Offline Twisterdodger
#1 Posted : 13 November 2018 15:48:45(UTC)
Twisterdodger
Having recently added a few ROCO pieces of rolling stock, I notice the ROCO ( Railjet Passenger car 64720 ) coupler pocket is lower than all my MARKLIN pieces. Of course I would hope to make them friendly with each other, does MARKLIN or ROCO make couplers that compensate for this mismatch? Whichever brand, I assume there would need to be a small vertical offset. Essentially the coupler, when installed in the ROCO pocket would need to angle upward to match the MARKLIN height. Can anyone point me in the direction of the correct coupler or a better solution?
Thank you all!
George
Offline PMPeter
#2 Posted : 13 November 2018 16:16:09(UTC)
PMPeter
I use the Roco height adjustable universal couplers 40395 for those situations.
Relex to Close couplers (General MRR)
by Zeeboo04 08/02/2025 22:21:12(UTC)
Couplers not coupling (H0-scale)
by rg1911 20/01/2025 05:06:14(UTC)
Hornby Magnetic Couplers (General MRR)
by Drongo 01/01/2025 13:11:18(UTC)
How to replace Marklin Maxi F-7 couplers with kadee (Big scale)
by roddewr 16/11/2024 20:43:34(UTC)
39902 Class 290 Telex couplers acting stange? (H0-scale)
by LA2019 01/10/2024 00:10:48(UTC)
Question about couplers (H0-scale)
by fabstar68 18/06/2024 22:35:07(UTC)
Problems with couplers (H0-scale)
by Alex H 29/05/2024 19:05:49(UTC)
Close couplers for some of the 30xx series engines (H0-scale)
by lpesce 13/05/2024 08:44:15(UTC)
Marklin 4707 Couplers (General MRR)
by Bruce Clark 27/08/2023 00:42:47(UTC)
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
Replace all loco couplers with NEM pocket clutch bars (H0-scale)
by einotuominen 09/01/2023 14:48:53(UTC)
Replacement couplers for Märklin # 4722? (H0-scale)
by Coppas 20/11/2022 15:56:06(UTC)
Interior Lighting & Current Conducting Couplers (H0-scale)
by Eddie7979 18/10/2022 11:58:28(UTC)
Decouplers with the CS3 (Digital components and Software reviews)
by Keyser 11/08/2022 17:40:42(UTC)
How can we uncouple current‐conducting closed std. couplers? (H0-scale)
by Pronto5 05/06/2022 01:26:55(UTC)
What are Roco telex couplers like!! (H0-scale)
by danmarklinman 04/06/2022 19:47:12(UTC)
Couplers (H0-scale)
by Mr. Ron 06/01/2022 20:25:38(UTC)
Couplers (H0-scale)
by Harvey 28/12/2021 02:32:07(UTC)
Prototype Couplers - Spur 1 (Big scale)
by Richard556 06/12/2021 08:55:44(UTC)
Scharfenberg couplers (H0-scale)
by oliver 14/11/2021 04:11:06(UTC)
Put proper couplers on Märklin 3132 V5 (H0-scale)
by MartinS 09/10/2021 15:04:39(UTC)
NEM couplers and startup (H0-scale)
by revmox 13/08/2021 13:35:39(UTC)
Help differentiate couplers pack (H0-scale)
by Puttputtmaru 15/07/2021 13:55:14(UTC)
controlling uncouplers (Digital)
by Don Morris 09/07/2021 04:33:12(UTC)
Kupplungs, clutches, and couplers (Small scale)
by husafreak 09/06/2021 18:50:29(UTC)
72021 current conducting couplers (H0-scale)
by marklinist5999 15/05/2021 21:02:42(UTC)
Uncouplers (H0-scale)
by Rwill 28/02/2021 11:22:23(UTC)
Couplers and buffers cause derailment (H0-scale)
by PeFu 14/02/2021 07:15:11(UTC)
Recommendation of 2-pole couplers? (H0-scale)
by PeFu 06/02/2021 17:34:16(UTC)
Magnetic marklin couplers (H0-scale)
by Lucky Trains 20/12/2020 14:02:32(UTC)
Anyone have a Roco locomotive with auto/remote control couplers (H0-scale)
by danmarklinman 16/12/2020 17:41:45(UTC)
current conducting couplers fro 4132 style coaches???????? (H0-scale)
by dominator 24/10/2020 09:50:02(UTC)
Kadee couplers (H0-scale)
by Harlov 05/10/2020 18:29:04(UTC)
Pickup shoes and couplers (H0-scale)
by alistairiancampbell 22/06/2020 10:27:53(UTC)
Current-Conducting close couplers 72021 (General MRR)
by ocram63_uk 25/05/2020 09:48:43(UTC)
Couplers (H0-scale)
by mikemasey 25/05/2020 00:10:10(UTC)
Digital uncouplers. (Digital)
by eberhardt 16/04/2020 11:04:09(UTC)
Where to purchace replacement couplers (H0-scale)
by tcatman 11/02/2020 03:29:48(UTC)
I need advice with Märklin E115737 current conducting close couplers NEM 72020 / 72021 (H0-scale)
by Janne75 06/02/2020 22:55:18(UTC)
Brawa's telex couplers. Opinions? (H0-scale)
by Copenhagen 23/01/2020 17:32:56(UTC)
Roco automatic couplers (H0-scale)
by danmarklinman 05/01/2020 10:45:51(UTC)
Is there some trick with Telex couplers? (H0-scale)
by LongHairedDavid 31/12/2019 18:51:00(UTC)
Is it possible to install Marklin close couplers on a Bachman car? (H0-scale)
by Uwe 29/12/2019 01:33:29(UTC)
change couplers (H0-scale)
by harris19 03/12/2019 11:39:12(UTC)
Couplers for 216 090-1 Engine (H0-scale)
by guitartoys 09/10/2019 05:40:38(UTC)
Marklin couplers for Fleischmann (H0-scale)
by Ivan 02/09/2019 20:38:58(UTC)
Marklin TRAXX Locos - couplers (H0-scale)
by LongHairedDavid 24/07/2019 13:59:01(UTC)
Query on replacing old metal couplers (H0-scale)
by madhu.gn.71 21/11/2018 07:32:11(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Current conducting couplers (General MRR)
by morsing 18/10/2018 21:44:59(UTC)
This page was generated in 0.323 seconds.
