Offline Ausipeet
#1 Posted : 21 August 2012 07:14:31(UTC)
Ausipeet
Cn some one please explain to me how to connect turn out,s Pionts and lights please in plain non technical english like which wire goes where as turn outs have three wires and where do they connect to please thanks
Offline Angus
#2 Posted : 21 August 2012 11:27:19(UTC)
Angus
My first little bit of advice here, let's see if I manage to get it right.
Talking analogue (M-track):
Your turnout, as mentioned, has three wires, 1x yellow, 2x blue (1 with red plug, 1 with green plug)
The yellow goes into the yellow socket on your transformer. The blue(red) and blue(green) go into their respective sockets in a 7072 unit (the little blue thing with buttons), which is then connected to the brown socket on your transformer via the socket on the side of the 7072 unit.
I hope that helps.
Offline Ausipeet
#3 Posted : 21 August 2012 11:49:00(UTC)
Ausipeet
thank you that's just what the doctor ordered.
Offline amartinezv
#4 Posted : 21 August 2012 11:59:30(UTC)
amartinezv
Hello
All of this things about wiring and more, are explained in marklin brochures, specially in the marklin signals hadbook, you can download these brochures from
http://www.lctm.info/Biblioteca/Libros/index.htm
Antonio Martínez
www.raildigital.es/davidruso
Offline FMS
#5 Posted : 21 August 2012 14:42:18(UTC)
FMS
Tks Antonio!
FMS
How to open my Crocodile's pantographs (H0-scale)
by ParisTsirchoglou 23/09/2025 11:50:09(UTC)
How to tune ESU Loksound/Lokpilot 5 BEMF? (Digital)
by patnaik 15/09/2025 01:53:44(UTC)
How to clean old solenoid signals and turnouts (points) (General MRR)
by Aussie Susan 19/06/2025 07:44:46(UTC)
Locomotives stalling on c-track switches - any ideas how to fix? (H0-scale)
by fynrfin 10/03/2025 19:39:36(UTC)
How to use a decoder function to activate a relay, and keep alive? (Digital)
by 5HorizonsRR 23/02/2025 20:29:00(UTC)
How to register viessmann 5211 on cs3 (Digital)
by geir 25/01/2025 18:28:43(UTC)
How to extract sound from marklin sound project to use them in a different one? (Digital)
by Audik 02/12/2024 17:42:25(UTC)
Roco 4268 passenger coach. How to open for light installation? (H0-scale)
by einotuominen 17/11/2024 15:28:04(UTC)
How to replace Marklin Maxi F-7 couplers with kadee (Big scale)
by roddewr 16/11/2024 20:43:34(UTC)
How to install light kit in Trix coaches (General MRR)
by shannon 25/10/2024 07:40:58(UTC)
How to configure Viessmann 5235 decoder with CS3 (Digital)
by obb_taurus 04/07/2024 17:41:01(UTC)
analog m track parts.. how to... (Model railroad wiring)
by lucasm54 21/04/2024 09:50:34(UTC)
How to adjust 3065 reverser spring? (H0-scale)
by ccranium 16/04/2024 17:52:21(UTC)
Cv29 how to adjust for a speedy loco after short circuit (Digital)
by Puttputtmaru 31/01/2024 00:30:05(UTC)
How to match containers to MArklin 47106 cars (General MRR)
by egonzinc 20/01/2024 03:12:20(UTC)
How to connect/How to use it-a beginner guy (General MRR)
by dra6ko 27/10/2023 14:48:50(UTC)
Locked stock decoders or how to change the Function Keys (Digital)
by Sashmeister 13/10/2023 08:44:34(UTC)
How to reduce noise on our permanent train layouts ? (H0-scale)
by French_Fabrice 03/08/2023 15:14:04(UTC)
How to change a Delta Chip to an FX one (Digital)
by Harryv40 29/07/2023 12:13:57(UTC)
How to make Marklin Ktrack turnout power-routing (General MRR)
by Yoginath 01/07/2023 05:56:24(UTC)
how to identify a digital loco (H0-scale)
by heinrichhess 07/06/2023 21:38:51(UTC)
How to calculate length of curved track (H0-scale)
by garben 05/06/2023 18:08:32(UTC)
CS3 - how to edit loco and initial screen set ups? (Digital)
by kimballthurlow 05/03/2023 07:26:58(UTC)
How To Modify A Marklin RM 800 For Studded Track? (General MRR)
by Roman 04/03/2023 05:38:53(UTC)
Märklin 37320 Re 10/10 how to reprogram double-traction (H0-scale)
by PFG45 17/02/2023 20:56:03(UTC)
How to remove the chassis cover on Marklin #33034 BR 80.030? (General MRR)
by Sally 25/01/2023 22:03:45(UTC)
How to mount analog signals to table? (H0-scale)
by Brian_BR96 06/10/2022 02:44:03(UTC)
How to wire the Marklin 60902/60942 decoder to achieve swiss lighting in Re460 (Digital)
by Bill L 05/10/2022 09:01:14(UTC)
How to replace rubber tires on Marklin 37796 TGV?? (H0-scale)
by frickwg 06/09/2022 18:33:13(UTC)
How to design a layout (General MRR)
by Mr. Ron 31/08/2022 06:43:45(UTC)
How to open coal tender on BR 52 3793 ???? (General MRR)
by mattj70 19/08/2022 18:33:10(UTC)
Trix Marklin Alco Pa Union Pacific 600/601 DCC -how to connect the LED lights in AC system (H0-scale)
by Bill L 25/05/2022 01:33:28(UTC)
How to reset an MFX Item (Digital)
by thulasa 24/03/2022 12:36:51(UTC)
How to Change Tires on 37183 (H0-scale)
by Harvey 28/02/2022 22:50:00(UTC)
How to date an old 3031? (H0-scale)
by artfull dodger 23/01/2022 07:30:51(UTC)
How to run CS3+ events at a specific time of the day? (Digital)
by Nick1150 22/01/2022 11:43:05(UTC)
How to power 72720 control box? (Model railroad wiring)
by Dfergus54 01/01/2022 14:54:57(UTC)
How to connect boosters please (Model railroad wiring)
by DV 25/11/2021 04:07:24(UTC)
How to read a german "Zugbildung" (Prototype)
by fosuna 29/10/2021 10:36:25(UTC)
how to test a 3015 crocodile ? (Collector's Corner general)
by fifoooo 25/10/2021 19:06:22(UTC)
How to open a 3138 (H0-scale)
by geir 21/10/2021 22:40:16(UTC)
How to use turntable "position reached" in TC? (Digital)
by MartinS 26/09/2021 16:42:43(UTC)
Factory Decoder Bricked after Failed Firmware Update. How to Unbrick? (Digital)
by DaveCowl 12/09/2021 22:17:24(UTC)
How to disassemble old tin plate coaches (General MRR)
by ocram63_uk 21/08/2021 13:18:12(UTC)
How to route wiring (General MRR)
by Mr. Ron 01/08/2021 23:45:13(UTC)
How to connect 60974 on a board without SUSI-connector? (Digital)
by mzbringh 04/07/2021 10:22:52(UTC)
How to make my Faller figures stand? (H0-scale)
by H5463 23/06/2021 15:41:41(UTC)
Your favorite how to site or channel (General MRR)
by Puttputtmaru 07/06/2021 21:08:03(UTC)
How to properly store our trains (Small scale)
by wildstix 15/05/2021 10:36:29(UTC)
Intellibox I 65000 S88 damaged. How to open it? (Digital)
by fje 01/05/2021 18:12:54(UTC)
This page was generated in 0.293 seconds.
