectors (insulation-displacement contact) are extremely reliable and do not require solder.
Offline rhfil
#4 Posted : 03 September 2021 16:12:34(UTC)
rhfil
I have found that there is a lack of consistency with size. It is the Goldilocks problem-some are too loose, some too tight, and some just right. I have found it is easiest to make the female connections a bit loose to make connecting easy and then tighten them with small pliers to keep them from slipping off. I have also thought about soldering them but that seems way too permanent. Some kind of a removable contact adhesive would be ideal. Unfortunately it does not seem to exist.
#5 Posted : 03 September 2021 16:39:24(UTC)
I only used crimp terminals on my lighting transformer terminals. They did slide off when I crimped two 22 gague wires on. I soldered them with thin wire solder and a standard iron with flux. For lengthening wiring, and splicing I used heat shrink tubing. I only had to solder first when the splice was thin l.e.d. cable to 24 gague wire.
Offline rhfil
#6 Posted : 03 September 2021 17:48:43(UTC)
rhfil
Oh, good point. Is he talking about the terminals disconnecting from the wires or from the matching terminal? I assumed he was referring to the other terminal. Usually the problem with the wire coming out of the terminal is an improper crimp. I think if you double the bare wire back on itself as I think is recommended by Marklin there should not be a problem with the wire coming out of the terminal.
#7 Posted : 03 September 2021 21:17:47(UTC)
I just solder wires which keeps them from coming loose. If you need to take a wire off again just heat the solder and the wire will come away.
Offline Mr. Ron
#8 Posted : 05 September 2021 23:14:31(UTC)
Mr. Ron
Soldering wires is the right way to go. Crimp on terminals are not reusable anyway, so might as well solder them.
thanks 1 user liked this useful post by Mr. Ron
soldering wires to the Flat sleeve connectors. (General MRR)
by Alex H 06/10/2025 19:48:43(UTC)
Soldering Iron (General MRR)
by Harvey 25/02/2024 16:52:49(UTC)
soldering station (General MRR)
by David Dewar 14/12/2022 15:54:25(UTC)
Marklin 70910 Soldering Iron Set - Australian and NZ members Only (Digital)
by xxup 03/08/2018 05:50:09(UTC)
Soldering (General MRR)
by ocram63_uk 10/07/2018 17:56:14(UTC)
Testing K track soldering - Success! (H0-scale)
by PeFu 08/04/2018 14:33:58(UTC)
Digital soldering station (General MRR)
by Thewolf 15/08/2017 22:46:17(UTC)
What are the best soldering irons to use in our hobby (H0-scale)
by dominator 02/10/2016 11:49:19(UTC)
Soldering & Smoke Alarms (General MRR)
by analogmike 02/10/2016 00:04:07(UTC)
Help required with some advice on simple soldering technique (General MRR)
by Ausipeet 30/03/2016 23:55:44(UTC)
Soldering iron recommendations? (General MRR)
by biotechee 21/11/2013 00:08:41(UTC)
74491 -The soldering saga! (Digital)
by Joseph Meiring 29/07/2013 20:11:30(UTC)
Soldering on marklin C-track to create a detection feedback section... (Digital)
by fhp2 21/07/2013 12:22:29(UTC)
soldering (Digital)
by db ice3 25/12/2012 22:27:17(UTC)
Soldering 3rd rail - How? (H0-scale)
by Rinus 27/12/2009 11:32:17(UTC)
Soldering iron. (General MRR)
by Ian555 07/11/2009 12:34:21(UTC)
What soldering jigs, clamps, holder do you use? (Digital)
by trainbuff 03/06/2009 20:46:49(UTC)
K track / soldering (General MRR)
by bygger01 23/11/2008 19:08:31(UTC)
Soldering Temparature (General MRR)
by Caplin 31/10/2008 20:49:57(UTC)
Decoder, soldering, adding extra functions? (Digital)
by LeoArietis 25/02/2008 19:57:45(UTC)
k-track difficult to soldering (Digital)
by marklinologos 15/10/2007 10:46:59(UTC)
Soldering on k-track (H0-scale)
by Voller 27/07/2007 21:48:53(UTC)
Soldering Station (General MRR)
by David Dewar 17/03/2007 17:50:09(UTC)
EU regulations affect soldering wire (General MRR)
by hmsfix 16/01/2006 00:09:01(UTC)
Soldering K-track (H0-scale)
by hmsfix 23/12/2005 01:01:38(UTC)
Recommended soldering guns and solder (Digital)
by nicky52 19/09/2003 03:16:37(UTC)
This page was generated in 0.390 seconds.
