Offline anthpao
#1 Posted : 19 October 2011 12:36:52(UTC)
anthpao
I want to add telex couplers to some of my locomotives. All of the have Esu decoders so I can use the function mapping to enable telex couplers.
I am familiar with marklin's telex couplers 117993 and I can't say that I am totally happy with their functionality.
So my question is: Are Roco's telex couplers better and more reliable than Marklin's and are they compatible with Marklin's close couplers.
P.S. The problem i have with Marklin's is that if I enable the coupler and then disable it, the coupler still remains enabled until I press the STOP button. This happens only with the locomotives that I retrofitted with telex couplers.
It doesn;t happen with 37903 Loco that uses the same type of close coupler.
Offline NZMarklinist
#2 Posted : 23 October 2011 19:36:34(UTC)
NZMarklinist
Hi Anthpao,
I refered this thread to my friend and list member drwhittle, known locally as "The Train Dr" and hoped he would comment on the forum, but..........
He is converting my M37900 (among other projects) to an M4 decoder with sounds,double "A" light function and Telex couplers using the 117993's. We are just waiting for the new Marklin Decoders(MFX) to see if they provide a better solution, otherwise it will be an ESU M4.
His comments re your difficulty with them;
"Re the telex coupler thing, I think the Greek Gentleman has probably messed up his retro-fitting somehow. No reason for them to do that."
So check your wiring and function settings maybe ??!!
Glen
Auckland NZ
Offline anthpao
#3 Posted : 25 October 2011 21:43:27(UTC)
anthpao
Thank you for your time.
I will try to see if there is a "ground problem" with the common (+) wire and the function wire (purple).
Offline kbvrod
#4 Posted : 25 October 2011 23:38:06(UTC)
kbvrod
The thing to remember is that a Telex is basically a switch/point/turnout/signal,a momentary contact,unlike the other functions that a lok decoder has to preform.If a decoder can be programmed to send the single impulse to the Telex,AND it can be uncoupled(without movement),you have a problem.Look at M or any one else uncoupler tracks,...long?
Roco,a few years ago they did come out with an remote uncoupler on a Köf I(?),big and ugly and not available as a spare part because the average Joe would burn it out,....
Dr D
#5 Posted : 26 October 2011 04:31:06(UTC)
NZMarklinist
Hi Anthpao,
The first thing I would check, which you can do with either MCS or an ESU Lokprogrammer, is to make sure you have the function for your telex's enabled as a "momentary" function Confused not permanent Cursing
Glen
Auckland NZ
Offline Dave Banks
#6 Posted : 26 October 2011 09:49:20(UTC)
Dave Banks
Hi Anthpao, when I installed telex couplers in my Marklin #30322 BR81, I was lucky enough to install an ESU Loksound V3.5 decoder & it was most probably an early version but it offered you a time setting for telex & you could set the number of seconds you wanted it to remain on. The MFX loksound decoder unfortunately did not afford one that luxury & one could set it only as a "momentary setting". That is about all I can add to the subject for you.
D.A.Banks
39902 Class 290 Telex couplers acting stange? (H0-scale)
by LA2019 01/10/2024 00:10:48(UTC)
What are Roco telex couplers like!! (H0-scale)
by danmarklinman 04/06/2022 19:47:12(UTC)
Brawa's telex couplers. Opinions? (H0-scale)
by Copenhagen 23/01/2020 17:32:56(UTC)
Is there some trick with Telex couplers? (H0-scale)
by LongHairedDavid 31/12/2019 18:51:00(UTC)
New Märklin H0 telex couplers (H0-scale)
by Minok 01/12/2017 19:50:55(UTC)
Digital Telex couplers (Digital)
by disavelo 20/08/2017 11:23:27(UTC)
Those pesky telex couplers (oh wait,its a new kind of telex!) (H0-scale)
by Minok 29/02/2016 07:01:26(UTC)
How to wire analog Märklin DB BR 85 with Telex couplers (H0-scale)
by Janne75 06/01/2015 23:19:04(UTC)
Can I retrofit my BR81 from 2006 digital starter set #29852 with Telex couplers? (General MRR)
by shamrock 24/05/2014 16:53:03(UTC)
Telex couplers not "holding on" to carriages (Digital)
by anderspihl 08/11/2012 13:24:05(UTC)
New Items; why no telex couplers? (H0-scale)
by peterbrown 02/02/2008 20:18:11(UTC)
Telex Couplers on 37903 (H0-scale)
by Frostie 20/09/2007 01:10:36(UTC)
Any new telex couplers under development? (H0-scale)
by trainbuff 23/06/2007 08:12:24(UTC)
Digital Telex Couplers ... Compatible? (H0-scale)
by Night Train 06/06/2005 02:09:38(UTC)
This page was generated in 0.427 seconds.
