Offline Dreadnought
#1 Posted : 22 September 2010 01:37:55(UTC)
Dreadnought
This question, is out of idle curiosity.
I have noticed electric engines in Europe tend to have the after pantograph up, drawing power as they run. Sometimes a freight train, if pulling new cars in auto carriers it is the forward one. I understand that is to keep sparks from the pantograph rubbing on the catenary falling onto the cargo, (cars in my question).
Almost all other trains, particularly passenger, it seems to be the after pantograph. Is there a reason, ie quieter for the driver?
Offline sjlauritsen
#2 Posted : 22 September 2010 09:00:17(UTC)
sjlauritsen
No, but in case of an accident (e.g. the pantograph breaks and falls of), it will not hit the other pantograph. The locomotive will still be able to drive using the other pantograph.
Søren from Denmark
Offline kariosls37
#3 Posted : 22 September 2010 09:56:29(UTC)
kariosls37
The only reasons that a loco may have it's front panto up is:
A) the car/cargo could be damaged by sparks if the car/cargo is flammable, where the rear panto is down
B) if the loco is a multiple voltage type, in which case each panto is for one(or more eg. 3kV and 1.5Kv DC) voltage and only the panto for that voltage is up
C) if the loco is an older type and is accellerating from a standstill,both pantos will be up. The front panto is withdrawn as soon as the loco has built up speed. This has to do with the maximum current allowed per panto.
There are some interesting videos on youtube that show what happens when a panto goes into self destruct mode
#4 Posted : 22 September 2010 12:59:09(UTC)
This applies to locos running on DC, but not to all European locos.
It seems you're a fan of railways from the Netherlands - but you should indicate that in your responses.
German locos with old-style pantographs will always have both up - to get secure contact. But this was discussed before.
Similar topics:
https://www.marklin-user...aspx?g=posts&t=11860 (started by Dreadnought)
https://www.marklin-user...erms=raise,catenary,rear
#5 Posted : 22 September 2010 21:45:51(UTC)
Some loks, like the first series of Re 4/4II (or the BLS Re 425) are equipped with only one pantograph. I wonder if these loks had to be turned around to run with a load of car carriers, tank cars or other cargo that needed to be hauled with the pantograph at the opposite end of the lok? Is that one of the reason that all of the Re 4/4II of the first series (11101-11155) were transferred to SBB Passenger when the fleet was divided?
#6 Posted : 22 September 2010 22:50:28(UTC)
Hi, Mike,
I can't speak for SBB, but DB locos with only one suitable pantograph (e. g. some BR 189) run as they come, they are not turned around.
Sometimes they pull tank cars or car transporters while using the rear pantograph.
Offline perz
#7 Posted : 22 September 2010 23:39:31(UTC)
perz
Choice of front or rear pantograph could, at least in the old days, be a question of best aerodynamics. The turbulence caused by the loco front will, depending on the speed of the train and the shape of the loco front, cause an upward or downward force on the pantograph. This force can be significantly different at the front and the rear pantograph. If it is an upward force, you get excessive wear. If it is a downward force, you get bad contact.
I assume that those problems are solved on newer loks.
Offline Dreadnought
#8 Posted : 23 September 2010 06:42:34(UTC)
Dreadnought
Thank you everyone. Fasciating answers. This forum is a wonderful source of information.
Now that you mention it, I recall seeing a pantograph disintigrate on a UTube video. It took a good chunk of catenary when it went.
Now I have no excuse for not concentrating on work.
Offline kariosls37
#9 Posted : 23 September 2010 11:16:37(UTC)
kariosls37
Similar topics:
Your'e absolutely right. Thanks for pointing it out.
It only applies in DC countries(because of the larger currents involved). I should have mentioned it(I knew tooBlushing )
Kariosls
Raising the pantographs on märklin 39365 (H0-scale)
by Evergreen 11/04/2025 21:53:23(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
M28590 piezo pantographs (H0-scale)
by QQQ1970 20/04/2024 21:04:43(UTC)
Pantographs (Prototype)
by Mr. Ron 24/06/2023 21:55:49(UTC)
Pantographs (General MRR)
by river6109 05/07/2022 13:10:28(UTC)
Marklin 39126 - Pantographs not working (General MRR)
by tomdakl 24/06/2022 03:08:03(UTC)
39445 E 44.5 2020 Insider - Pantographs (H0-scale)
by Donb 28/10/2021 06:51:11(UTC)
How do I raise the pantographs on my Spur 1 5756 Krokodil? (Big scale)
by JPL44 24/04/2021 18:01:29(UTC)
Adjusting Pantographs (Big scale)
by Surge 01/10/2020 00:42:32(UTC)
Pantographs for DL 800 (H0-scale)
by rhschulz2000 11/08/2018 01:43:32(UTC)
Maerklin 39460 SBB Re 460 Helvetia with Faiveley Pantographs and new motor (Loco Reviews)
by mike c 28/12/2017 04:42:52(UTC)
Working pantographs (General MRR)
by jcrtrains 07/03/2017 02:05:53(UTC)
Fixing pantographs (H0-scale)
Belarus Gregor 18/04/2015 19:09:59(UTC)
Need pair of pantographs for Hag Bühler Ae 6/6 (older version) (H0-scale)
by Marklinista 22/10/2014 12:56:29(UTC)
How many models with Piezo Pantographs? (General MRR)
by cookee_nz 15/06/2014 04:14:22(UTC)
Pantographs with new marklin catenary (H0-scale)
by marklin61 16/02/2014 10:42:11(UTC)
37224 pantographs. (H0-scale)
by steventrain 10/12/2013 22:09:23(UTC)
fixing Märklin wobbly pantographs (General MRR)
by river6109 27/10/2013 09:31:09(UTC)
When Are Diner Pantographs In Use? (Prototype)
by Roman 09/08/2013 02:28:30(UTC)
remote control pantographs (H0-scale)
by sleepvark 02/08/2013 21:18:55(UTC)
Adjusting pantographs on locomotives (H0-scale)
by sjlauritsen 22/06/2013 12:54:33(UTC)
Marklin Budbet Traxx pantographs (H0-scale)
by danmarklinman 31/10/2012 14:40:02(UTC)
Pantographs?? (Prototype)
by Dimi194 13/06/2012 00:52:17(UTC)
Marklin ELok Pantographs. (H0-scale)
by James 25/02/2011 20:35:39(UTC)
Electric loco with 4 pantographs. (H0-scale)
by steventrain 26/10/2010 23:45:38(UTC)
by Dreadnought 08/01/2009 04:15:29(UTC)
Make dummy pantographs work (H0-scale)
Belarus dandrikop 24/08/2008 01:32:25(UTC)
Raising pantographs on marklin 39221 (H0-scale)
by grnwtrs 11/01/2008 07:59:29(UTC)
M* and pantographs mounted the wrong way (General MRR)
by H0 05/04/2006 00:59:21(UTC)
Silly Question on Pantographs (H0-scale)
by wilki 04/03/2004 14:29:04(UTC)
by Nuno 22/01/2004 18:57:23(UTC)
This page was generated in 0.404 seconds.
