Offline db ice3
#1 Posted : 25 December 2012 22:27:17(UTC)
db ice3
i have another question. i feel sorry to be asking again here for more information - i dont want anyone to think im hogging the forum!
so santa claus also brought to me a maplin digital temperature controlled soldering iron.
for a different locomotive that i wish to drive with my central station2, i want to install a lenz mini gold decoder and also a power 1 module which will be installed in a semi - permanently attached wagon.
how much heat can the tiny solder pads on the decoders take?
should i purchase the lowest temperature-melting solder i can find?
the soldering iron controller goes from 150c to 400c.
im afraid to damage the decoder with heat from the iron so what would be all your advices in your experiences?
i have soldered in the past many times but not to something so small as the solderpads on the decoder itself.
tomorrow i will go to the maplin store to try to get the smallest soldering tip available for my iron.
the job is in the pic below - the loose pink, brown and blue wires need to be soldered to the 3 little squares of gold metal on the decoder! - the squares are approx 1mm square - this is encroaching on needing watch making skills lol
or is there an easier way? - how would you do it?
thanks 1 user liked this useful post by db ice3
Offline kbvrod
#2 Posted : 25 December 2012 23:04:56(UTC)
kbvrod
Hi Jay,all,
>so santa claus also brought to me a maplin digital temperature controlled soldering iron. <
Nice!ThumpUp
I'm afraid to damage the decoder with heat from the iron so what would be all your advices in your experiences?<
As someone who has built Z-scale signal kits,maybe I can offer some tips-
1) place the decoder(circuit board) on folded over[two ends] piece of painters tape(blue color in the US, a less sticky form of plain masking tape),on your work area.Secure the decoder on this for a stable base.
2) Tin the wires,that is flux then add solder to the wires.
3) Add a wee bit of flux to the soldering pads.
4) Add more solder to the iron's tip.
make sure you have the highest temp. possible on the iron and it is hot!Quick soldering is the way to protect the decoder/board!
5) Hold the wire in position(or use the tape to help) and hit it with the iron.You can blow on it to help cool the solder.Wait and then -test- the joint.
6) repeat Smile
>tomorrow i will go to the maplin store to try to get the smallest soldering tip available for my iron.<
Good idea!
Dr D
kbvrod attached the following image(s):
Offline db ice3
#3 Posted : 25 December 2012 23:32:36(UTC)
db ice3
dr d - many thanks for this info!
i will add flux to my shopping list as i dont have any - its like a creamy compound isnt it - lightly apply to all surfaces to be soldered?
should i also buy the lowest temperature melting solder that i can find too?
i think the existing solder i have is probably fine for soldering larger cables where heat isnt a big issue but im really afraid to damage the lenz gold mini decoder as they are not cheap!. ( well not for me anyways! ).
thankyou for the technique though, i will follow this carefully.
actually what i do want to do is to fit a plug / socket arangement to the decoder and power 1 module so i can disconnect them if necessary for any reason in the future.
thankyou once again for your help here.
kind regards and merry christmas!
Offline kbvrod
#4 Posted : 26 December 2012 00:05:16(UTC)
kbvrod
Hi Jay,all,
>dr d - many thanks for this info!<
Your welcome!
>i will add flux to my shopping list as i dont have any - its like a creamy compound isnt it - lightly apply to all surfaces to be soldered?<
Correct, a chemical cleaning agent, flowing agent, or purifying agent.
>should i also buy the lowest temperature melting solder that i can find too?<
Special solders,such as Tix can be used but they are for the metal(s) to-be-soldered,....a good rosin core solder will work just fine.
>thankyou for the technique though, i will follow this carefully.<
See above,I posted a photo of the tiny Z-scale signal circuit boards I did,the entry signals had 7 wires!Blink BigGrin
>actually what i do want to do is to fit a plug / socket arangement to the decoder and power 1 module so i can disconnect them if necessary for any reason in the future.<
Good thinking!
>thankyou once again for your help here. <
I think that's what we are all here for!Blushing
Merry Christmas Laddie!ThumpUp
Dr Dirt.
Offline Danlake
#5 Posted : 26 December 2012 05:42:24(UTC)
Danlake
Great tips above!
Instead of masking tape you can also use Blue Tac.
I use that for all my soldring job and easy to do final adjustment on wires/part so they get in correct position before soldering.
Brgds - Lasse
Offline kariosls37
#6 Posted : 26 December 2012 08:00:51(UTC)
kariosls37
Make sure you have some experience in soldering first before you try and solder to a decoder. There is a bit of an art to soldering properly. A good way to learn is to get some old electrical wire and practice soldering that together.
There are diffrent kinds of flux available, and is inmportant you use flux intended for electrical soldering. Flux intended for non-electrical jobs can be very agressive and will harm your decoder.
Something that would be useful for these kinds of jobs is soldering paste, which is available from electronics stores.
Low temperature solder is available, but if you can use normal electronics solder it is probably better in terms of properties. Many people prefer the "old" solder containing lead opposed to the lead free solder. In terms of health, I highly doubt use of lead solder for a hobby will have health effects.
Feel free to ask more questions, that's what this forum is forWink
Rick
Offline kc6uvm_George
#7 Posted : 26 December 2012 08:30:36(UTC)
kc6uvm_George
I've been buying these folks soldering and flux products since I had a hobby shop in the late 1980's.
H&N Electronics: http://www.ccis.com/home/hn/
George,
73 de kc6uvm
NMRA life member
Lancaster, CA
Offline hgk
#8 Posted : 26 December 2012 09:16:13(UTC)
hgk
Another thing with the small tip is to use a small dia. solder. Something like .032 inch. (If you ever need to thicken it you
can always twist 2 or 3 pieces together.) You might also want to get a dry tip cleaner, looks like a bunch of brass curls,
and midsize copper braid for desoldering any mistakes. A clean tip and a clean components are absolutely necessary for a good job.
There are also you tube videos to watch how it's done properly.
thanks 1 user liked this useful post by hgk
Soldering Iron (General MRR)
by Harvey 25/02/2024 16:52:49(UTC)
soldering station (General MRR)
by David Dewar 14/12/2022 15:54:25(UTC)
Soldering (General MRR)
by Bones 03/09/2021 12:29:10(UTC)
Soldering K Track to C Track (Model railroad wiring)
by cancan 03/05/2020 13:30:10(UTC)
Soldering C-track connectors (Model railroad wiring)
by morsing 12/06/2019 18:37:50(UTC)
Soldering Feeder wires to C track (Model railroad wiring)
by Jabez 19/04/2019 22:36:52(UTC)
Marklin 70910 Soldering Iron Set - Australian and NZ members Only (Digital)
by xxup 03/08/2018 05:50:09(UTC)
by ocram63_uk 10/07/2018 17:56:14(UTC)
Testing K track soldering - Success! (H0-scale)
by PeFu 08/04/2018 14:33:58(UTC)
The good temperature of the soldering station (Model railroad wiring)
by Thewolf 07/12/2017 00:07:54(UTC)
Digital soldering station (General MRR)
by Thewolf 15/08/2017 22:46:17(UTC)
What are the best soldering irons to use in our hobby (H0-scale)
by dominator 02/10/2016 11:49:19(UTC)
Soldering & Smoke Alarms (General MRR)
by analogmike 02/10/2016 00:04:07(UTC)
Help required with some advice on simple soldering technique (General MRR)
by Ausipeet 30/03/2016 23:55:44(UTC)
Soldering iron recommendations? (General MRR)
by biotechee 21/11/2013 00:08:41(UTC)
74491 -The soldering saga! (Digital)
by Joseph Meiring 29/07/2013 20:11:30(UTC)
Soldering on marklin C-track to create a detection feedback section... (Digital)
by fhp2 21/07/2013 12:22:29(UTC)
Soldering 3rd rail - How? (H0-scale)
by Rinus 27/12/2009 11:32:17(UTC)
Soldering iron. (General MRR)
by Ian555 07/11/2009 12:34:21(UTC)
What soldering jigs, clamps, holder do you use? (Digital)
by trainbuff 03/06/2009 20:46:49(UTC)
K track / soldering (General MRR)
by bygger01 23/11/2008 19:08:31(UTC)
Soldering Temparature (General MRR)
by Caplin 31/10/2008 20:49:57(UTC)
Decoder, soldering, adding extra functions? (Digital)
by LeoArietis 25/02/2008 19:57:45(UTC)
k-track difficult to soldering (Digital)
by marklinologos 15/10/2007 10:46:59(UTC)
Soldering on k-track (H0-scale)
by Voller 27/07/2007 21:48:53(UTC)
Soldering Station (General MRR)
by David Dewar 17/03/2007 17:50:09(UTC)
EU regulations affect soldering wire (General MRR)
by hmsfix 16/01/2006 00:09:01(UTC)
Soldering K-track (H0-scale)
by hmsfix 23/12/2005 01:01:38(UTC)
Recommended soldering guns and solder (Digital)
by nicky52 19/09/2003 03:16:37(UTC)
This page was generated in 0.380 seconds.
